Merian Samba Member
Posted: Mon Oct 12, 2015 3:23 pm Post subject: Vacuum Leaks |
Oddly, there is no topic in Vanagon Essentials ~ The FAQ Guide that tells DIYers where to check for vacuum leaks in the engine.
Can we start one?
Here is my minor contribution:
Vacuum Hoses on 2.1L Vanagon
Vacuum hose that runs from ?? on the engine to the brake power booster runs under the Van
One hose to vapor emissions charcoal canister from top of air filter housing was deleted by VW and it is normal to see a plugged fitting there. |
Merian Samba Member
Merian Samba Member
Posted: Mon Oct 12, 2015 3:40 pm Post subject: |
from another thread:
deprivation wrote: |
I feel your pain. And the Bentley doesn't have a paragraph entitled "VACUUM LINES" Worse, if you have running issues people say "check all your vacuum connections" Great. Which ones? Where are they?
I can't speak directly to your question because I have a 2.1L '86 and I don't know how different that is from your ride. But I can tell you that it won't take but a foot or two - if you cut and measure carefully a foot will probably cover you but get more incase you screw up like I did.
On the 2.1, I found the following REPLACEABLE (non-plastic) vacuum lines:
1: between the intake plenum and fuel pressure regulator
2: between the throttle body and the line going to the evap valve
3: between the evap valve and the hard line (purple)
4: Plenum to brake booster check valve (this is not the 3.5mm - it's much bigger)
The only problem I had in replacing my 3.5 vacuum line was the connection between the plenum and the fuel press reg. The connectors are of different diameters. So I had to get a bit of slightly bigger hose for the pressure regulator and the usual 3.5 for the plenum. I bridged the the two different sizes of hose with a one-inch segment of aluminum tubing and silicone ATV. I don't know if you'll have the same problem or not.
Other vacuum-related connections to look at are the four intake sleeve between the plenum and the intake manifolds. I was doing a major engine clean-up and I soaked my rubber sleeves in Armor-All for a few days.
There is a possible source of leaks between the idle air control valve and the valve itself. There is a vacuum tube between the oil breather tower and the intake boot.
And there is the big intake boot itself. It has two big connections at the throttle body and the air box. I've read that the boots on the 1.9L engines are getting old and crappy. Some can be repaired with ATV and silicone tape. They are not making new ones so repair is the only option for most.
The injector seals can leak, too. Just to be safe I installed new seals and I coated the outside of the seals with a smear of hi-temp ATV just to be sure that I had a good seal.
The brake vacuum line is a mystery to me in terms of what can be replaced. Like I said, there is a replaceable bit of hose in the engine compartment and I honestly can’t say for sure if there is any other rubber along the way to the front of the van. I traced the line (you’ll have to remove the spare tire to do this) on up to the front floor and the peeked down into the dashboard and didn’t see any other rubber connections.
Does any of this help? I’m VERY new to Vanagons, but I am happy to share what little I know. |
mrcool Samba Member
Joined: April 01, 2015 Posts: 358 Location: Bozeman, MT
Posted: Fri Mar 04, 2016 3:14 pm Post subject: Re: Vacuum Leaks |
If you get a good fit to the nipple where vacuum hose goes, does it matter if it is 3.5mm vs 5mm? Or do you just need to make sure its air tight?
Why this question came up:
I am running a 2.0L Aircooled CV engine.
According to Parts base, the vaccum hose I need is 3.5mm... But the air intake nipple it goes on is bigger! I haven't measured it yet but 5mm hose fits ok.
Part #18 in this diagram.
http://www.partsbase.org/vw/vanagon-va-us-1983-27-overrun-air-system/ |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32367 Location: Reading Pennsylvania
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12102 Location: Port Manteau
Posted: Sat Mar 05, 2016 10:27 am Post subject: Re: Vacuum Leaks |
A list of point sources is fine for visual inspections, but these types of leaks often occur as tiny openings in junctions etc. Far more preferable would be to smoke them out or (safety nannies avert yer eyes) strategic blasts with starter/brake cleaner fluid. That way you can narrow it down to specific areas on the list _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Tue Mar 08, 2016 1:19 am Post subject: Re: Vacuum Leaks |
I would say the 3mm fabric covered hoses that join the plastic vacuum lines in the engine bay are a likely source of vacuum leaks. I replaced these with new original style hose a while ago and the hoses all cracked at the ends and became loose or came off altogether in a fairly short period. I have now replaced these with silicone hoses which will hopefully last better. _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
mrcool Samba Member
Posted: Tue Mar 08, 2016 10:16 am Post subject: Re: Vacuum Leaks |
I'm with you on that one Mellow.
My aircooled van was stalling all the time on startup. It isn't perfect yet but as I replace more and more of those 3.5mm vacuum hoses it gets better. I have a vacuum kit from german supply but the kit is so vague I don't know if it will have the hoses I really need like the aux air reg hoses. I also have some worn out rubber hoses on the way and the 4 air intake hoses.
Pretty much anything that is rubber is shot. |
xflyer Samba Member
Posted: Mon Jun 11, 2018 1:37 pm Post subject: Re: Vacuum Leaks |
The hose connecting the fuel pressure regulator to the intake plenum is a different size than all the other 'small' hoses in the engine area. It was 4.5mm IIRC and had red fabric on the outside to make it visually distinct from all the black hoses. Probably all the OEM hoses are gone by now.
I don't know if you can get that hose anymore. I think there is a American (inch) dimension hose that is the right size to fit, seal and not fall off or crack and split right away. See your FLAPS. _________________ 1989 Campmobile, 1984 7 passenger beater Vanagon
Both with cool A/C |
