LivinInnaVWBus Samba Member
Posted: Fri Nov 27, 2015 4:14 pm Post subject: Largest Starting & Auxiliary Odyssey Battery |
Hey guys
Currently shopping Odyssey batteries for both the starting battery and an auxiliary battery. The battery Odyssey recommends for a direct replacement is the PC1200MJT group 42 (Length: 7.995" - Width: 6.79" - Height: 6.8625")
Not concerning myself with mounting it using the stock hold down, what is the largest battery I could physically fit on the battery trays?
Aux battery list & sizes; http://www.odysseybattery.com/performance_battery_specs.aspx
Starting battery list & sizes; http://www.odysseybattery.com/extreme_battery_specs.aspx |
Brian Samba Moderator
Posted: Fri Nov 27, 2015 5:02 pm Post subject: Re: Largest Starting & Auxiliary Odyssey Battery |
Brian wrote: |
Short answer: Big
Long answer: Large
There's already like a shit ton of threads on batteries though. I'd take a gander at them first, because that question is asked often
Take a look at this thread: Auxillery Battery & A GrapeSolar GLACIER 1.1 Fridge |
Lol yep, I've scoured them ALL. I've got two screens at work, they're both full and I wasn't able to find a solid answer. The post you linked to is mine, though it gets me closer, no cigar.
Next step is to make some battery shapes out of cardboard. |
airschooled Air-Schooled
Posted: Fri Nov 27, 2015 5:14 pm Post subject: Re: Largest Starting & Auxiliary Odyssey Battery |
Has your research turned up any opinions (or facts!) about using two 6v batteries tied together? My dad swears by this method for deep cycle work at 12v.
www.airschooled.com |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Fri Nov 27, 2015 5:16 pm Post subject: Re: Largest Starting & Auxiliary Odyssey Battery |
I have a hard time understanding why people feel they always need something bigger. It's like oil pumps. The 26mm works just fine but if someone sells a bigger pump, people are sure to buy it. As far as batteries go I would think a tape measure and a trip to your local battery store would solve your problem. I really doubt that all the money spent on exotic batteries will pay off. As long as you buy a good quality lead acid battery instead of some crap brand I think you'll be just fine. There is always someone out there that's willing to take your money and sell you some kind of imaginary security. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Fri Nov 27, 2015 5:59 pm Post subject: Re: Largest Starting & Auxiliary Odyssey Battery |
asiab3, yes. The solar guys do that if they've got the space, typically in a shallow but long space like under the back seat. I didn't consider it an option for myself until you mentioned it, but that may be a viable way to squeeze more capacity in there if two will fit next to each other.
aeromech, I live in the bus and I'm converting from plug in to full off grid. I will be going solar eventually, but in the mean time I'll be charging both batteries using the alternator while running a fridge and vent fan - I'll need extra capacity until I can install the secondary charging source so I don't run out of juice. Also, I'll probably be up in Alaska within the next couple of years so I might need some extra power for cold starts. |
Posted: Fri Nov 27, 2015 6:12 pm Post subject: Re: Largest Starting & Auxiliary Odyssey Battery |
I like that double 6v idea. But a nice sealed deep cycle and a battery warmer will serve you will.
Make sure it's HD and made in the U S of A
_________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Fri Nov 27, 2015 6:13 pm Post subject: Re: Largest Starting & Auxiliary Odyssey Battery |
Brian wrote: |
battery warmer will serve you |
Not if I can't plug in |
Posted: Fri Nov 27, 2015 6:40 pm Post subject: Re: Largest Starting & Auxiliary Odyssey Battery |
I have run Group 79 side terminal batteries on my old '74. The tray actually accepted this size just fine. My present tray is designed with the much smaller Group 42 in mind.
I am a big fan of large batteries and fat wires, this just makes the engine start like a breeze and seems to extend of the life of the starter, alternator, and the battery.
The one Diehard Group 79 I had lasted 13 years and another Group 27 Diehard I had in my pickup died at 11 years when the battery tray collapsed dropping the battery. |
ZachL Samba Member
Joined: January 07, 2006 Posts: 34 Location: Austin, TX
Posted: Fri Nov 27, 2015 9:03 pm Post subject: Re: Largest Starting & Auxiliary Odyssey Battery |
There's only a handful of companies that actually manufacture batteries, which are then bought by all sort of companies who sticker them with their own brands and resell. Two of the biggest companies are East Penn and Johnson Controls.
My one recommendation is to go with an AGM (Absorbed Glass Mat) battery. All AGM batteries are virtually spillproof, vibration-resistant, and allow installation in virtually any position. The spill proof technology is what allows web vendors to ship AGM batteries ready to go out of the box. Standard lead / acid batteries are shipped dry (no acid) and then the acid is typically added at the parts store or its central warehouse prior to delivery to the customer.
I recommend East Penn. Their house brand makes the Deka Intimidator AGM, but the DieHard Advanced Gold AGM is the same battery, the cheapest I could find, and available to order online and pickup at any local Sears store. The Johnson Control batteries seem to have gone done in quality the last several years, including the Optima line which they manufacture. Do some research and Google'ing and you'll see a ton of people having them less than 2 years.
FYI Odyssey used to make the DieHard Platinum batteries. You might be able to find the Odyssey battery for substantially lower price, just with a different sticker on the outside. |
Posted: Sun Nov 29, 2015 9:20 am Post subject: Re: Largest Starting & Auxiliary Odyssey Battery |
Wildthings, I'm with you. I'll be converting to 2g USA made high temp auto wire shortly.
ZachL
Thank you for the information, but none of that is pertinent to the inquiry. |
myvantastic Samba Member
Posted: Sun Nov 29, 2015 9:31 am Post subject: Re: Largest Starting & Auxiliary Odyssey Battery |
I have 2 Optima yellow AGM 55ah batteries in my left battery tray.
It fits perfectly!
Chris _________________ www.myvantastic.com
www.instagram.com/myvantastic |
Posted: Sun Nov 29, 2015 9:44 am Post subject: Re: Largest Starting & Auxiliary Odyssey Battery |
asiab3 wrote: |
Robbie |
Times have probably changed, but 20-30 years ago 6v batteries seemed to be built using 1920 era technology so tended to give life expectancy problems. In theory yes two 6v in series should work better than two 12v in parallel. |
