nightcrawlr Samba Member
Joined: October 16, 2015 Posts: 24 Location: NE Texas
Posted: Sun Oct 18, 2015 12:58 pm Post subject: Sarah & Thomas 2000 Jetta GLS |
We will document the restoration of our 2000 Jetta GLS, goal is to make it a reliable daily driver. The car was a one owner vehicle, and has been garage kept. It is need of through cleaning and new engine. The original purchaser of the car said they took it to Wal-Mart for oil change and the oil never got installed. Needless to say the engine had a catastrophic failure.
Posted: Sun Oct 18, 2015 1:01 pm Post subject: Sarah & Thomas 2000 Jetta GLS |
The car is equipped with the 2.0 and manual 5 speed gearbox. Only has 101,684 original miles on the clock.
Posted: Sun Oct 18, 2015 2:41 pm Post subject: Sarah and Thomas 2000 Jetta GLS |
Hauling it home, my dad and brothers stopped by the LKQ Pick N Pull and harvested a replacement short block.
Posted: Sun Oct 18, 2015 2:49 pm Post subject: Sarah and Thomas 2000 Jetta GLS |
What a lack of lubrication (engine oil) looks like!
Posted: Sun Oct 18, 2015 2:54 pm Post subject: Sarah and Thomas 2000 Jetta GLS |
Off to LKQ Pick N Pull for more parts!
Left to Right, Dad, Me (Sarah), Seth, and Noah
Harvesting a passenger side mirror assembly.
Removing 2.0 head assembly.
Wow! It is a good head! |
Posted: Sun Oct 18, 2015 2:57 pm Post subject: Sarah and Thomas 2000 Jetta GLS |
Engine re-installation.
Head cleaned and ready for re-installation.
Posted: Mon Oct 19, 2015 11:03 pm Post subject: Sarah & Thomas 2000 Jetta GLS |
Dad, Seth, Micah and Noah got the head installed, next is radiator, radiator support, Oil, 5W-40, Filter PO-12, and G12 Antifreeze.
Posted: Fri Oct 23, 2015 11:53 pm Post subject: Sarah & Thomas 2000 Jetta GLS |
Thomas installing new battery and helping Seth with radiator support installation. Got the engine running, have a small leak where the metal tube seals into the block beside the thermostat housing. Will replace the o-ring and we should be done with engine installation.
cmarino929 Samba Member
Joined: August 16, 2009 Posts: 257 Location: Central NJ
Posted: Mon Oct 26, 2015 11:24 am Post subject: |
I have read all of your family's projects and you are def in good hands! Keep up the great work! |
Beetlebaum Samba Member
Joined: December 04, 2008 Posts: 2181 Location: Virginia Beach, VA
Stock Steve Samba Member
Joined: April 10, 2005 Posts: 1963 Location: My Left Nutmeg State
Posted: Wed Oct 28, 2015 10:31 pm Post subject: Sarah & Thomas 2000 Jetta GLS |
Thomas and Dad got a lot done on the car today. Drained and refilled with G12 coolant, installed new door pulls on all four doors, serviced the A/C system with R-134A, removed the headliner assembly and stripped and recovered it. Finally replaced a couple of bad bulbs. Took the car up the road to fill with gasoline. Thomas had the opportunity to take it on its first drive. Car ran great!
Thomas and Dad working on the headliner.
Headliner Installed!!!
Thomas backing it out of the garage. Look at that Jetta grin!
Filling the tank! |
Posted: Fri Oct 30, 2015 10:43 pm Post subject: Sarah & Thomas 2000 Jetta GLS |
Dad got the dash back together. Had to replace the climate control backlight bulb, took the center section of the dash apart (removed cup holder, storage pocket, radio and climate controls). When he could not figure out how the back lighting worked (typical man), he checked youtube. Simple process requiring the removal of the fan speed knob. It pays to research before removing fasteners!
Dash back together, all back lighting now working!
Dad then vacuumed the interior and cleaned all surfaces (detailed). Turned on the heater and A/C controls to make sure everything still worked after having it apart. Instantly the interior filled with small chunks of foam particles. Past experience told him this was from the blend doors. Time to take the dash all apart again!
Micah, my youngest brother helping Dad remove the dash.
Dash and heater core housing removed to get access to the blend doors.
Defective foam on the blend doors.
Self adhesive foam used to cover the blend doors.
Blend doors after covering with adhesive backed foam.
Blend doors being reinstalled into heater core housing.
Heater core assembly ready for re-installation. |
Posted: Sat Oct 31, 2015 7:14 am Post subject: Sarah & Thomas 2000 Jetta GLS |
cmarino929 wrote: |
Thanks! |
Posted: Sat Oct 31, 2015 7:17 am Post subject: Sarah & Thomas 2000 Jetta GLS |
Beetlebaum wrote: |
Nice! I've got a 2003 New Beetle--mechanically, pretty similar to yours, on the whole. Definitely following this thread. |
Sarah's Dad here, yes as best I can tell, the 2003 beetle is very similar in terms of chassis and drive-train, main difference being the body and interior. |
Posted: Sat Oct 31, 2015 7:18 am Post subject: Sarah & Thomas 2000 Jetta GLS |
Stock Steve wrote: |
Very cool! I'm impressed! Keep it up! |
Thanks for the encouragement! |
Posted: Tue Nov 03, 2015 7:08 pm Post subject: Re: Sarah & Thomas 2000 Jetta GLS |
nightcrawlr wrote: |
Beetlebaum wrote: |
I had the problem of the climate control knobs not lighting up on my New Beetle, and that fan knob proved really troublesome to pull out. Now that it's all fixed and has a new bulb in there, it's really nice to have all the dash lights working! _________________ 1973 Super Beetle
2003 New Beetle
Post your Super here: http://www.thesamba.com/vw/forum/viewtopic.php?t=331999
Beetle Bums VW Club Member |
Posted: Tue Nov 03, 2015 10:53 pm Post subject: Sarah & Thomas 2000 Jetta GLS |
Started working on the seats today. Dad and Mom and my brother Noah, cleaned, repaired, and conditioned the leather seats.
Mom and Dad cleaning and conditioning front seat.
Mom with finished seat, ready for installation.
Dad working on the drivers seat.
Dad and Noah replacing the airbag. Once installed, they used VagCom to check the SRS system and clear past faults. |
