dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
insyncro Banned
Posted: Fri Feb 12, 2016 7:01 am Post subject: Re: Bostig RG6 and beyond |
dobryan wrote: |
Thanks from me too on continuing this thread. (and I'm not even contemplating this conversion)
It really helps to have as robust a knowledge base as possible. |
You are welcome.
Thanks for viewing.
Glad to help. |
insyncro Banned
Posted: Fri Feb 12, 2016 7:03 am Post subject: Re: Bostig RG6 and beyond |
Just so that we are all on the same page here:
Copied from the first post and I agree wholeheartedly, just sharing my experience for the benefit of all following along.
" Moderator note:
This person is not associated with Bostig and is not selling anything at this time.
This thread is for discussion only. " |
mpl Samba Member
Posted: Fri Feb 12, 2016 10:23 am Post subject: Re: Bostig RG6 and beyond |
This is great. Having more clear, well described photos of the conversion-in-process is a huge help, both personally and to the community! Keep 'em coming... I'll try to contribute mine as well as I make headway through the conversion. |
insyncro Banned
Posted: Fri Feb 12, 2016 11:18 am Post subject: Re: Bostig RG6 and beyond |
mpl wrote: |
Indeed.
Your threads are on my list to link to from here as well.
I will have time this evening to do so.
D |
insyncro Banned
Posted: Sat Feb 13, 2016 8:31 am Post subject: Re: Bostig RG6 and beyond |
One of the reasons I wanted to use a bellhousing to mount the engine to my stand is to be able to attach the entire conversion and be able to see how it all lines up.
Not everyone needs this, but I have been able to assemble the needed parts, so what the heck, why not.
Here are a few of the things I look at, just to see how it all fits together:
insyncro Banned
Posted: Sat Feb 13, 2016 8:47 am Post subject: Re: Bostig RG6 and beyond |
Threadlockers:
The manual calls for threadlockers and I wholeheartedly agree.
I use these compounds all the time and now rely on them for various reasons.
Number one, when using an adapter plate, we can not afford to have fasteners loosen up.
RED locker will only release when heated.
Heated as in with a torch, not heat from the exhaust or engine compartment.
Here is how I like to apply threadlockers:
Apply a small amount of the locker to the amount of threads that will be mated.
I do so in a line from tip of the applicator, than run my finger all the way around the threads.
Wipe the excess off your finger or where gloves as this stuff isnt really harmful, but better safe than sorry.
It does make a mess and will feel sticky after a few minutes if left on your skin. |
insyncro Banned
Posted: Sat Feb 13, 2016 8:59 am Post subject: Re: Bostig RG6 and beyond |
Paint marks:
You will see multiple paint marks on the engines I am working on.
I was taught this many moons ago by a group of professionals in the race industry.
Making marks, multiple color marks are for a reason.
First off, if a fastener is just installed and not torqued for the final time, I make a mark to remind me.
Most often orange means that it is hand tight and needs more attention.
Second, when using the threadlockers described above, especially RED, that needs heat to release, make a red mark so that you or any mechanic that will see the van will know that heat is needed.
Also, let a mechanic know that RED means heat to release.
The fastener will release with brute force, but in some cases, damage to either sides of the threaded portion could happen if enough force is applied.
Simply hit the fastener with some heat and remove it.
Always clean the locker off the threads with a wire wheel before reinstallation and make sure to reapply the appropriate locker.
Paint dots vs lines.
Dots work great as a checklist, when you see them, you can say yup, torqued or yup hand tight.
Making a line through the fastener and out on to what it is fastened too will help show if it has loosened at all.
Here are a few examples:
insyncro Banned
Posted: Sat Feb 13, 2016 9:00 am Post subject: Re: Bostig RG6 and beyond |
Before getting started with your build, I highly recommend cleaning every single part so that they fit together perfectly, as designed.
insyncro Banned
Posted: Sat Feb 13, 2016 10:30 am Post subject: Re: Bostig RG6 and beyond |
SK-A:
This photo was a tough call to post.
Jim says to wedge a bolt between the post and the flywheel.
The nail puller actually worked well as it has a handle to hold on to if needed.
The flywheel was not damaged at all from this tool.
83ft/lbs of torque to the flywheel bolts.
They come from Ford with thread locker pre installed.
I marked them RED as these bolts need to stay put.
Clean the flywheel with solvent well after removing the sticker.
insyncro Banned
Posted: Sat Feb 13, 2016 10:33 am Post subject: Re: Bostig RG6 and beyond |
Ready for the next step. |
jimf909 Samba Member
Posted: Sat Feb 13, 2016 1:05 pm Post subject: Re: Bostig RG6 and beyond |
Thanks for the terrific thread! These are great shop tips in general and good insights on the conversion.
Looking forward to more. _________________ - Jim
Abscate wrote: |
regis101 Samba Member
Joined: July 28, 2005 Posts: 2078 Location: Livermore, Ca
Posted: Sat Feb 13, 2016 1:19 pm Post subject: Re: Bostig RG6 and beyond |
Nice pictures. Looks good. Out of curiosity, what is the dimension from crank center to the top of the belt cover? If we could only get a legal wiring harness for those of us in Cali-land _________________ Peace, Regis
insyncro Banned
Posted: Sat Feb 13, 2016 2:56 pm Post subject: Re: Bostig RG6 and beyond |
This post deleted by request.
Moderator note/warning: Dylan is generously providing a how-to guide for installing Zetec engines using Bostig's conversion kit so that potential DIY'ers will have a nice online reference. Once again, a reminder: Dylan/insyncro's services are not being advertised and he is not currently for hire. Attacks on his intentions with this topic are not appropriate. Any further questions/attacks regarding his intentions will be removed. Let's keep this great resource positive and civil, folks. Muchas gracias. |
Bassyaks Samba Member
Joined: October 06, 2010 Posts: 1137 Location: S.E. Connetitcut
JudoJeff Samba Member
Joined: May 24, 2013 Posts: 1179 Location: Near Springfield, MA
Posted: Sun Feb 14, 2016 2:57 pm Post subject: Re: Bostig RG6 and beyond |
Dylan, well done and very informative. _________________ ________________________________________
1989 Vanagon GL Westfalia Camper, Burned up on 7/31/16.
1987 Vanagon GL Westfalia Camper, Bostig & Rebuilt, sold
1986 Vanagon GL Westfalia Camper, Bostig Sold May 10, 2021
1999 Ford GTRV Westfalia camper (30% bigger Westy layout) |
insyncro Banned
Posted: Sun Feb 14, 2016 6:21 pm Post subject: Re: Bostig RG6 and beyond |
JudoJeff wrote: |
Dylan, well done and very informative. |
Thanks Jeff.
Much more to come. |
insyncro Banned
Posted: Sun Feb 14, 2016 6:23 pm Post subject: Re: Bostig RG6 and beyond |
regis101 wrote: |
Nice pictures. Looks good. Out of curiosity, what is the dimension from crank center to the top of the belt cover? If we could only get a legal wiring harness for those of us in Cali-land |
I have been away from my shop for a few days.
I will post a picture with the measurement for you soon.
California is going to be a tough sell without the BAR sticker.
Jim tried, but it required more than he was able to do at the time. |
insyncro Banned
Posted: Sun Feb 14, 2016 6:32 pm Post subject: Re: Bostig RG6 and beyond |
insyncro wrote: |
Thanks to our MOD Kam, this thread is being monitored and kept free of non technical banter.
For closure on the subject, I am NOT for hire, nor am I selling anything here.
Instead, I am taking the time to document an RG6 build, with an engine that has low miles and is in very good condition.
My pictures are for reference and are to accompany the Bostig Manual revision that I have shown previously.
Also, I am not affiliated with Bostig Engineering in any way.
Just a HUGE fan
Much more to come.
Please stay tuned. |
