Bodacious Samba Member
Joined: October 01, 2015 Posts: 121 Location: Knoxville, TN
Posted: Sat Oct 31, 2015 9:08 pm Post subject: Wheel and Suspension Fitment |
Hey guys, I started a thread in the 68 plus section. I am looking for some specifics on setting up the "German look" on my car. Is there a good link where I can find pics with wheel and tire diameter and offsets? Plus suspension setups? _________________ 1974 Standard Beetle
Baja Transformation in Progress
1600 DP ( 2110 in the works)
10A Rally Yellow
Daily Driver |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sat Oct 31, 2015 10:11 pm Post subject: |
97 pages of different wheel/tire/suspension setups here. You ought to be able to find something you like.
http://www.thesamba.com/vw/forum/viewtopic.php?t=247735 _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Sun Nov 01, 2015 9:17 am Post subject: |
Thanks for that link. That helps me out quite a bit. I am going to look into some Chevy adapters for my 4 lugs and probably a 16" wheel. Right now my car is setting on the bump stops in the back and has 2.5" drop spindles in the front (bought it that way). I absolutely loath the ride, it's terrible. I will more than likely move the rear to almost stock height and stay with just the drop spindles in the front. Thanks again. _________________ 1974 Standard Beetle
10A Rally Yellow
Daily Driver |
lolight70 Samba Member
Joined: August 22, 2013 Posts: 160 Location: West Australia
Posted: Sun Nov 01, 2015 5:17 pm Post subject: b |
Just remove the bump stop rubbers and see if that helps.
I lowered my 65 bug 1 outer spline and it sat on the stops,
removed them and all is well,didnt drop any further. |
