What year is this split beetle speedo pod? is it barndoor?
vintage fiberglass
vintage fiberglass is offline
PostPosted: Sat Oct 31, 2015 6:36 pm    Post subject: What year is this split beetle speedo pod? is it barndoor? Reply with quote
I got this older split speedo pod for a standard split? or so I think. It has a L part number on the back as you see in the picture. The key code is odd?? like HU and so is the key (maybe after market)? Is this a 1949? or 1950?
Bruce
Bruce is offline
PostPosted: Sat Oct 31, 2015 7:05 pm    Post subject: Reply with quote
Turn your lights on.
Retrovan
Retrovan is offline
PostPosted: Sun Nov 01, 2015 7:13 am    Post subject: Reply with quote
Not sure, is from a STD model
If you do not need it, I would be interested to buy it for my Split.
PM me and we can talk.
Herman
1968 Fastback Type 4 2 Lt. twin 34 ICT's (Red)
1952 Split Beetle 1835cc. twin 34 ICT's (Azur blue)
1975 Split Bus Type 4 1914cc. twin 34 ICT's (wh/aqua)
1972 Bay Panel-van with type 4 2 Lt. twin 34 ICT's (white)
2019 Beetle Flatbed Truck called MeFusco
1973 FT Hahn SP - Project 1776cc
usariemen
usariemen is offline
PostPosted: Sun Nov 01, 2015 10:33 am    Post subject: Reply with quote
If you make a better pic of the whole rear side, I am sure here are people around wich are able to tell you if that is bus or beetle.
And if you suspect it to be bus you might better ask in the bus forum?
Master of my domain!
johnshenry Premium Member
johnshenry is offline
PostPosted: Sun Nov 01, 2015 9:12 pm    Post subject: Reply with quote
There is usually a date code stamped on the ground fork. I can see just bit of it on the right side in one of your pics. Being that it is on the right, it is a '49 and later pod.
Some pods (rare ones) don't have date codes on the ground fork.
John Henry
'57 Deluxe
'56 Single Cab
PostPosted: Sun Nov 01, 2015 9:13 pm    Post subject: Reply with quote
Also, looks like a P profile key, not an A profile, but it could have been changed out....
John Henry
'57 Deluxe
'56 Single Cab
Hebster52
Hebster52 is offline
PostPosted: Fri Nov 06, 2015 6:40 am    Post subject: Reply with quote
50 or later standard pod or Barndoor pod.
~Kris~
The Hebster52
The 912ST
The KidVRod project
The 356 Pre-A replica,SOLD
The 1966 Kommanderwagen, SOLD
The Doppel -67, SOLD
The Singlecab -72, SOLD
