Joined: January 01, 2007 Posts: 16802 Location: sticksville, ct.
Posted: Tue Nov 10, 2015 5:31 pm Post subject: |
if you need an engine on the road, junkyard one from the same (donor) model year, switch over the intake and go.
this is why it's so important to record the VIN of the donor.
for the most part, a 2.5 is a 2.5 is a 2.5, the engine management must stay the same. some were MAF, some were MAP etc etc, but the key is the intake. I can take any 2.5 on the planet and put my intake on top of it. 2.2/2.5 intakes are wildly different, but bolt up to 2.2/2.5 engines...
for example
my engine is a 2.5 block, 2.2 heads 2.2 engine management and intake with some tweeks to it (intake/fueling) to support my frankenengine
I had custom head gaskets made to my specs to adapt the 2.2 heads to the 2.5 block.
there are differences in head bolts between the 2.2/2.5 heads. so...mine is a mix of parts through several model years to make it work. unless I could service it till it dies or I croak, it would be unfair to sell what I built for myself to joe public based on the fact that a shop would tell you to pound sand should you bring it for service.
in my mind, it's important in these swaps to keep it "stock" Subaru so any issues can be resolved by doing diag for a 20xx forester/impreza (whatever your donor is)
basically, the way I wire these I tap in to the stock vw alt, oil pressure and the 15 feed to the coil...from those 3 points, the rest is Subaru. there is no real molestation of the factory vw wiring.
it makes for a pretty clean install. 1 big issue is the Subaru harness is about as flexible as a rock. there is a lot of wires in the bundle. _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Tcash Samba Member
Posted: Tue Nov 10, 2015 7:02 pm Post subject: Re: PUTT-N + Subaru= HAUL-N |
Sounds like you have a unique set up.
My thought was the turn around time and expense of putting in a short block versus a long block on the road.
Just a thought
Tcash |
Posted: Tue Nov 10, 2015 8:00 pm Post subject: Re: PUTT-N + Subaru= HAUL-N |
Tcash wrote: |
Just a thought
Tcash |
a junk yard engine would be install and go. would I do it? not without doing all the timing components. plus 90% of the cars in the junk yard have had either:
engine failure
transmission failure
if you can't hear it run, I would pass. my time is way to valuable to dick around with a gamble like that. imagine if dumpy's owners dragged some engine out of a yard, I got it all in and hit the key to find blown head gaskets, broken timing belt, rod knock etc....
by the way, I am in there at 0:29 _________________
Jake Raby wrote: |
Brian wrote: |
JeffRobenolt Samba Member
Joined: February 25, 2007 Posts: 1513 Location: Wisconsin
Posted: Tue Nov 10, 2015 8:50 pm Post subject: Re: PUTT-N + Subaru= HAUL-N |
Harness is ready!
_________________ --------------------------------------------------------
jfats808 wrote: |
Most, some, few is not all. You can always learn something from everyone , even the fool. |
Posted: Wed Nov 11, 2015 12:19 pm Post subject: Re: PUTT-N + Subaru= HAUL-N |
you are the man!! _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Wed Nov 11, 2015 7:26 pm Post subject: Re: PUTT-N + Subaru= HAUL-N |
well, finished dumpy up and their owners came to pick her up tonight. just got confirmation that they are home and happy....with the heat pumping on this cold November night....
so, I am sharpening my chisel and ax to start hacking away at PUTT-N
so, up until this point, I was making my own cooling pipes. by chance, I ran into an old friend at napa who has access to a pipe bender. it was a royal time consuming pain in the tic tac's to weld these up, so I had some bent up
well, ok....I had a lot bent up
let the good times roll....
I have a few things I can do to keep moving forward till the harness turns up and the heads get done...stay tuned _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Thu Nov 12, 2015 5:42 pm Post subject: Re: PUTT-N + Subaru= HAUL-N |
started in on the hanger
I really wish the RMW hanger worked out...it's a ton of work making these hangers. by the time you add up time and material it's in line with a RWM hanger. I would love to open a box and install said part, but that's not the way it works with these swaps...
tomorrow I hope to use the old engine to mock up the end plates and get those out of the way and get it ready for the real deal install. _________________
Jake Raby wrote: |
Brian wrote: |
BusPriest Samba Member
Joined: October 08, 2014 Posts: 420 Location: Denver, Co
Posted: Thu Nov 12, 2015 5:54 pm Post subject: Re: PUTT-N + Subaru= HAUL-N |
What about the rjes bar or the bus lab bar? _________________ 1977 Champagne Transporter Custom Camper.
SOHC EJ25, tubbed, wagenswest
Work in progress build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=619684
Not a Priest. |
Posted: Thu Nov 12, 2015 7:43 pm Post subject: Re: PUTT-N + Subaru= HAUL-N |
never seen bus labs, and RJES looks to mount the same way. I need to follow the inner frame rail to keep my pipes tight and out of the way. my bars mount on the out side of the frame rail leaving a bit of a pocket to accomplish this.
my cooling pipes barely hang below the pinch weld on the frame. thankfully I can get away with a smaller bar on the late buses due to the fact that the transmission is supported. early bays I use some pretty diesel stuff to hold the weight.
that's the early bay bar. just to be "trick" the mounts (plates with the 3 holes in them) tuck INSIDE my frame. it was kind of a bitch to do it that way so now I go on the outside of the rails. _________________
Jake Raby wrote: |
Brian wrote: |
captincanuck Samba Member
Joined: August 13, 2014 Posts: 730 Location: The Great White North
Posted: Thu Nov 12, 2015 8:36 pm Post subject: Re: PUTT-N + Subaru= HAUL-N |
Did you ever have a go at using the Subaru engine carrier? You already have it, and you only need to fabricate two small brackets to adapt it to mount to the frame rails. Might have the same problem as the RMW bar with it interfering with your cooling system thou. Only you would know for sure. _________________ 1979 Westfalia "FireFly" Subaru 2.2 with Subaru gears 5spd.
Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=634777&postdays=0&postorder=asc&start=0 |
Posted: Thu Nov 12, 2015 11:08 pm Post subject: Re: PUTT-N + Subaru= HAUL-N |
jfats808 wrote: |
Posted: Fri Nov 13, 2015 5:45 am Post subject: Re: PUTT-N + Subaru= HAUL-N |
captincanuck wrote: |
Did you ever have a go at using the Subaru engine carrier? You already have it, and you only need to fabricate two small brackets to adapt it to mount to the frame rails. Might have the same problem as the RMW bar with it interfering with your cooling system thou. Only you would know for sure. |
nope. it looks like crap. I haven't even bothered to mess with it. honestly it's just easier to build what I want rather than modify a piece that I wouldn't be happy with.
the bars are not really that hard to make just very time consuming welding them and plasma cutting all the bits
cool video jeff! that was dumpy's harness _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Fri Nov 13, 2015 8:22 am Post subject: Re: PUTT-N + Subaru= HAUL-N |
Whoops, here is the right video
jfats808 wrote: |
Posted: Fri Nov 20, 2015 11:27 am Post subject: Re: PUTT-N + Subaru= HAUL-N |
well, jeff got the harness back to me...and as usual his work is outstanding!
we decided to go ahead and paint the engine bay while she was all naked.
so, I went and color mapped the color on the bus. when she gets a full re-spray, at least the engine bay will be all dialed in
now before anyone gets all "the paint looks brighter" well, it does, as it's on a bright metal lid. using the right value shade primer will darken it up a bit, and paint darkens a bit when it dries....trussssst meee
got more stuff cleaned up
and test fitted the hanger using the old short block
so, now that I have the materials to paint, I will get that out of the way in the next few days. Subaru order due in Monday and still waiting on the heads to come back from the machine shop. radiator off at the shop getting modified as we speak _________________
Jake Raby wrote: |
Brian wrote: |
crownline Samba Member
Joined: September 10, 2010 Posts: 589 Location: Northwoods of WI
Posted: Fri Nov 20, 2015 12:20 pm Post subject: Re: PUTT-N + Subaru= HAUL-N |
Skills, you sure do great work with your setup. Very professional. I think I need to save my money for my 72 and talk the wife into it. After all she drives a WRX _________________ 1972 Bus 1700 cc Single Carb. But not a progressive.
Barelymuvin
Wish I still had the ones I got rid of.
"It"s got some dings and dents and neither of us is going to SEMA."(Update, I went to SEMA in 2019 but the Bus stayed home)
[url=http://www.vw-mplate.com/mplate-8446.png]Click to view image[/URL] |
Posted: Fri Nov 20, 2015 5:09 pm Post subject: Re: PUTT-N + Subaru= HAUL-N |
thanks I do my best to try and make these swaps go smoothly...no 2 swaps are ever the same.
so, I went to go remove the transmission today so I can get started on the clean up to get the bay/transmission hole painted.
as I was removing the axles, I hung my head in shame, muttered a f*ck me out of the corner of my mouth and just went for it....
we needed to re-boot the axles. anyone who has done this knows what a time consuming, messy messy messy nasty miserable low man on the totem pole job this is. especially picking the poop out of the bolt heads.
needless to say, I got 1 cleaned, blasted and pre greased
as I was pulling the other one and looked at the devastation the first one brought to my rags, solvent tank and 1/2 case of brake cleaner I didn't have it in me to rip the other one apart yet
but I did get all the bolts de-pooped and blasted
yuck...axles are just a train wreck mess of an operation... _________________
Jake Raby wrote: |
Brian wrote: |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12687 Location: on a bike ride somewhere
Posted: Fri Nov 20, 2015 6:41 pm Post subject: Re: PUTT-N + Subaru= HAUL-N |
Hire me for $15/hr and I'll do all the axles and bring you all the beer you need. And I can be a smart-ass online, so with a little training I could take care of a lot of bullshit as your proxy! _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Posted: Fri Nov 20, 2015 7:09 pm Post subject: Re: PUTT-N + Subaru= HAUL-N |
asiab3 wrote: |
Hire me for $15/hr and I'll do all the axles and bring you all the beer you need. And I can be a smart-ass online, so with a little training I could take care of a lot of bullshit as your proxy! |
when can you be here?
you know, your comment just gave me a very sad realization...
I am closer to 40 than I am 30. I have 1 kid and don't plan on another. she is awesome, and although I would NEVER wish my line of work on anyone your comment got me to thinking...
I have no one...zip, nada...that I can share my knowledge with. kind of depressing actually. when I was growing up if there was a hood up in the neighborhood, I was there. I had been known at a very early age to get a Christmas present and ask for a screw driver....those kids just don't exist anymore.
I look around at my daughters daycare and see the future...2 gang bangers, a potential terrorist, 3 trailer park princess's, andy dick, a janitor and the rest will just push paper for some company...none of the kids are even remotely interested in mechanical stuff. a sad reality that I have come to.
you wouldn't want to slum around here in CT when you have all that CA stuff you (can't) do _________________
Jake Raby wrote: |
Brian wrote: |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Fri Nov 20, 2015 7:16 pm Post subject: Re: PUTT-N + Subaru= HAUL-N |
I'll come out and work with you....I need to learn custom skills....got basic machnical down pretty good, so that'll save you some time _________________ Stuart Zickefoose
206-841-7324
[email protected] |
