Chevy432 Samba Member
Posted: Tue Nov 17, 2015 10:19 am Post subject: New brakes needed for VW rabbit |
Just got my winter tires put on my car and tire shop says I need new brakes because I have around 1mm left on my right front tire. I'm in university and don't have all that much money, where do I even look for brakes for my car and how much should I budget for on this?
Thanks,Trevor |
Joined: August 31, 2013 Posts: 12860 Location: North Carolina
Posted: Tue Nov 17, 2015 3:33 pm Post subject: Re: New brakes needed for VW rabbit |
What year/model is your car? You can probably get the parts from your local parts store for $75 for pads & rotors.
If you have a 81-84 rabbit, get pads & rotors for a 83/4 GTI, you'll get vented rotors for better braking performance. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Thu Nov 19, 2015 1:43 am Post subject: Re: New brakes needed for VW rabbit |
Mine is a 1980 VW Rabbit. The report says my front left pad/shoe is at 1mm and my front right pad/shoe is at 3mm. Why is one wearing more then the other? |
Old n' slow Samba Member
Joined: October 29, 2012 Posts: 619 Location: Western Maryland
Posted: Thu Nov 19, 2015 6:52 am Post subject: Re: New brakes needed for VW rabbit |
Chevy432 wrote: |
...one piston slightly sticking causing drag, one rotor rougher than the other ??
nothing to worry about as long as it stops straight and one side is not overheating.
If really on a tight budget go to ebay buy new pads for $10 delivered, put them on and drive it. _________________ Currently own : 1969 Beetle w/ 1600cc, Single Port, Solex 30 PICT 2, Dist. 113 905 205 T, stock exhaust.
All my daily drivers gone but not forgotten;
1964(sunroof)1967 & (2)1968 Beetles , 1968 Squareback , 1963 (23 window )Deluxe Sunroof Bus , 1969 Westphalia camper, 1974 Dasher , 1985 Vanagon , (2) 1981 Rabbit Diesels & a 1991 Jetta Diesel . |
