richierich Samba Member
Posted: Sat Nov 14, 2015 4:29 pm Post subject: 56 bug rear torsion bars question |
Hi all - I hope someone can help me with this.
I have a 56 bug. The rear has been lowered and sits slightly higher on one side so today i pulled the lower side apart to rectify and level things up. I was suprised that these earlier swing axle rear ends have the 'snout' which sticks through the spring plate cover on the outer ends of the torsion bars - see pic of mine below.
When i pulled the torsion bar it came out from the middle - so i had to turn it one inner spline which has proved to be too much because now it sits higher than the other side.
My question is, do these earlier torsion bars have splines both inner and outer like the later bugs? _________________ Blah..... |
Bruce Samba Member
Posted: Sat Nov 14, 2015 4:40 pm Post subject: Re: 56 bug rear torsion bars question |
Yes, exactly the same spline count, both inner and outer. _________________
Posted: Sat Nov 14, 2015 4:44 pm Post subject: Re: 56 bug rear torsion bars question |
Thanks Bruce - so on these then one inner should be the same drop as one outer? _________________ Blah..... |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Sat Nov 14, 2015 6:51 pm Post subject: Re: 56 bug rear torsion bars question |
richierich wrote: |
Thanks Bruce - so on these then one inner should be the same drop as one outer? |
I don't think that that is what Bruce means . . .
You wanted to say this, right Bruce?
Bruce wrote: |
Yes, exactly the same spline count as later torsion bars . . . inner and outer are different. |
_________________ Jesucristo es mi Seņor y Salvador! |
Bruce Samba Member
Posted: Sat Nov 14, 2015 11:57 pm Post subject: Re: 56 bug rear torsion bars question |
richierich wrote: |
My question is, do these earlier torsion bars have splines both inner and outer like the later bugs? |
Bruce wrote: |
Yes, exactly the same spline count, both inner and outer. |
My answer was that the spline counts were the same as later cars. Both inner and outer (are the same as later cars). I didn't want to say the inner count was different from the outer because that's not what he asked initially. _________________
Posted: Sun Nov 15, 2015 2:27 am Post subject: Re: 56 bug rear torsion bars question |
Thanks fellas but just to clear up confusion i guess i should have asked - are there splines both ends and are there the same number of splines both ends? Look a bit different to later ones which is what i'm more used to _________________ Blah..... |
Kjell Roar Samba Member
Joined: December 08, 2008 Posts: 1326 Location: Norway
Posted: Sun Nov 15, 2015 3:37 am Post subject: Re: 56 bug rear torsion bars question |
richierich wrote: |
Thanks fellas but just to clear up confusion i guess i should have asked - are there splines both ends and are there the same number of splines both ends? Look a bit different to later ones which is what i'm more used to |
They have different number of splines in each end of the torsion bar , so it is possible to adjust the ride height properly. Its a table who tells how to do it. _________________ I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438 |
