gfarn1 Samba Member
Joined: November 10, 2015 Posts: 16 Location: Willoughby, OH
Posted: Tue Nov 10, 2015 12:03 pm Post subject: Upper Engine Mounting Bolts |
Please help! I am going nuts trying to figure this out!
I am trying to remove the engine from my 1966 bus (which actually have a 72 Beetle engine, but I don't think that should matter for this).
Everything has been completed to take the engine out (e.g. generator wires, fuel line, lower mounting bolts, etc), except the drivers side upper mounting bolt. My problem is that it's not really a bolt that can be removed (see photos). The last photo is not from my bus but seems to provide a better view of what I think I'm dealing with (?).
Yes, I tried a search first and was at least able to find out either:
1. there may only be 3 mounting bolts instead of 4
2. I may need a "Captive nut for top left engine mounting bolt" (https://www.vwheritage.com/shop/111101135/captive-nut-for-twinport-case/)
Any and all advice is GREATLY appreciated!
Thank you!
Greg |
Z Samba Member
Joined: June 15, 2003 Posts: 2517 Location: galveston, tx
Posted: Tue Nov 10, 2015 12:08 pm Post subject: |
What you're seeing IS a captive nut. Look on the other side of it. |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
gfarn1 Samba Member
Posted: Tue Nov 10, 2015 12:16 pm Post subject: |
Thank you!
Yes I do have a jack under it. It seems to be hung up only on that upper drivers side corner.
I will try to get to it from the other side, but that didn't seem possible, at least coming from the top. |
coolerthanelvis Samba Member
Joined: June 30, 2003 Posts: 924 Location: San Diego, CA
Posted: Tue Nov 10, 2015 4:12 pm Post subject: |
You will need a 17mm socket, wobbly extension, long extension, 3/8" drive ratchet.
Crawl under the bus and determine if your clutch throw-out arm is straight (pointing straight up) or curved (leaning toward the tranny). If it's curved, it is right in front of the bolt that you need to take out. Put the socket with the wobbly extension on the bolt and try to find a good angle to get the other extension and ratchet on. If your throw-out arm is straight, it's easier, but not really easy, to get to the bolt. Good luck! _________________ Shawn
SV2s member #420
'68 Westy
"Do or do not, there is no try."
-Silent Bob |
Tyler 5447 Samba Member
Posted: Tue Nov 10, 2015 5:40 pm Post subject: |
coolerthanelvis wrote: |
Crawl under the bus and determine if your clutch throw-out arm is straight (pointing straight up) or curved (leaning toward the tranny). If it's curved, it is right in front of the bolt that you need to take out. Put the socket with the wobbly extension on the bolt and try to find a good angle to get the other extension and ratchet on. If your throw-out arm is straight, it's easier, but not really easy, to get to the bolt. Good luck! |
I have a thin walled wobbly socket that makes life much easier when working with that bolt. |
dlicious Samba Member
Joined: September 07, 2006 Posts: 245 Location: Spring(pronounced Sprang), TX
Posted: Tue Nov 10, 2015 7:07 pm Post subject: Re: Upper Engine Mounting Bolts |
I remove the heater box from that side when I pull the motor. I can then get a box wrench on it easy. _________________ '63 Caravelle Camper
dLk |
Posted: Tue Nov 10, 2015 7:39 pm Post subject: Re: Upper Engine Mounting Bolts |
dlicious wrote: |
I remove the heater box from that side when I pull the motor. I can then get a box wrench on it easy. |
I wish I would have thought of that last time I pulled a motor in a parking lot on a road trip. |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Tue Nov 10, 2015 7:44 pm Post subject: |
Tyler 5447 wrote: |
2x
With a 18"-24" extension |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76938 Location: Sneaking up behind you
Posted: Tue Nov 10, 2015 7:47 pm Post subject: Re: Upper Engine Mounting Bolts |
17mm swivel socket on a 24" extension.
Or use a M10x70 bolt with a Allen head.
_________________ Glenn
Member #1009
#BlueSquare |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Tue Nov 10, 2015 7:54 pm Post subject: Re: Upper Engine Mounting Bolts |
Glenn wrote: |
Or use a M10x70 bolt with a Allen head. |
This is what every VW I have gets when an engine goes back in.
Or...
kevhum wrote: |
found this one on another thread
_________________ nothing |
Posted: Tue Nov 10, 2015 7:57 pm Post subject: |
^^^ This is how it is done. A complete and utter pain in the ass at times, but this is just how things are sometimes.
Switch to that allen head bolt upon reinstalling the engine and don't look back. Plus, the allen head makes your engine less theft prone. Less of an issue these days but a nice comfy feeling nonetheless. _________________ nothing |
Posted: Tue Nov 10, 2015 7:57 pm Post subject: Re: Upper Engine Mounting Bolts |
Glenn wrote: |
Damn, that's a good idea too. |
Posted: Tue Nov 10, 2015 8:00 pm Post subject: Re: Upper Engine Mounting Bolts |
Tyler 5447 wrote: |
Glenn wrote: |
Yep.
Here's my setup.
Glenn Mr. 010
Posted: Tue Nov 10, 2015 8:18 pm Post subject: |
cdennisg wrote: |
Plus, the allen head makes your engine less theft prone. |
Good luck stealing my engine, you better have a few hours.
Dual carbs, remote filter and large tube headers in a bug. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Nov 10, 2015 8:27 pm Post subject: |
Glenn wrote: |
cdennisg wrote: |
Dual carbs, remote filter and large tube headers in a bug. |
You know what I meant. _________________ nothing |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Wed Nov 11, 2015 9:47 am Post subject: Re: Upper Engine Mounting Bolts |
You guys run a husky washer against the allen? |
gfarn1 Samba Member
Posted: Wed Nov 11, 2015 10:03 am Post subject: Re: Upper Engine Mounting Bolts |
Thank you everyone for the fantastic tips! With your wonderful expertise and a bit of arm contortion, I successfully got the motor out. Thank you as well for the allen bolt suggestion for the re-install. Good stuff!
Kindly,
Greg |
scottvw Samba Member
Joined: November 17, 2004 Posts: 2821 Location: Centennial, CO
Posted: Wed Nov 11, 2015 10:11 am Post subject: Re: Upper Engine Mounting Bolts |
I had a nut welded to the bolt to give it a little more to grab on to |
Z Samba Member
Posted: Wed Nov 11, 2015 4:27 pm Post subject: Re: Upper Engine Mounting Bolts |
gfarn1 wrote: |
Kindly,
Greg |
Congrats...when your arm heals from the 3 breaks required to remove that bolt, you can get back to working on your bus! |
