Dubfreak1 Samba Member
Joined: March 12, 2005 Posts: 29 Location: Zeeland, MI 49464
Posted: Thu Oct 29, 2015 3:14 pm Post subject: 36hp cam and pushrod/lifter question |
Would there be a problem moving a cam and the pushrod/lifter assemblies to a different crankcase? All the lifters will be on the same lobes as they were originally. I am concerned that differences in the machining of the two crankcases could cause excessive wear if the lifters don't meet the cam lobes exactly the same way. Anyone have experience doing this? Thanks. |
TomSimon Samba Member
Posted: Thu Oct 29, 2015 4:03 pm Post subject: |
I've swapped cams and lifters around on T1 engines, as is sometimes necessary, but I treat it like a new build, and 'break in the cam' upon start up. I've not done this on a 36hp, but so long as the wear faces of both lifter and cam lobe aren't galled or pitted, you should be ok. Particularly with the light valve spring pressures in the 36hp engine.
New lifters can be had for $100 these days
http://www.aircooledresearch.com/docs/parts_cam_followers.html _________________ 2-time NASA Pro Racing Champion, Bonneville 130 Club and 150 Club Memeber, BRS Pro Gas racer |
Mr. Motorhead Mad Scientist
Joined: January 06, 2004 Posts: 717 Location: Practitioner of 36hp alchemy
Posted: Mon Nov 02, 2015 4:15 pm Post subject: 36hp cam and lifter |
Thanks for the input. It makes sense that the 36hp would have less of a problem than the later type I motors and this is done frequently. I'd still like to hear from someone that moved the parts in a 36hp and how it worked out |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Mon Nov 02, 2015 4:31 pm Post subject: |
I have done it several times in my engine coaxing more miles out of it with no problems for me. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Fri Nov 20, 2015 6:20 pm Post subject: Re: 36hp cam and pushrod/lifter question |
Decided to send my cam to Matthew to get reground to stock specs. This is for a Stone Stock 36 land speed effort, so I didn't want to give up any lift from even the lightly worn cam. |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Mon Nov 23, 2015 6:33 am Post subject: |
Let me know when your new lifters come in! I'd still like you to make me a set with the 3mm inserts from WW.
Email or call me
Mr. Motorhead wrote: |
Currently out of stock, I have some coming in about a week. I've be doing regrind German lifters to fill the need. |
