chris123 Samba Member
Posted: Fri Oct 09, 2015 10:24 am Post subject: rear bumper splash plates |
Hi people,
Can anybody advise me are rear bumper splash plates necessary the van has gone in for a paint job and upon removing the bumper there was a lot of rust in the are where the plates can these be left off when I replace the rear bumper
thanks |
Convoy Samba Member
Joined: March 17, 2011 Posts: 312 Location: San Clemente
Posted: Fri Oct 09, 2015 10:55 am Post subject: |
They are heat shields . More of a safety item than anything else as they shield dresses, clothing, etc. from contacting a hot muffler. Not totally necessary. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51152 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Oct 09, 2015 11:51 am Post subject: |
The pans support the ends of the bumper, without them the ends wiggle up and down and eventually crack the blade at the mount bolts. They also keep rocks from bouncing off the inside of the blade and chewing up the back of the bus. Never seen them cause rust, did the bus sit a long time with leaves or pine needles trapped in there? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Dana Champion Samba Member
Joined: July 06, 2012 Posts: 633 Location: Ventura County, CA
Posted: Fri Oct 09, 2015 5:10 pm Post subject: |
Back in the day it was common place to remove them. Keeping these critters more stock original today is where it's at. I would put them back on. They are available, you might have to get them overseas. |
awreed Samba Member
Joined: January 14, 2010 Posts: 1268 Location: Kirkland, WA
Posted: Fri Oct 09, 2015 6:26 pm Post subject: |
As busdaddy said, these splash pans are absolutely necessary to support the ends of the bumper from wiggling up and down. This is what they look like on the assembled rear bumper with brackets
Without any splash pans or anything else to support the bumper, you'll get cracks in the paint/powdercoat where the bracket carriage bolts are. Look closely. With enough bumping and wiggling up and down, the steel of the bumper can begin to tear as well
These are not always easy parts to find, so in the meantime get some steel and bend it to the correct shape. Use some rubber gaskets to protect your paint. This is what I did while searching for my splash pans. This won't keep rocks from hitting the underside of the car, but they'll hold the bumper steady.
Tcash Samba Member
Posted: Fri Oct 09, 2015 9:59 pm Post subject: |
I thanks everybody for your advice , I will be putting them back on |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Fri Feb 10, 2017 7:37 pm Post subject: Re: rear bumper splash plates |
I came across this while searching for info on splash pans. I see from the above picture that they appear to be the white bumper color. I recently got a used set to refurbish for a 70 I'm working on, and although all the top paint had flaked off, the bottom had some black paint under some undercoating. So, are they all white, white top with black bottom, or is the black paint a rattle can job that has nothing to do with the color? |
airschooled Air-Schooled
Posted: Fri Feb 10, 2017 8:02 pm Post subject: Re: rear bumper splash plates |
[email protected] wrote: |
From the factory, the bumpers and brackets were white, while the splash pans were black. I have no idea the percentage of gloss, but my local powder-coater does runs of gloss and semi gloss black every other week, so I just had him throw them in with whatever he had that week. They looked nice until a Honda bashed into them in Mancos, Colorado. Funny, the bumper powdercoat was fine but it snapped a bumper bolt and folded the splash pan…
www.airschooled.com |
Lil Lulu Samba Member
Joined: December 08, 2007 Posts: 1745 Location: Mouth of the Columbia
Posted: Fri Feb 10, 2017 9:07 pm Post subject: Re: rear bumper splash plates |
After what I saw happened to a friend's bus from a parking tap on the rear bumper, I have opted to run with no rear bumper. On my bus it would have just been a ding. It ripped the shit out of both rear corners on his and fucked up the bumper. Hit and run. _________________ '65 Beetle "Lil' Lulu"- Ruby Red
1600 stock from '71 bus
'72 Deluxe - Niagara Blue w/pastelwiess Camper Special 2L dual 40 Webers 002
'74 Hightop Weekender "Dixie" 1800 34 Del singles |
wcfvw69 Samba Purist
Posted: Fri Feb 10, 2017 9:23 pm Post subject: Re: rear bumper splash plates |
I sourced an original, non restored set of 70' splash pans. They were black from the factory and didn't look gloss but more like the engine tin glossiness or semi gloss.
They are absolutely needed unless you want your bumper ends flopping around and looking terrible. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Sat Feb 11, 2017 7:09 am Post subject: Re: rear bumper splash plates |
Interesting...... So the 70 I got them for didn't have them. And like mentioned, if you bumped the end of the bumper with your knee, it would sit there and vibrate like a tuning fork. The drivers side of the body was completely smooth without any mounting hole, or raised section. After doing some investigating, it turned out it had been bumped into and that section of the body had been patched, and filled over. It's a shame because that was about the only bad spot on the whole Bus. It also explains why they weren't on because the drivers side one was probably destroyed. The black paint I did find on mine was a satin type finish, so I'll put them back in that. For anyone's future reference, SEM's Hot Rod Black is a nice catalyzed paint that has about a 60%/degree gloss. Thanks to all for the info! |
awreed Samba Member
Posted: Sat Feb 11, 2017 7:18 am Post subject: Re: rear bumper splash plates |
When I found those splash pans they were still primer gray. I had no idea what color they were supposed to be, so I just had them powder coated to match the bumper. Guess I should have done some research first before acting- oops The white on white still works for me though. |
Posted: Sat Feb 11, 2017 8:28 am Post subject: Re: rear bumper splash plates |
awreed wrote: |
It's all good. I would actually prefer them in white, and I may still go with white if the customer wants to. The shop I work at does a lot of OEM restorations, so the "what is correct" ideal has gotten hard wired into my brain. It's a nice stock Bus, but it's a fun vehicle for the customer, and I don't think it matters much to them about correctness. |
