Ring Gap for turbo
LeninCas
LeninCas is offline
PostPosted: Sat Oct 03, 2015 3:33 pm    Post subject: Ring Gap for turbo Reply with quote
I searched the forum and found that someone else with a turbo used a .020 ring gap for their top ring and a .024 ring gap for their 2nd ring.
I did MY math and according to Wiseco's chart, I should use a .018 top ring and a .020 2nd ring.
This car will see the both street and track. Should I use the numbers I found in the forums or the ones I came up with? I am using Mahle forged pistons (93.93)
one, two, many
one too many
Howard 111
Howard 111 is offline
PostPosted: Sat Oct 03, 2015 6:20 pm    Post subject: Reply with quote
I went with a Total Seal second ring. It just seemed right for an engine using boost.
1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270
SamT
SamT is offline
PostPosted: Sat Oct 03, 2015 6:34 pm    Post subject: Reply with quote
Just use the chart.
No need for total seal rings either. They work great, but the need for them is a gimmick.
Howard 111
PostPosted: Sat Oct 03, 2015 7:17 pm    Post subject: Reply with quote
What size turbo do you run SamT? What size engine?
1973 Karmann Ghia
LeninCas
LeninCas is offline
PostPosted: Sun Oct 04, 2015 12:49 am    Post subject: Reply with quote
It's a Garrett T3/T4 on a 1914. Probably won't run more than 11 psi (91 pump fuel) unless Im at the track which probably wont be more than 4 times a year.
one, two, many
one too many
Eaallred
Eaallred is offline
PostPosted: Sun Oct 04, 2015 9:00 am    Post subject: Reply with quote
I run 22 and 24 gap on my rings with 24 lbs boost. 18 and 20 should be fine at lower boost levels
Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn.
mark tucker
mark tucker is offline
PostPosted: Sun Oct 04, 2015 9:19 am    Post subject: Reply with quote
total seal not a gymick unless you have no brains. but then nothing will last and you blame it on something else. as for the wizeco chart...it's also for wizeco pistons.not all pistons are created equal and they retain or shed/reject heat differently. high silocon aloys tend to run hotter witch will make the ring run hotter and gap close up more.
engine labs has a good article by mahle on piston aloys, they also have a very good mahle article on piston rings....and oh so many many more performance related real articles, not internet mombojumbo bob,gene elmo said shit that was miss quoted,miss heard,miss printed,just plain missed allthe way around. and for the "oh but it's a vw crowd" the fucking engine dosent know what it is. Shocked
SamT
SamT is offline
PostPosted: Sun Oct 04, 2015 12:34 pm    Post subject: Reply with quote
That settles it! I suspect my blow by should show up any day now? I wont be able to sleep now.
SamT
SamT is offline
PostPosted: Sun Oct 04, 2015 12:35 pm    Post subject: Reply with quote
2332. T4
Fiatdude
Fiatdude is offline
PostPosted: Sun Oct 04, 2015 1:15 pm    Post subject: Reply with quote
^^^^This should work for you^^^^^^
But on my turbo'd 2989 T1, I won't have anything but total seals in there on the first and second rings, guess it is just your preference.........
Remember, as you travel the highway of life,
For every mile of road, there is 2 miles of ditch
Howard 111
PostPosted: Sun Oct 04, 2015 1:56 pm    Post subject: Reply with quote
SamT wrote:
2332. T4
I'll bet that thing is a blast!!! Very Happy
1973 Karmann Ghia
SamT
SamT is offline
PostPosted: Sun Oct 04, 2015 6:19 pm    Post subject: Reply with quote
Howard 111 wrote:
SamT wrote:
2332. T4
Yup lots of fun. But its pretty dangerous dare i say. I leave my 8psi spring it because its uncontrollable with the 14. 900lb with no passengers and 300HP on tap is enough. With paddles in sand i can get on it pretty good, but it will go over backwards if you screw up bad. On the street its plain scary when the boost comes on it literally throws you back like that fake nitrous on fast and furious. It doesnt loose boost when shifting either if your on the floor. Im just thankfull my suspension is excellent or it would be a death machine. No beers while playing either and that kinda sucks.
modok
modok is offline
PostPosted: Sun Oct 04, 2015 6:50 pm    Post subject: Reply with quote
Wiescos chart is OK!
.018 is a good minimum for top ring, and I also agree on the idea the second gap should be the same to a bit more.
This is to make sure the top ring holds compression and the second ring stays sharp.
So lets say the spec is .018-.024,
don't feel bad if you try for .018 and overshoot a thou or two.
LeninCas
LeninCas is offline
PostPosted: Mon Oct 05, 2015 2:48 pm    Post subject: Reply with quote
I guess I could do 18 and 20 with little boost but I do plan on using up to 22psi boost at the track with race fuel once in a while so I'll go with 20 and 24.
I've read on here that Total Seal 2nd isn't always necessary and this isn't going to be a track car only with lots of boost all the time so I don't think I will need it. If I end up getting too much blow by, I will switch to Total Seal 2nd ring next.
Thank you everyone for your help.
one, two, many
one too many
Stripped66
Stripped66 is offline
PostPosted: Mon Oct 05, 2015 4:49 pm    Post subject: Reply with quote
If you end up getting too much blow-by, then you need to think about why you have blow-by. .024" of ring gap is not the reason why...
66brm wrote:
Bodacious wrote:
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor.
I don't think electrickery works that way
Howard 111
PostPosted: Mon Oct 05, 2015 5:04 pm    Post subject: Reply with quote
SamT, I'll bet that thing does scare you. That is so light! Have fun and be careful!
1973 Karmann Ghia
Eaallred
Eaallred is offline
PostPosted: Mon Oct 05, 2015 5:29 pm    Post subject: Reply with quote
I've run BIG ring gaps before (a bit carried away with filing!) and it made zero difference. Over 0.030" gaps.
So proper gap vs. total seal? Meh.
Better the gap is a little big than a little small. Rings expand when hot and if they expand enough to touch and then some, that's when expensive stuff happens.
Eric Allred
clonebug
clonebug is offline
PostPosted: Mon Oct 05, 2015 5:37 pm    Post subject: Reply with quote
If you have too much blow-by,,, you had better check your pistons for cracks.....if you can see them.
In fact...I have a set that you can look over if you want....... Rolling Eyes Embarassed
Changed them out and blow by was gone.
vwracerdave wrote:
Take a good long look in the mirror and report back on what you see.
Paul.H wrote:
That one line on that chart is probably better info than you can get from this place in a month
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936
Fiatdude
Fiatdude is offline
PostPosted: Tue Sep 27, 2016 7:59 am    Post subject: Re: Ring Gap for turbo Reply with quote
My total seal gapless 2nd rings are set at .008 gap
