Jrb572 Samba Member
Joined: August 30, 2013 Posts: 191 Location: St. Louis
Bruce Samba Member
Joined: May 16, 2003 Posts: 17285 Location: Left coast, Canada
Posted: Sat Nov 07, 2015 12:18 am Post subject: |
That's the wrong pulley for your engine. If you use this one, it will slow your cooling fan since it is smaller.
If you need a pulley, search the classifieds here on the Samba. _________________
Jrb572 Samba Member
Posted: Sat Nov 07, 2015 6:42 am Post subject: |
Yeah I already did that and got one that was messed up. Now I need to find another one. |
rud helsen Samba Member
Joined: July 14, 2009 Posts: 323 Location: Belgium, Heist op den Berg
Posted: Sat Nov 07, 2015 12:40 pm Post subject: |
Jrb572 wrote: |
I have got a spare NOS one.
If you're interested let me know! |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14576 Location: 18 miles North of the border
Jrb572 Samba Member
Posted: Sat Nov 07, 2015 3:30 pm Post subject: |
I ordered one. We will have to see how it compares when it arrives. It has to be better than this dented one I have now. |
Bruce Samba Member
Posted: Sat Nov 07, 2015 4:38 pm Post subject: |
RareAir wrote: |
From reading the ad link, it looks to be a regular sized pulley
What Bruce is describing is a power pulley. much smaller in diameter. |
No, the new one John sells is a 40hp-1600 size pulley. They are smaller in diameter than a 25-36hp pulley.
Using a 1600 size pulley slows the cooling fan making the engine run hotter. = bad idea. _________________
Snort Samba Member
Joined: April 02, 2005 Posts: 1957 Location: Seattle, WA
Posted: Sat Nov 07, 2015 6:09 pm Post subject: |
Just think of it as a winter pulley. You're going to also have to play around with different sized fan belts to find one that fits. Keep looking for the correct pulley and you should be able to get set up properly before summer comes. |
Jrb572 Samba Member
Posted: Sun Nov 08, 2015 6:50 am Post subject: |
Then they should not state it works for a 1200 on there site. |
Jrb572 Samba Member
Posted: Sun Nov 08, 2015 7:12 am Post subject: |
I emailed them about canceling my order if the pulley size didn't match mine. |
Ben Dover Banned
Joined: March 02, 2014 Posts: 92 Location: Charleston
Posted: Sun Nov 08, 2015 8:24 am Post subject: |
A 36hp is NOT a 1200. You said your pulley is bent;straighten it. |
Bruce Samba Member
Posted: Sun Nov 08, 2015 3:47 pm Post subject: |
Jrb572 wrote: |
It is correct for a 61-65 40-hp, 1200cc engine.
Ben Dover wrote: |
The 36hp engine is exactly 1192ccs, or in advertising, 1200. _________________
EVfun Samba Member
Posted: Sun Nov 08, 2015 4:40 pm Post subject: |
There are 2, 1200 cc motors. Both have a 77 mm bore. Both have a 64 mm stroke. Both are air cooled. That is pretty much all they have in common. _________________
Wildthings wrote: |
Jrb572 Samba Member
Posted: Sun Nov 08, 2015 5:29 pm Post subject: |
They cancelled my order no problem. I have one place here to call locally so I can go see it in person. |
Ben Dover Banned
Posted: Sun Nov 08, 2015 5:48 pm Post subject: |
I understand that Bruce,but every advertiser calls the 36 horse a 36 horse and the 40 horse a 1200. |
56Cabrio Samba Member
Joined: May 22, 2008 Posts: 1899 Location: San Fernando Valley, CA
Jrb572 Samba Member
Posted: Tue Nov 10, 2015 6:14 pm Post subject: Re: Will this pulley work |
I seen that and ordered one from him along with an intake. Thanks for sharing it though. |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Tue Nov 10, 2015 7:10 pm Post subject: Re: Will this pulley work |
I see that you already cancelled, but that pulley would have worked just fine.
The size difference is minimal. 36 hp engines run cold anyways.
I've been running a 1600cc pulley on my 36hp for a couple of years now. I had to switch due to running a machined in sand seal. My 36hp also runs higher compression, ported/polished heads, and larger valves, etc. Engine still runs cold, and even did when I was running my speedwell blower.
A good used 36hp pulley is great too, but you would have been fine.
Original belt works with 1600cc pulley as well...you just need to adjust slightly with generator pulley washers(as designed). |
