60 baja Samba Member
Posted: Sun Nov 22, 2015 2:21 pm Post subject: Shift linkage |
So i am putting in a transaxle in my baja and it is all bolted in. The shift linkage is about 1/4" too long to fit onto the hockey stick. I REALLY do not want to unbolt the whole damn transmission to get a 1/4" of clearence. Is there anything i can do at the coupler or in the linkage that would be easier?
Thanks
Sandjunky Samba Member
Joined: August 03, 2015 Posts: 292 Location: New Mexico
Posted: Sun Nov 22, 2015 4:32 pm Post subject: Re: Shift linkage |
You could weld an extension on the coupler if it isn't adjustable. I don't know how hard it is to take a linkage out of a stock bug, but this adjustable end would work well. I just installed it in my sand rail this weekend.
https://www.google.com/url?sa=i&rct=j&q=&a...1457266501 |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20378 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Nov 22, 2015 5:59 pm Post subject: Re: Shift linkage |
Have you tried popping shifter out to get better movement of rod?
Posted: Sun Nov 22, 2015 11:50 pm Post subject: Re: Shift linkage |
What do you mean by popping? Like trying to get into reverse?
Thanks |
Posted: Mon Nov 23, 2015 8:41 am Post subject: Re: Shift linkage |
60 baja wrote: |
Thanks |
No.... Try taking out the two bolts that holds shifter assembly to tunnel and removing it, this allows the shift rod to move back and forward some more and then maybe you can get coupler on to hickey stick....
Posted: Mon Nov 23, 2015 10:21 am Post subject: Re: Shift linkage |
Oh, ok i will try that next, thanks |
Gary Massin-Ball Samba Member
Posted: Thu Nov 26, 2015 10:04 am Post subject: Re: Shift linkage |
How bout poppin the trans into 1st or third? That would move the hockey stick in towards the trans a bit! _________________ Warrior sand rail:
2276cc 82x94
Engle FK-41 with 1.25:1 street style rockers
40x35.5 stock cast single port heads
Single 40mm Kadron w/32vent
Equalizer 5lb pulley
Stock lifters
Stock aluminum pushrods
26mm aluminum oil pump full flow
*Poor mans rack and pinion up front*
The Ugly Bug is on the road! |
Posted: Fri Nov 27, 2015 2:41 pm Post subject: Re: Shift linkage |
Dropped the shifter into reverse before unbolting anything and it gave me the clearence i needed
Thanks for the help |
