DeKazman Samba Member
Posted: Fri Nov 06, 2015 9:57 pm Post subject: Ever remove a Rear view mirror? |
The po mounted (with some kind of glue) a rear view mirror on the windshield of my Ghia.
I saw a youtube vid where a guy heated the metal 'button' with a lighter until the glue melted and the button dropped off.
The only thing: the windshield he was working with was already broken.
So I have no idea if the heat will crack the windshield.
Anybody ever do this? Remove a mirror off a windshield? |
Keith Samba Member
Joined: August 15, 2005 Posts: 3634 Location: Brodheadsville, PA
Posted: Sat Nov 07, 2015 10:34 pm Post subject: |
Razor blade, I used to have to remove the glue on mirrors sometimes at the dealership. I would heat the razor blade with my butane torch and then slide it between the button and the glass, slowly pushing it in until it didn't want to slide anymore and then I would take it out and reheat the blade and go at a different side and repeat until the button came off.
I should note that I used the razor blade scraper that we often used for removing inspection stickers or prepping gasket areas. _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
Posted: Sun Nov 08, 2015 8:24 am Post subject: Thanks |
I'll give that a try! |
