ldj1002 Samba Member
Posted: Wed Nov 25, 2015 9:22 am Post subject: Master cylinder vent |
Does the master cylinder need a vent in the cap? I have heard it does. However I have heard for type 3 brake fluid to not use it after a few months because once open it absorbs moisture. Well, if my master cylinder is vented then the brake fluid is open to moisture. |
Mr.Duncan Samba Member
Joined: May 12, 2012 Posts: 3542 Location: Houston, TX
Posted: Wed Nov 25, 2015 9:29 am Post subject: Re: Master cylinder vent |
My 71' had a small TINY TINY hole. Size of a pin head.
Same thing, in my 2003 Camry. (which takes DOT3)
True DOT 3 absorbs moisture.
However it is recommended maintenance to replace the DOT3 Fluid in the entire system every 2 years. _________________ (Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle |
volksworld Samba Member
Joined: November 26, 2011 Posts: 2529 Location: formerly NY currently NC
Posted: Wed Nov 25, 2015 8:42 pm Post subject: Re: Master cylinder vent |
yes it has a vent hole...as fluid level drops to fill calipers air has to enter to replace it...most american cars used a cover gasket with 2 rubber bellows that could extend as levels dropped but vw's werent that sophisticated |
Joe Bence Samba Member
Joined: March 14, 2004 Posts: 501 Location: San Diego, CA
Posted: Wed Nov 25, 2015 9:15 pm Post subject: Re: Master cylinder vent |
Thanks for info. |
