coopster Samba Member
Joined: March 26, 2005 Posts: 54 Location: Glasgow,Scotland, United Kingdom
joghia Samba Member
Joined: March 12, 2008 Posts: 87 Location: ANTWERP BELGIUM
Posted: Mon Nov 23, 2015 7:08 am Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... |
thanks ! working on a leed in holland now, ...
if this is nothing , i'll try him, there are many doors and fenders out here in belgium, but almost all of them are rusted, dented or full of bondo... |
joghia Samba Member
Posted: Wed Nov 25, 2015 12:58 am Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... |
yes front left fender and 2 left doors found ! picking them up this evening !
now i only need a left rear fender !
i have a spare one, but this one weighs 3 times more than an untouched one i guess
welded a few times and some sort of bondo/resin /polyester on it...
pics will follow ! |
joghia Samba Member
Posted: Mon Nov 30, 2015 2:13 am Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... |
finally found some nice doors without rust... now i have a set of 4, altough 1 is damaged on the inside huge dents, but it is what it is,
i put some filler on all 4 of them (not much) they 're pretty straight now,
181 bundeswehr straight
and they are ready to be painted in and outside now ! |
joghia Samba Member
Posted: Mon Nov 30, 2015 2:25 am Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... |
now the tricky part, i found a left fender for 30 euros, this was pretty banged up, we used a fire torch to beat the corner back in,, but it still needed a lot of banging and 'filler/bondo.....
then i came home and found a really dumb mistake i made, ...
seems that there are 2 different model fenders out there
small an large side repeater ( as in euro and american style ?)
my right one was og bundeswehr and had a small one and my new donor fender has a bigger bump for the front blinker.
so my " new " fender was cut up, and i managed to cut the right side indicator 'bump' out of my old fender, out with the old and in with the new
after that surgery i found a nice healthy spot in an other fender i had, so i cut the corner out of that one and inserted it to the heavily damaged one i was trying to fix.
so i managed to make 1 fender out of 3 !
a saturday spend on nothing more then that !
now all we need is filler, but i was hungry and tired, and dirty, and so i left it there in the cold.....
tomorrow another day of sanding and putting filler on,.... almost there with the 'new' parts, then it's on to the old body............
joghia Samba Member
Posted: Mon Nov 30, 2015 2:33 am Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... |
also my lightbowl ? was pretty rotten in the 'new' fender
thanks to some previous dodgy repairwork on my old car, i managed to save this one !!
it was only in there with silicone !
nice !
gotta love the p.o. dodgy repairs !
i peeled the fender of ! like a rotten banana !
nice score ! |
joghia Samba Member
Posted: Mon Dec 07, 2015 2:38 am Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... |
so here we are, sanded the inside and sprayed the red on it ..
also the doors insides were done
el_safari Samba Member
Joined: January 01, 2005 Posts: 375 Location: Nouvelle Aquitaine,France
Posted: Mon Dec 07, 2015 3:01 am Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... |
Hi
Did you choose what colour ? _________________ La terre n'est qu'un seul pays |
joghia Samba Member
Posted: Mon Dec 07, 2015 7:22 am Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... |
no, i am still choosing between 7016 and 7021 ral,
i like the 7021 stumpf panzergrau, but i leek it a bit worn, so a little brighter would be perfect,
right now it's only first coat of base paint (red menie) ish
here are a few pics of my 181 as it sits now waitng for the new body....
joghia Samba Member
Posted: Mon Dec 07, 2015 7:29 am Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... |
sad to let her go, but she will almost be as new as she left the factory soon
joghia Samba Member
Posted: Mon Dec 07, 2015 7:31 am Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... |
these pictures don't do her justice, she is in fact far worse !
every panel is rotten and filled with filler, even the insides are bad,
i think this bodyshell is beyond repair ! you tell me ! |
ente_kaefer Samba Member
Joined: August 22, 2013 Posts: 242 Location: St Louis, MO
Posted: Mon Dec 07, 2015 8:10 am Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... |
joghia wrote: |
img] |
Those 'black out' lights on the front bumper would look great on my car, on the off chance you want to not use them . . . |
joghia Samba Member
Posted: Fri Dec 11, 2015 2:59 am Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... |
the front black out ligths are also unrestorable, they are too far gone, when i sandblast themwith the softest sand there will be nothing left of them... even the insides are too far gone i believe,
i'm sure you can find a good usuable pair on the ebay.de site in germany ! they aren't that expensive in a good shape |
joghia Samba Member
Posted: Fri Dec 11, 2015 3:01 am Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... |
getting ready to 'pull' the body off ... if i get some help, this thing is rotted but still heavy, i'll have to cut the body off with the bottom plates, they are all welded together...... |
joghia Samba Member
Posted: Tue Dec 22, 2015 3:19 am Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... |
finally this weekend we had some time to pull te old rotten body off, it took a whole lot of elbow greas, but we did it !
the pans look like theyr are gonna fit quite good actually, we'll see if we get there ,
now on to the other side, the left pan needs to come out, also am looking for better usable seat rails, because mine are not so good any more... |
joghia Samba Member
Posted: Tue Dec 22, 2015 3:24 am Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... |
even the tunnel needs a bit of tlc.............. |
Posted: Tue Dec 22, 2015 4:35 am Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... |
Hello Joghia
The seat rails from 181 are different from the one from bug .
It works also but the driving position is different .
What is the year of your 181 ?
Bonnes fêtes à tous ! _________________ La terre n'est qu'un seul pays |
joghia Samba Member
Posted: Wed Dec 23, 2015 3:02 am Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... |
will check that later, i know they are different, there is also a chance that i can save them, the fronts are good, but thse sides need some welding.., i am also looking to 'lower' my seats a little, not sure about that !, but i like the lowered look in the car also
in the mean time my ordered paint from germany is on it's way !
ral 7021 panzergrau stumpfmatt
i am hoping that it will arrive shortly, so i can spend my holidays with my car in stead of the family
the temperatures here are almost too good to be true, so fingers crossed !
next up more welding ... |
joghia Samba Member
Posted: Mon Dec 28, 2015 6:07 am Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... |
painted the gastank,
left and right pan were completely wirebrushed to get the 'transport' coat of
(almost done with that, 1 is allready painted in rot-braun anti rust base.
also cleaned the tunnel edges .. need to clean the chassis even more, man this is a job that has taken all christmas days and evenings...
no party for me yet |
joghia Samba Member
Posted: Tue Dec 29, 2015 2:03 am Post subject: Re: my 181 bundeswehr olf friend, time to do a body swap ... |
this evening i finally finished my second pan , completely wirebrushed it , to get rid of the factory shitty paint and put some good 'rotbraun' on it !
now the 2 pans are ready to be fitted.
next up : remove frontaxle, remove transmission and small parts, so i can completely paint the frame and tunnel in rotbraun, then fit the pans , this is gonna be tricky, i need some help to put the body on and off for exact fitment,
also i have a fitment issue with my left front door, gonna tackle that this tomorrow, a bit of 'tweeking' , some wood and muscles ....
