BadWeb Samba Member
Posted: Tue Oct 27, 2015 3:59 pm Post subject: Tire size on a 15X5" Wheel |
Has anyone mounted a 195/50/15 on a 5" wheel? Just wondering how anyone feels about this match. I have some Formula Vee wheels (I think) and would like to put that size on them.
Thanks in advance
Joe _________________ 1969 Beetle Standard. Owned since 1973. 1600 dual port, dual carbs. |
slalombuggy Samba Member
Posted: Tue Oct 27, 2015 5:56 pm Post subject: |
They'll fit, but your tire guy will hate you as they'll be a bitch to get on the rim and seated. That size tire should be mounted on a 6-7" rim.
brad |
BadWeb Samba Member
Posted: Tue Oct 27, 2015 7:58 pm Post subject: |
Thanks _________________ 1969 Beetle Standard. Owned since 1973. 1600 dual port, dual carbs. |
EVfun Samba Member
Posted: Tue Oct 27, 2015 9:24 pm Post subject: |
They look a little goofy on a 5.5 inch wheel. The short sidewalls are tucked inward. _________________
Wildthings wrote: |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Wed Oct 28, 2015 6:28 am Post subject: |
A 195X60 or 195X70 would look better & fill the fenderwell better than a 195X50. Looks like you have 60-70 Series tires on it now? 40-50 Series tires look like rubber bands.
_________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
911pickup Samba Member
Joined: March 06, 2004 Posts: 625 Location: Near Goats on the Roof
Posted: Wed Oct 28, 2015 8:10 am Post subject: |
I wouldn't recommend anything less than a six inch wide wheel. |
Posted: Wed Oct 28, 2015 9:24 am Post subject: |
I have some 185X60 on 4.5" stock wheels so I think he'll be okay with 195's on 5" wide aluminum wheels? He might find they are 5.5" wide when he takes the old tires off? I have 185X60 & 205X70 on 5.5" wide 2.0 liter Fuchs wheels. He does have flared fenders & lots of room for bigger tires & wheels! _________________ https://imgur.com/user/FisherSquareback/posts
BadWeb Samba Member
Posted: Wed Oct 28, 2015 9:48 am Post subject: Tire size on a 15X5" Wheel |
Thanks Mike. I did measure them and I believe they are 5.5" wheels. _________________ 1969 Beetle Standard. Owned since 1973. 1600 dual port, dual carbs. |
BadWeb Samba Member
Posted: Wed Oct 28, 2015 9:55 am Post subject: |
The tires mounted currently are 205/65/15.
Posted: Wed Oct 28, 2015 10:25 am Post subject: |
Well I would probably buy new 205X60-70 again. Why do you want smaller? We always want bigger! _________________ https://imgur.com/user/FisherSquareback/posts
BadWeb Samba Member
Posted: Wed Oct 28, 2015 4:23 pm Post subject: Tires |
I'm putting disc brakes and dropped spindles on so I was a little concerned about clearance. Eventually I want to get rid of the flared fenders. _________________ 1969 Beetle Standard. Owned since 1973. 1600 dual port, dual carbs. |
Bodacious Samba Member
Joined: October 01, 2015 Posts: 121 Location: Knoxville, TN
Posted: Sat Oct 31, 2015 9:10 pm Post subject: |
I just picked up some 185/55 15's for the front, and honestly I wish I would have went 60 on the sidewall. They are thinner than I thought they would look. But then again I like sum meats on my wheels. _________________ 1974 Standard Beetle
Baja Transformation in Progress
1600 DP ( 2110 in the works)
10A Rally Yellow
Daily Driver |
caddy man Samba Member
Posted: Sun Nov 01, 2015 10:47 am Post subject: |
I'm running a 195/65/15 on the rear, on a 5.5" wheel, and they have quite a bit of width and sidewall and fit really good.
ach60 Samba Member
Joined: May 14, 2001 Posts: 4139 Location: Santa Maria
Posted: Tue Nov 10, 2015 9:28 pm Post subject: |
[/quote]
No way I would get rid of the flared fenders on that car!
Just my opinion, but the car is a nice 70's period piece as is.
I'd look for wider wheels, like Fentons or Torque Thrust in 14 x 6, and 14 x 8. _________________ Good Luck
Al |
Posted: Wed Nov 11, 2015 2:44 pm Post subject: Re: Tires |
BadWeb wrote: |
I'm putting disc brakes and dropped spindles on so I was a little concerned about clearance. Eventually I want to get rid of the flared fenders. |
Show us a picture of it sitting on the garage floor. The disc brakes and dropped spindles come First, before the new tires &/or wheels. Keep the flares, so you can run bigger rather than smaller! _________________ https://imgur.com/user/FisherSquareback/posts
