3gengines Samba Member
Joined: July 17, 2015 Posts: 73 Location: Sugar Hill, Ga
Posted: Sun Nov 22, 2015 10:47 am Post subject: Link and pin questions |
I have my front end apart on my rail buggy. Some year model of Link and Pin.
The bushing feel tight and I have cleaned and freshened the pins that are in good shape.
I need to know:
#1, How can I figure out the year model of the front end?
#2, How many shims should be used?
#3, My pins are 3/4 and I see 5/8 & 7/8 available. Am I missing something?
Thanks. |
dustymojave Samba Member
Posted: Mon Nov 23, 2015 12:09 am Post subject: Re: Link and pin questions |
Quote: |
#1, How can I figure out the year model of the front end? |
Link pin Bug front ends vary quite little from 1938 to 1965. The steering box changed in 1961 and remained pretty much the same through the ball joint years. The pins didn't change, nor did the king pins, shims, link carriers, spindles, beam, trailing arm, etc. So on a buggy, the year model your beam came from really doesn't matter.
Quote: |
#2, How many shims should be used? |
The same for all years. 10 shims on all 4 pins for ALL link pin Bugs. Some cars were equipped (mostly retrofit during normal maintenance work) with "Dust Seal" shims which take the place of 2 regular shims and have a rubber lip around the outside. For how many to install inboard and how many outboard of the link on each pin, you will need a chart. I've always relied on my "Without Guesswork" factory service book. Some charts out there do not take into account the dust seal issue and will give you specs for 8 shims. If you DO put dust seals in, go by the numbers for 8 shims.
This drawing is from the "Idiot" book.
A chart from the service manual which refers to using dust seals:
Quote: |
#3, My pins are 3/4 and I see 5/8 & 7/8 available. Am I missing something? |
Stock Link pins for a Bug are 18mm, which is about 1mm less than 3/4". Some convert that to 5/8". The "7/8" size link pins are commonly called "King Kong" by offroaders and are the same diameter as Bus link pins. _________________ Richard
SoCalBajas Member
Posted: Mon Nov 23, 2015 12:33 am Post subject: Re: Link and pin questions |
Here is a scan of the shim chart pages from the Without Guesswork book:
(Not my scan)
Click on the image to enlarge it. _________________ Richard
SoCalBajas Member
Posted: Mon Nov 23, 2015 5:07 am Post subject: Re: Link and pin questions |
Richard, As always, a great wealth of knowledge. Thank you.
I will order enough 5/8 shims to properly adjust my front end.
B Ramsey Samba Member
Joined: February 05, 2006 Posts: 477 Location: Ramona ca.
Posted: Mon Nov 23, 2015 7:55 am Post subject: Re: Link and pin questions |
some arms have an indented space for the o-ring, earlier ones dont. not sure of years, but i have seen both. |
