buggyjj Samba Member
Joined: March 17, 2013 Posts: 128 Location: Kelowna, BC
Posted: Sat Nov 28, 2015 8:29 pm Post subject: Lost power please help! |
1998 2.0 gas golf
We sprung a leak at the oil cooler so this morning I replaced the gasket and the oil filter. Now the car loses all power on acceleration. It idles fine. In neutral I can rev it up with no problem although there is a whirring noise at higher rpms. When I accelerate it will go for maybe a second then rpms drop and the car will nearly stall. I can get it going again if I put in the clutch, get the rpms back up, then release clutch and give it barely any gas. It did this in first and second gear and I couldn't get going fast enough for third. It was running fine before I changed that gasket. Coincidence? Did I knock something loose? _________________ 68 vw beetle
69 vw beetle
74 super beetle 71 engine off-road mods
77 raised roof Westy
81 Westfalia
Rabbit
Fox
02 new beetle
06 golf |
73sports Samba Member
Joined: September 26, 2004 Posts: 2107 Location: Warrington, PA
Posted: Sat Nov 28, 2015 8:51 pm Post subject: Re: Lost power please help! |
Check the intake boot between the air box and throttle body. It may have a split or not be attached properly. _________________ I will never lie, but sometimes the truth changes.
Central Jersey VW Society |
Posted: Sun Nov 29, 2015 2:22 pm Post subject: Re: Lost power please help! |
Thanks for your help. I checked the boot and it is connected properly and in very good condition. I checked all electrical connection and hoses in the area I was working and all seems fine...
Any other ideas? _________________ 68 vw beetle
69 vw beetle
81 Westfalia
Rabbit
Fox
02 new beetle
06 golf |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Sun Nov 29, 2015 6:16 pm Post subject: Re: Lost power please help! |
What is your fuel pressure? |
Posted: Sun Nov 29, 2015 7:06 pm Post subject: Re: Lost power please help! |
I'm not sure...but considering that in neutral it revs up and down and idles with no issues, I wouldn't suspect a fuel pump or pressure issue... _________________ 68 vw beetle
69 vw beetle
81 Westfalia
Rabbit
Fox
02 new beetle
06 golf |
Posted: Sun Nov 29, 2015 7:08 pm Post subject: Re: Lost power please help! |
When I changed the oil cooler gasket I also disconnected the battery to clean the posts. Not sure if disconnecting battery could have affected something? _________________ 68 vw beetle
69 vw beetle
81 Westfalia
Rabbit
Fox
02 new beetle
06 golf |
ps2375 Samba Member
Posted: Sun Nov 29, 2015 8:00 pm Post subject: Re: Lost power please help! |
It doesn't take much fuel to free rev a motor. |
Joined: August 31, 2013 Posts: 12861 Location: North Carolina
Posted: Mon Nov 30, 2015 3:10 pm Post subject: Re: Lost power please help! |
Disconnecting the battery can cause the computer to lose "memory" of the throttle body on some of the cars in those years. Try scanning the codes or having someone do it for you, if you get a throttle adaptation code you will need to clean the throttle body & have it adapted to the computer. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon Nov 30, 2015 3:12 pm Post subject: Re: Lost power please help! |
TDCTDI wrote: |
Disconnecting the battery can cause the computer to lose "memory" of the throttle body on some of the cars in those years. You will need to clean the throttle body & have it adapted to the computer. |
Is that something I can do myself (how) or do I need to take it to the mechanic? _________________ 68 vw beetle
69 vw beetle
81 Westfalia
Rabbit
Fox
02 new beetle
06 golf |
Posted: Mon Nov 30, 2015 3:16 pm Post subject: Re: Lost power please help! |
You might be able to buy a cheap scanner to check & clear codes but it won't let you perform adaptation procedures. But it might be cheaper than towing it to a shop with no idea what's going on. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon Nov 30, 2015 3:20 pm Post subject: Re: Lost power please help! |
You might want to see if someone near you has a VAG-COM (Ross tech sells one that can be used with your laptop) that be willing to do an adaptation where your car is at. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Tue Dec 01, 2015 8:37 am Post subject: Re: Lost power please help! |
I was reading some other forums and came across this to reset everything:
Disconnect the negative terminal from the battery and wait about 15 minutes or so. Reconnect the terminal and insert fob and turn to ACC and then you should start to hear the TB clicking as it tries to self align. Wait at least 3 minutes until you stop hearing the engine clicking and there is NO noise coming fom the compartment...pull fob shut hood, get in car shut drivers door start her up...I do this everytime I clean my MAF, TB, IAT sensor and Air intake filter...
-J
I tried it and it seems to have fixed the problem at least for now... _________________ 68 vw beetle
69 vw beetle
81 Westfalia
Rabbit
Fox
02 new beetle
06 golf |
