reluctantartist Samba Member
Joined: August 13, 2006 Posts: 1927 Location: Bloomington, IN
Posted: Sun Oct 04, 2015 6:19 pm Post subject: heater motor - fan blowing fuses |
The heater blower is blowing fuses. Is this something that can be dealt with by lubricating the bearings? Can these be rebuilt ? It looks like they are NLA even thought the bays use them as well.
Thanks _________________ 1982 Westy, 1974 412 Variant... Yes, Aircooled's are great! Oh and I do have modern computer controlled vehicles too, but I just don't care about them. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21513 Location: Oklahoma City
Posted: Sun Oct 04, 2015 7:31 pm Post subject: |
The motor itself is likely not blowing fuses. Which fuse is blowing?
Yes... a few parts are tricky to disassemble and reassemble....but they can be rebuilt. G3t a spare when you can....but shirt of lube and occasionally bearings....rare occasion.....most of these just has little wear on them.
Usually when fuses start blowing......its connection issues or overheating. Ray |
Kharon8 Samba Member
Joined: March 05, 2011 Posts: 375 Location: Espoo, Finland
Posted: Mon Oct 05, 2015 1:01 pm Post subject: |
I just ... not 'rebuilt' as that's too much, but ... let's call it 'serviced' my fresh air fan as it wasn't running at all.
Dirt/dust in bearings, broken connector and very oxidized anchor.
Cleaned the bearings with brake cleaner, changed the connector and ground anchor with 1000 grit metal sand paper carafully until it was shiny again.
Cleaned the grinding dust away with brake cleaner and now it works like a charm again.
Of course the fresh air fan is something you can disassemble, to a degree: You at least can see the anchor and coals (to clean them). _________________ Kharon -- '62 typ1, '63 typ14, '61 typ21, '65 typ34, '74 412, '75 typ26
FVWA.fi support group. |
Posted: Mon Oct 05, 2015 3:33 pm Post subject: |
The fuse that is blowing it the 16 amp one for the blower in the engine compartment. The pump runs and the heater fires up. _________________ 1982 Westy, 1974 412 Variant... Yes, Aircooled's are great! Oh and I do have modern computer controlled vehicles too, but I just don't care about them. |
Posted: Tue Oct 06, 2015 6:21 am Post subject: |
Ah....yes.....you are on the right track then. It has been a long time since i have had to be inside one of those motors......but i had to work on them a couple of times. They are a little tricky if memory serves.
Just going off memory......there is a set screw for the fan on a D-shaped shaft. Remove motor from housing......and two screws. ...or three bend tabs on the tail of the motor. I will have to look at mine. I also have some of the wagon style motor i will look at.
The issue i remember is spring loaded brushes and short brush leads. I know there is more to it. Its easily been 18 years. Also the bearing is a cup bushing if memory serves on one end and a shaft bushing on the other. They need to be cleaned and the shaft polished.
I had taken to not using grease any more on these bearings. I used ATF on one and it works great. The grease eventually dries. I will probably need to do mine as well its been 14 years since it ran. I may try superlube synthetic grease. Ray |
Posted: Thu Oct 15, 2015 8:58 pm Post subject: |
I have the heater fan apart and it has a bakelite squirrel cage. Is there a way to remove it? I can't get at the bearing to grease it. _________________ 1982 Westy, 1974 412 Variant... Yes, Aircooled's are great! Oh and I do have modern computer controlled vehicles too, but I just don't care about them. |
