teched Samba Member
Joined: August 23, 2015 Posts: 46 Location: Forestport, NY
Posted: Sun Nov 29, 2015 6:07 pm Post subject: 1300 Back in the car and Ran, but now it wont. |
Ok Got the engine back in the car. I had a couple of plug wires switched, but I it fired up and ran for about 5 seconds. Long enough to play with the distributor a little. I am runing it off a pepsi bottle so no crud from the tank. Now its acting like its out of time. Spins over and pops through the carb even stops rotating like its way out of time, buts its not.(I put the distrubutor back where I had it to start the first time) Could it be super flooded? I am not to sure about the carb. I pulled it apart and cleaned it, but the jet under the choke butterfly went in "cross threaded". The carb is not giving a spray of fuel went I pump the throttle either. I think I have carb problems. Changed the plugs and checked the compression 110 on three cylinders and 95psi on one cylinder. Should be good enough to run...I think. I posted a video up on my youtube channel. Under Ed Moore |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Sun Nov 29, 2015 6:14 pm Post subject: Re: 1300 Back in the car and Ran, but now it wont. |
So, no fuel spray from the accel jet. Is there fuel in the float bowl? |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5363 Location: Lefty, CA
teched Samba Member
Posted: Mon Nov 30, 2015 3:39 am Post subject: Re: 1300 Back in the car and Ran, but now it wont. |
Yes the bowl is full. I tried pouring gas down the carb and even starting fluid. Just poping and back firing. Changed plugs thought maybe I drenched them. No difference. Couldn't have jumped time... could it? |
David_nc_72std Samba Member
Joined: August 22, 2015 Posts: 841 Location: Winston-Salem, NC
Posted: Mon Nov 30, 2015 4:40 am Post subject: Re: 1300 Back in the car and Ran, but now it wont. |
teched wrote: |
Ok Got the engine back in the car. I had a couple of plug wires switched, but I it fired up and ran for about 5 seconds. Long enough to play with the distributor a little. ...... Spins over and pops through the carb even stops rotating like its way out of time, buts its not.(I put the distrubutor back where I had it to start the first time) ......... |
Have you checked the dwell and timing to be sure it is correct? Just moving the distributor "back to where I had it" by eye isn't going to be good enough. You need to at least check the static timing with a test light, and probably verify the points gap just to make sure you got that correct. |
teched Samba Member
Posted: Mon Nov 30, 2015 5:31 am Post subject: Re: 1300 Back in the car and Ran, but now it wont. |
Thanks Dave, Is it that critical to get the timing Tach/dwell exact to get it to "run". I know for fuel consumption, power, etc it is imperative, but just to get it to run "even poorly" What kills me is that it did run for a few seconds and then just died. I will check the points tonight. |
Posted: Mon Nov 30, 2015 11:00 am Post subject: Re: 1300 Back in the car and Ran, but now it wont. |
teched wrote: |
It doesn't have to be exact, but it has to be in the ball park. Just a little twist on the distributer make a lot of change in the timing. If you don't have a test light. Rotate the engine until it is on TDC for #1 cylinder. Then with the key on, slowly rotate the distributer back and forth until the points just spark. This should get you close enough to start. _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
teched Samba Member
Posted: Mon Nov 30, 2015 12:26 pm Post subject: Re: 1300 Back in the car and Ran, but now it wont. |
I will give it a try. I saw a guy on YouTube hook up a what looked to be a 12 volt test light to the wire coming out of distributor to the coil. With the number one cylinder at top dead center he rotated the distributor until the light just went out. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31361 Location: Hot Arizona
Posted: Mon Nov 30, 2015 12:56 pm Post subject: Re: 1300 Back in the car and Ran, but now it wont. |
teched wrote: |
I am running it off a pepsi bottle .....spins over and pops |
I just found it funny that you used a Pepsi bottle and it went pop !!!
teched wrote: |
Yes, that's called static timing. With the engine turned to TDC #1 or 7.5 BTDC #1 (7.5 degrees before, or clockwise, from TDC) that should be close enough to get it to start.
What one really wants is like 30 BTDC at about 3500 rpm using a timing light. I have a German 009 distributor, and on mine 30 BTDC at about 3500 rpm does fall to 7.5 BTDC at idle, so matches my static timing. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
teched Samba Member
Posted: Mon Nov 30, 2015 5:09 pm Post subject: Re: 1300 Back in the car and Ran, but now it wont. |
I feel kinda stupid, but I figured it out. Pulled the cap and the rotor was not turning. Dizzy must have jumped out when I was turning it. As for my Pepsi bottle...would I gain a couple of HP if I used a Red Bull Can? Just a thought. Thank you all for helping. |
cletus_zuber Samba Member
Joined: January 08, 2010 Posts: 2407 Location: Gladstone, Ore
Posted: Mon Nov 30, 2015 6:36 pm Post subject: Re: 1300 Back in the car and Ran, but now it wont. |
teched wrote: |
FYI this is called "static timing" and will get you in the ballpark, as above. Glad you got it running! _________________ 1972 1302
HPMX 40's & 019 |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Tue Dec 01, 2015 12:42 pm Post subject: Re: 1300 Back in the car and Ran, but now it wont. |
teched wrote: |
As for my Pepsi bottle...would I gain a couple of HP if I used a Red Bull Can? Just a thought. |
Yes, good idea. Just don't use a Four Loko can, or your car will get the Super Shimmies. _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
