SixtyThreeRag Samba Member
Joined: July 12, 2015 Posts: 101 Location: Fort Worth, TX
Posted: Tue Nov 24, 2015 9:56 am Post subject: 59 body on a 63 pan |
Thinking about picking up a 59 body to lay on my restored 63 pan. Is this just a simple bolt up operation, or is there anything else to it? |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11055 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Tue Nov 24, 2015 10:05 am Post subject: Re: 59 body on a 63 pan |
Technically considered illegal...... but bolts up easier than searching the forums..
http://www.thesamba.com/vw/forum/search.php?search..._chars=200
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Tue Nov 24, 2015 10:08 am Post subject: Re: 59 body on a 63 pan |
haha, thanks VWNUT |
Ben Dover Banned
Joined: March 02, 2014 Posts: 92 Location: Charleston
Posted: Tue Nov 24, 2015 12:41 pm Post subject: Re: 59 body on a 63 pan |
What happened to the 59's pan? |
Lidpainter Samba Anti-Hero
Joined: January 21, 2004 Posts: 2045 Location: 41.77 | -83.56
Posted: Tue Nov 24, 2015 12:46 pm Post subject: Re: 59 body on a 63 pan |
Is it registered/titled to the body or the pan? If you have a title for the pan and register it as a '63 you should be golden but if you title/register it to the body you are asking for trouble. _________________
EverettB wrote: |
Thanks, time to bulk up on meat! |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Tue Nov 24, 2015 2:38 pm Post subject: Re: 59 body on a 63 pan |
Lidpainter wrote: |
Is it registered/titled to the body or the pan? If you have a title for the pan and register it as a '63 you should be golden but if you title/register it to the body you are asking for trouble. |
Why is that? I was actually curious about doing this. I have a bug registered as a 64 due to the pan but the body is a 63. I had considered seeing what it would take to register it as a 63. I spoke to someone briefly at the DMV here and they mentioned a "built from parts" title. I didn't want to go that route as it sounds too similar to a salvage title. |
Posted: Tue Nov 24, 2015 3:16 pm Post subject: Re: 59 body on a 63 pan |
^ You are lucky it stopped there.. . and you got away..
Pan (chassis) numbers are generally the official serial (VIN) numbers.
Body swaps, body tags being lost or swapped is fairly common albeit illegal..
Not saying its right.... but .....
Its best to have the title match the chassis number..... and keep any other questionable and lost number "things" to yourself.
If the title matches the Body tag only..... then... keep it even quieter..
Either way.. be happy you can drive it..
Just hope if you ever need to file an insurance claim it will be covered... because its a 110% reason and a way for them to deny if they start poking around..
Posted: Tue Nov 24, 2015 3:35 pm Post subject: Re: 59 body on a 63 pan |
I got the impression that it wouldn't be that big of a deal either way to register it if it was built from parts. Its just a different type of title here. Either way, its fully able to be registered and driven. Heck, Florida is one of the few states where you can actually title, register and drive a sand rail on the roads. They also have kit car and custom car registrations. |
Posted: Tue Nov 24, 2015 4:55 pm Post subject: Re: 59 body on a 63 pan |
I've got both pans, but I've already restored the 63 pan, and the 59 body is primo. I was planning on dropping the 59 body on the 63 pan and living happily ever after. |
morymob Samba Member
Posted: Wed Nov 25, 2015 4:01 am Post subject: Re: 59 body on a 63 pan |
Maybe happy 4 u as a 59but if ever u try to sell, many go by legit chassis vin,, & probably like me it otherwise was by body u have a parts car. U sell, new owner sees titled by body, could get u for that thing called fraud, even a costly suit, your choice. As usual no warranty offered at this time. |
Posted: Wed Nov 25, 2015 6:18 am Post subject: Re: 59 body on a 63 pan |
I would check with your local DMV and see what they say. My guess is you'll have to title it as a 63. |
Posted: Wed Nov 25, 2015 7:44 am Post subject: Re: 59 body on a 63 pan |
SixtyThreeRag wrote: |
.. great idea..
Last to the 50's ... I'd roll it any day..
When asked.. tell all proudly its a 59'... Nobody will really know the difference about the pan being a 63.. .. or in reality...even care.
HBRag Samba Member
Joined: April 29, 2005 Posts: 735 Location: Huntington Beach, CA
Posted: Wed Nov 25, 2015 11:16 am Post subject: Re: 59 body on a 63 pan |
Although I've done the swap myself, I do know the rear shock towers and body area are different. The '59 gas the towers and upper shouck mounts parallel to the centerline. The '63 has the mounts turned out at about a 30 degree angle. At a result, you may have to modify the '59 body to clear. |
Posted: Wed Nov 25, 2015 11:31 am Post subject: Re: 59 body on a 63 pan |
HBRag wrote: |
What did you have to do to yours to make it fit? |
Posted: Wed Nov 25, 2015 3:42 pm Post subject: Re: 59 body on a 63 pan |
HBRag wrote: |
The rear shock towers will clear and fit perfectly fine.. No clearance issues.
The only mod if so desired... the shock bolt access hole needs be elongated to allow bolt removal.
Or.. more simply..... just put the bolts in the opposite way...
Straight
Angled
Joined: August 31, 2013 Posts: 12846 Location: North Carolina
Posted: Wed Nov 25, 2015 4:12 pm Post subject: Re: 59 body on a 63 pan |
Hey Ken, I said the same thing in HBB off-road forum & got corrected by one of the main contributors, I left it alone but he was quite adamant to the contrary. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Wed Nov 25, 2015 4:59 pm Post subject: Re: 59 body on a 63 pan |
Just like Ken says . . . bolt the shocks on with the bolt from the outside and the nut inboard from the shock . . . no need to modify the body.
FWIW . . . my avatar shows my European '56 Ragtop sitting on a '63 pan.
When I sold the car, the buyer questioned the discrepancy in the body VIN/chassis VIN/title VIN . . . SADLY for me, he bought it anyway and I have never seen it since.
Of all the cars and bikes I have owned, I wish I could have THAT one back! _________________ Jesucristo es mi Seņor y Salvador! |
Ben Dover Banned
Posted: Thu Nov 26, 2015 1:38 am Post subject: Re: 59 body on a 63 pan |
The fastest way to ruin the value of a be,is to swap it onto another pan.
You have a restored pan,great. There are plenty of bodies for sale that are missing their pan;use one of those.
I would never swap pans on my vw's, and I'll never buy a vw that doesn't have matching numbers. |
Posted: Thu Nov 26, 2015 10:47 am Post subject: Re: 59 body on a 63 pan |
VW purist's will turn their nose up at the body anyways. It's a 59 with a 56 roof on it.
And kind of the style I'm going for:
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Thu Nov 26, 2015 6:51 pm Post subject: Re: 59 body on a 63 pan |
Another area to consider is the wiring as '59 and '63 have different wire terminal styles, turn signal switch and lights, and horn wiring.
To make the conversion clean and simple, use everything electrical from the '59 including column, steering wheel and turn signal switch. _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
