Monkster7 Samba Member
Joined: November 03, 2015 Posts: 4 Location: Williamsburg, Virginia
Posted: Mon Nov 23, 2015 6:10 pm Post subject: Ghia - uncarpeted space around rear seat |
Got the car 95% ready for paint with exception of one patch panel. On to the interior. I got my carpet kit and dry fit it in place. Have also recovered seats and realize that there are gaps around the rear seat bottom that will not be covered by carpet or seat. Looking at my dad's Ghia, the areas are covered with some variety of plastic covering. I was thinking of using marine grade vinyl (it has a different texture) to cover those areas. Doesn't seem like they should just be painted, as the area directly behind the seat is recessed and it just doesn't seem like paint is the right approach. Thoughts?
73 Ghia - Primer Grey but headed to Candy Apple Red |
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2878 Location: Auckland, New Zealand
Posted: Mon Nov 23, 2015 8:41 pm Post subject: Re: Ghia - uncarpeted space around rear seat |
Monkster7 wrote: |
I ran into the same problem and the interior looked unfinished. What my wife and I did was to make our own vinyl sections to fit behind the back seat and the back seat back, and also for the sides where the back seat meets the arms rests. I trust this photo will demonstrate better than I can explain. We used the same vinyl as we had on the seats.
_________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
DogGeorge Samba Member
Joined: June 25, 2012 Posts: 16 Location: Central Virginia
Posted: Wed Nov 25, 2015 6:58 am Post subject: Re: Ghia - uncarpeted space around rear seat |
I used marine vinyl also - it's got more stretch. I had to go back and cover the front corners where the two bits of carpeting didn't meet. I think some carpet sets do this joint with a single piece so there isn't a gap. This is a TMI carpet set in my 66 coupe. I found the seat bottom fit a little too tightly, even though I didn't add sound mat down the sides of the seat. I try not to take the seat in and out too often because it scrubs the vinyl pretty hard.
c21darrel Samba Member
gregson1 Samba Member
Posted: Fri Nov 27, 2015 10:19 am Post subject: Re: Ghia - uncarpeted space around rear seat |
I had a mid-'62 with original carpeting that had the seams at the corners of the emergency seat supports. I do not know when the change to the carpeting in this area was made, but the spare parts list shows a change in parts numbers at the beginning of the '63 model year.
The rear bottom jump seat area was covered in a thin vinyl, the sides covered first, then the rear section, as pictured in the post above. It would have been covered using the same color material used in the package tray and around the outer edge of the seats. |
Andy Wellie Samba Member
Posted: Sun Nov 29, 2015 2:43 am Post subject: Re: Ghia - uncarpeted space around rear seat |
When I bought my interior kit from JBugs I also bought an extra piece of the vinyl the same colour as my seats and door cards and am planning on covering those panels and the rear parcel shelf so it all matches. Nothing like a bit of forward thinking!!! |
