rcroane Samba Member
Joined: January 03, 2013 Posts: 1996 Location: Springfield, Virginia
Posted: Tue Nov 24, 2015 5:52 pm Post subject: '65 bug wiring diagram - flasher relay question |
The '65 type 1 wiring diagram doesn't show a ground wire for the flasher relay. If I use a 3 terminal relay (111 905 185C), should I run a ground wire from terminal 31 on the flasher? Or, is it grounded by the connection to the bracket?
Thanks. _________________ '65 Sunroof Bug |
sump-plug Samba Member
Posted: Tue Nov 24, 2015 6:02 pm Post subject: Re: '65 bug wiring diagram - flasher relay question |
Hi
31 to ground with an additional wire to the bracket.
It wont ground through the tab for attchment
_________________ Common sense applied rigorously. |
Posted: Tue Nov 24, 2015 6:04 pm Post subject: Re: '65 bug wiring diagram - flasher relay question |
Perfect....thanks for the quick response. _________________ '65 Sunroof Bug |
Posted: Tue Nov 24, 2015 6:08 pm Post subject: Re: '65 bug wiring diagram - flasher relay question |
I didn't have any brown wire at the time (its the black one on the left of the flasher relay), so I used a black one. Grounds via a ring to the screw holding the flasher to the bracket. _________________ Common sense applied rigorously. |
Posted: Sun Nov 29, 2015 1:02 pm Post subject: Re: '65 bug wiring diagram - flasher relay question |
Update...I purchased a NOS 3 terminal flasher relay (111 905 185C) for my '65 bug. It was advertised as a '66 relay. I assumed it would work on my '65, but it doesn't. Speedo light comes on, but signals don't work. I double checked the wiring and signals were working fine with the two terminal flasher that I replaced.
Is there any reason this flasher should not work on my car? Or did I just get a bad unit?
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11053 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sun Nov 29, 2015 2:52 pm Post subject: Re: '65 bug wiring diagram - flasher relay question |
111 905 185C ????
Thats not a good flasher relay part number..
Not sure what you have..
2 or 3 terminals and are they numbered or labeled???
A US spec 66 flasher is not remotely close to a 65 flasher.
I think a 6 volt flasher should be 111 953 185.. (maybe B or C suffix by 1965)
Typical . ..
49 = Ign Key on fused power
49a = Signal circuit and indicator light shared
31 = Ground
_________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Sun Nov 29, 2015 3:03 pm Post subject: Re: '65 bug wiring diagram - flasher relay question |
Sorry....my bad....I meant 111 953 185C.
It has the screw stud on top that mounts to the bracket referenced in your post (part no. 111 415 621C).
I connected the ground (terminal 31) to one of the screws holding the speedo to the dash. Wires from turn signal switch and speedo light are connected to 49a. Wire from fuse block is connected to 49. _________________ '65 Sunroof Bug |
glutamodo The Android
Joined: July 13, 2004 Posts: 26300 Location: Douglas, WY
Posted: Sun Nov 29, 2015 4:18 pm Post subject: Re: '65 bug wiring diagram - flasher relay question |
In my experience, those old metal-can flashers can be hit or miss as for quality, even when they are NOS. (I've got a couple of NOS Bosch 12V smaller metal can three-terminal flashers that don't work for me either, and I had a larger one that never worked very reliably.) I have heard that some of them are sensitive to the angle they are installed (terminals facing up or facing down) |
Posted: Sun Nov 29, 2015 4:52 pm Post subject: Re: '65 bug wiring diagram - flasher relay question |
Well, for something that cost $2.85 in 1966 (the seller still had the original receipt), I guess it's not surprising that it doesn't work after 50 years on the shelf!
I'm going to get a WW relay. In this case, I need reliability more than originality.
Thanks for the feedback. _________________ '65 Sunroof Bug |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33883 Location: Conejo Valley, CA
Posted: Sun Nov 29, 2015 6:45 pm Post subject: Re: '65 bug wiring diagram - flasher relay question |
rcroane wrote: |
Thanks for the feedback. |
The cans are pretty large, large enough to fit the new relay inside, and then you can have it both ways. |
Posted: Sun Nov 29, 2015 7:06 pm Post subject: Re: '65 bug wiring diagram - flasher relay question |
Well, now I feel like an idiot. Turns out there is an adjusting screw near the terminals.....fiddled with that and bingo!
I also figured out that the ground connection to the speedo wasn't doing the job. Works much better when I ground it to the radio bracket.
I'm still getting the WW relay as a backup....I'm sure this can will give out eventually. KTPhil.....great idea to disguise the WW relay inside the can!
Thanks again for the input. _________________ '65 Sunroof Bug |
