Clara Samba Member
Posted: Thu May 26, 2016 7:20 pm Post subject: Re: '61 corner window westy campingbox |
I'll have to get some mirrors to put under it! _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
vwmike Samba Member
Joined: November 19, 2001 Posts: 156 Location: Fraser Valley, BC, Canada
Posted: Thu May 26, 2016 7:30 pm Post subject: Re: '61 corner window westy campingbox |
Impressive stuff Greg! I think in another life you must of worked at Wolfsburg or something.....
What purpose does welding the ends of the springs serve?
Glad your cat came back! Been there done that, not fun. |
srfndoc Samba Member
Clara wrote: |
I'll have to get some mirrors to put under it! |
Here's some inspiration:
_________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10198 Location: Petaluma, CA
Posted: Thu May 26, 2016 7:58 pm Post subject: Re: '61 corner window westy campingbox |
I had a picture of that 23 window hanging on my wall when I was 15.
The welded ends ran up through 64 or 65 and was just to make them easier to install. |
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Thu May 26, 2016 8:06 pm Post subject: Re: '61 corner window westy campingbox |
Is that Clara? _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends |
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5509 Location: 1st Coast
Posted: Thu May 26, 2016 8:33 pm Post subject: Re: '61 corner window westy campingbox |
Amazing Greg, and so happy for you and Clara that your kitty came home safe. Keep up the great work. _________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
jjjjack Samba Member
Joined: August 08, 2005 Posts: 1013 Location: Gainesville, FL
Posted: Fri May 27, 2016 5:57 am Post subject: Re: '61 corner window westy campingbox |
EverettB wrote: |
Did you replace the broken leafs with spares or can they be fixed?
I assume you have to replace any that are broken? |
I replaced the broken ones with good used ones.
You can buy new leaf spring packs from WW. I have not used them before. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Fri May 27, 2016 9:01 am Post subject: Re: '61 corner window westy campingbox |
"And when your found there ain't no word for glad" : It's a Beautiful Day, No word For Glad.
I had no idea there was that much involved in an early beam's bushings. Every bounce will be a payback for your dedication and expertise. |
EmpiGT Samba Member
Posted: Fri May 27, 2016 4:08 pm Post subject: Re: '61 corner window westy campingbox |
vwmike wrote: |
Welding the ends of the springs also keeps them from creeping out. I had a 58 bus and the welds broke and some of the springs in the stack were sticking out on one side about 3 inches, The grub skrews don't lock down all of the springs so they can float out.
on another note when in 1961 did they go from the beam with the v shaped support on the center pin with the upright supports to the later box shape support with no uprights to the upper tube. I have a 61 low hinge bullet bus with the later looking beam. |
Posted: Sat May 28, 2016 7:27 am Post subject: Re: '61 corner window westy campingbox |
EmpiGT wrote: |
vwmike wrote: |
Impressive stuff Greg! I think in another life you must of worked at Wolfsburg or something..... :)
I've seen that happen before. Not often.
I'm not sure when the beam changed, I have three 4/61 buses here I could check.
Front brakes are done.
I did the center pin too. |
squareweave Samba Member
Joined: November 15, 2004 Posts: 448 Location: British Columbia
Posted: Sat May 28, 2016 7:56 am Post subject: Re: '61 corner window westy campingbox |
Nice work on the hard lines! What paint (black) are you using? |
Posted: Sat May 28, 2016 7:59 am Post subject: Re: '61 corner window westy campingbox |
I love this thread. _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
rotorimp Samba Member
Joined: June 18, 2007 Posts: 253 Location: Surprise AZ
Posted: Sat May 28, 2016 8:16 am Post subject: Re: '61 corner window westy campingbox |
Really impressed with your level of detail! Keep up the good work! _________________ 1965 walkthrough Sundial |
Clara Samba Member
Posted: Sat May 28, 2016 8:21 am Post subject: Re: '61 corner window westy campingbox |
I took a couple pics of the engine compartment after it was somewhat cleaned up. The pics are a bit blurry, I think the paint is decent.
The wiring will need some tidying up.
J3 in Tennessee put new fuel lines on it (Yay! Safety!) and a new filter under the tank, when they got it running.
I did see a short video of them driving it up and down the block. It was driven onto the trailer to get here. It was driven off the trailer and into our driveway and into the garage.
It was backed out of the garage in the morning to make room to work on projects, and then driven back in at night, a number of times. (We need a bigger shop.)
Maybe a few miles at most. Look at that fuel filter.
I think the tank is nasty. It will come out and get cleaned out.
mudbucket Samba Member
Posted: Sat May 28, 2016 10:50 am Post subject: Re: '61 corner window westy campingbox |
Nice! Wondering what you are using for the front springs these days. I cant seem to find any correct springs for 62 and earlier. |
Posted: Sat May 28, 2016 1:04 pm Post subject: Re: '61 corner window westy campingbox |
squareweave wrote: |
Thanks.
Finish was two coats of PPG DPLF black epoxy primer over bare metal. Wait a day, then two coats of Glasurit single state 22 line paint - mixed 4:1 with flexible gloss reducer.
mudbucket wrote: |
As far as I know the springs are all the same for '55-'65? The '66-'67 springs might even be the same too, I've never bothered to check the lengths side by side. I've almost always have some on hand if you or anyone else are in need. |
Wexford Samba Member
Joined: January 28, 2009 Posts: 376 Location: Bristol, UK
Posted: Sat May 28, 2016 1:43 pm Post subject: Re: '61 corner window westy campingbox |
Good to see the fuel filter out of the engine bay.....(you see so many buses with filter in the engine bay on samba it makes you suspect people are partial to the flame-throwered/barbecued look).
Personally I'd have those fuel lines clipped on though.
Meant to ask earlier back...why were the ends of the beam leaves welded? Stiffness? (Am I missing something obvious?)
Keep up the good work... |
GTV Samba Member
Posted: Sat May 28, 2016 4:39 pm Post subject: Re: '61 corner window westy campingbox |
Wexford wrote: |
Look up a couple posts... _________________ EMPI Power Rules! |
