PUMA Coupe car cover
wagenbits
wagenbits is offline
PostPosted: Mon Nov 16, 2015 6:44 pm    Post subject: PUMA Coupe car cover Reply with quote
Has anyone found a car cover that actually fits the shape of a PUMA GTI Coupe, without resorting to a full-custom cover?
If so, what make and model car is that cover originally for?
Sadly, my 1981 GTI will be living outside this winter!
Thanks much for any information.
Letterman7
Letterman7 is offline
PostPosted: Mon Nov 16, 2015 6:59 pm    Post subject: Re: PUMA Coupe car cover Reply with quote
While not the same shape, it's the same size - try a Sterling cover from California Car Covers. You'll have to call them and give them the part number - #2075. You'll have to choose your fabrics from their online store, but you'll have to call for the cover since it's no longer listed online.
SBD
SBD is offline
PostPosted: Tue Nov 17, 2015 7:19 am    Post subject: Re: PUMA Coupe car cover Reply with quote
Just a suggestion... You might look at a cover for a Datsun 240Z. Not sure if it's the same size but the shape is similar. Could be worth investigating. If the cover is too small, the Datsun's got progressively larger with the newer models, just like Detroit did with their cars. Cool
"Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote:
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it.
