epowell Samba Member
Joined: September 23, 2015 Posts: 4733 Location: Czech (mostly) Vancouver (sometimes)
Posted: Wed May 11, 2016 9:55 am Post subject: Re: 1.6 TD JX timing belt change / injector pump timing set |
ZsZ wrote: |
As above, or shorten the bolt.
Nice use of a bicycle seat clamp |
Yes... as it is now, it actually is not rubbing at all - but still, this really is too close, I agree.
Yeah! The bike seat clamp is a nice trick, eh? Nobody in town had, or could even ORDER such a clamp!! _________________ www.edwardpowell.com |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
Posted: Wed May 11, 2016 9:59 am Post subject: Re: 1.6 TD JX timing belt change / injector pump timing set |
epowell wrote: |
ZsZ wrote: |
Yeah! The bike seat clamp is a nice trick, eh? Nobody in town had, or could even ORDER such a clamp!! |
You do realize that if you should EVER sell this bus that the next owner will be cursing that cheap PO that used a bicycle clamp on the shift linkage! _________________ Dave O
The Western Syncro build
MidwestDrifter Samba Member
Joined: June 13, 2012 Posts: 769 Location: Kicking Around Australia
Posted: Wed May 11, 2016 10:04 am Post subject: Re: 1.6 TD JX timing belt change / injector pump timing set |
Nice Ghetto fix. A new bolt and you are good to go.
I had several such unsightly fixes on my van when I sold it. (I did disclose them though). Many of them are still rolling along. Some of those temp fixes ended up working so well, that I couldn't bring myself to screw with them. _________________ 2004 Dodge/Mercedes Sprinter (Custom Camper)
2000 Jetta TDI
1982 Diesel Westy W/ ABA I4 hybrid (Sold)
Epic Road Tripping since 08/05/12 | http://VagariesAbound.blogspot.com/
My Current Build | http://sprinter-source.com/forum/showthread.php?t=41215 |
Posted: Wed May 11, 2016 10:07 am Post subject: Re: 1.6 TD JX timing belt change / injector pump timing set |
dobryan wrote: |
You do realize that if you should EVER sell this bus that the next owner will be cursing that cheap PO that used a bicycle clamp on the shift linkage! |
I guess the reality is that with all of these buses, we are ALWAYS going to be finding fault with the PO.
Question about OIL:
My turbo return pipe is leaking more and more and more and getting rediculous... gotta do something. Either I will modify the old one, OR, it seems there is a machine shop right in our town that can fabricate a new custom one, for cheap. Either way I gotta do this...
So, I need to drop all of the oil to do this messy job - and I have brand new oil in there now. If I use a perfectly clean bucket and make absolutely certain no unwanted material gets into that oil, can I simply pour that oil back into the engine after the work is done?
Or.... should I simply wait until my next oil change to swap the turbo oil return pipe? _________________ www.edwardpowell.com |
Posted: Wed May 11, 2016 10:14 am Post subject: Re: 1.6 TD JX timing belt change / injector pump timing set |
MidwestDrifter wrote: |
Nice Ghetto fix. |
haha!
Well if you thought that was nice, what did you think of my Turbo to Block bracket? _________________ www.edwardpowell.com |
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1647 Location: Budapest Hungary, Europe
Posted: Wed May 11, 2016 11:14 am Post subject: Re: 1.6 TD JX timing belt change / injector pump timing set |
On my first trip I broke the oil pan in Albania. I let down the oil into plastic soda bottles that I cut off the top at the neck and filled it back.
So the clean container trick is doable _________________ Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008 |
Posted: Wed May 11, 2016 11:19 am Post subject: Re: 1.6 TD JX timing belt change / injector pump timing set |
Filtering through some fine cloth, screen, filter of some kind works. The oil is filter after the pump, so minor contamination is of minimal concern.
If your containers are really clean, they you likely won't need any filtration. Just make sure not to knock some crud off your engine into the bucket.
You might try jacking up that side of your van. Have a rubber plug on hand to put in the hole once you pull the hose out. I bet you will barely loose a quart if you are quick about it. _________________ 2004 Dodge/Mercedes Sprinter (Custom Camper)
2000 Jetta TDI
Posted: Wed May 11, 2016 11:38 am Post subject: Re: 1.6 TD JX timing belt change / injector pump timing set |
You might try jacking up that side of your van. Have a rubber plug on hand to put in the hole once you pull the hose out. I bet you will barely loose a quart if you are quick about it. |
Yeah that's an idea. The coffee filter idea also!
OK, you guys inspired me, I am going to get moving on this... I tired of LEAKS
[maybe one of these days I will get around to further fine tuning the engine!] _________________ www.edwardpowell.com |
Posted: Wed May 11, 2016 11:43 am Post subject: Re: 1.6 TD JX timing belt change / injector pump timing set |
epowell wrote: |
Nice Ghetto fix. |
haha!
Well if you thought that was nice, what did you think of my Turbo to Block bracket? |
I think that is a perfectly legitimate repair. I would have used flat and star washers, and pinch nuts. But that's about it. _________________ 2004 Dodge/Mercedes Sprinter (Custom Camper)
2000 Jetta TDI
Posted: Wed May 11, 2016 11:55 am Post subject: Re: 1.6 TD JX timing belt change / injector pump timing set |
Thanks ...but the thing is that it only attaches to ONE hole in the block - not two... so it is not as strong as it could be. But better than nothing for now - later I can tweek it.
flat and star washers, and pinch nuts. |
What are those??
BTW, regarding fixing the 'no reverse' issue... I twisted the forward linkage pipe to the right as far as it could go, and the rear pipe twisted to the left as far as it could go... still only giving me a changed spread of max 3mm (then could not twist anymore), and this fixed it. When I did not twist it that much, I got reverse back but no 1st gear! ...then the full twise and it all came back
ZsZ wrote: |
On my first trip I broke the oil pan in Albania. I let down the oil into plastic soda bottles...
Then what did you do???? Find a new oil pan down there? _________________ www.edwardpowell.com |
Posted: Wed May 11, 2016 12:06 pm Post subject: Re: 1.6 TD JX timing belt change / injector pump timing set |
epowell wrote: |
What are those??
Star/serrated washers are designed to prevent bolts from loosening, especially in high vibration environments.
For the bolts where you have a nut on the back side, use a flat washer under the bolt head, this will prevent the head from damaging the bracket when you tighten it.
For the nut I like to use pinch nuts; also called distorted thread lock nuts. These are both nuts which are designed to prevent loosening in high vibration environments. The thread is slightly squished at one end. This produces noticeable resistance to tightening/loosening.
2000 Jetta TDI
ZsZ Samba Member
Posted: Wed May 11, 2016 1:01 pm Post subject: Re: 1.6 TD JX timing belt change / injector pump timing set |
epowell wrote: |
ZsZ wrote: |
Then what did you do???? Find a new oil pan down there? |
Just hit a speedbump and cracked the oil pan. First I removed the pan and put silicone from inside. It solved the problem but i was not sure that it could make it home so I got the pan welded. After the welding it was worse so at home I got it patched. _________________ Zoltan
Posted: Wed May 11, 2016 1:24 pm Post subject: Re: 1.6 TD JX timing belt change / injector pump timing set |
ZsZ wrote: |
Just hit a speedbump and cracked the oil pan. |
Just an innocent speed bump??! Wow!
Thanks Midwest for these tips! _________________ www.edwardpowell.com |
ZsZ Samba Member
Posted: Wed May 11, 2016 1:54 pm Post subject: Re: 1.6 TD JX timing belt change / injector pump timing set |
We were 8 people fully packed down a slope where the bumps were not marked. Hit the 30kmh speedbump with 60kmh so the rear just touched the bump in the bouncing _________________ Zoltan
Posted: Wed May 11, 2016 2:02 pm Post subject: Re: 1.6 TD JX timing belt change / injector pump timing set |
ZsZ wrote: |
We were 8 people fully packed down a slope where the bumps were not marked. Hit the 30kmh speedbump with 60kmh so the rear just touched the bump in the bouncing |
oh! I can't wait to get to Albania! [actually, seriously yes I am! ...but I will remember this story ] _________________ www.edwardpowell.com |
Posted: Wed May 11, 2016 2:07 pm Post subject: Re: 1.6 TD JX timing belt change / injector pump timing set |
Reminds me of Mexico. Tons of unmarked, over-height topes (speed bumps) everywhere. For some reason they are always built in the shade which makes them nearly impossible to see!
I have watched big rigs potato-chip rims, crazy....
2000 Jetta TDI
Posted: Wed May 11, 2016 2:30 pm Post subject: Re: 1.6 TD JX timing belt change / injector pump timing set |
Do some people raise the suspension height of Vanagons? ...seems a good idea _________________ www.edwardpowell.com |
ZsZ Samba Member
Posted: Wed May 11, 2016 11:19 pm Post subject: Re: 1.6 TD JX timing belt change / injector pump timing set |
epowell wrote: |
Do some people raise the suspension height of Vanagons? ...seems a good idea |
It is a trend now. Everybody wants a Syncro alike
You can buy the Gowesty stuff from Campervanculture UK. _________________ Zoltan
Posted: Wed May 11, 2016 11:27 pm Post subject: Re: 1.6 TD JX timing belt change / injector pump timing set |
ZsZ wrote: |
It is a trend now. |
It's a good idea, no? However my high-top is already SO high, that with raised suspension it would be absurd (and wind-factor even more disturbing) _________________ www.edwardpowell.com |
