fla2smoker Samba Member
Joined: December 31, 2011 Posts: 574 Location: Parrish, Florida
Posted: Sat Dec 05, 2015 9:52 pm Post subject: What do you use to mark bad metal? |
When you cut out cancer metal. What do you use to mark the bad metal when making cuts? Sharpies, dychem and a scribe? What do you use and when? What are your recommended tools to make a mark and what type of paper or cardboard do you use to re-create the template? I have seen a lot of different methods but I am not comprehending when to use what. Looking for help from the people who do this for a living. How do you determine if the metal needs to be replaced? Do you use weld thru primer on everything? _________________ View my 66 build thread here: http://www.thesamba.com/vw/forum/viewtopic.php?t=507996 |
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Mon Dec 07, 2015 12:04 pm Post subject: Re: What do you use to mark bad metal? |
Quote: |
When you cut out cancer metal. What do you use to mark the bad metal when making cuts? |
I use Sharpie's regular point or Milwaulkee's. Scribe marks are usually too hard to see.
Quote: |
What are your recommended tools to make a mark and what type of paper or cardboard do you use to re-create the template? |
Whatever card board I pull out of the recycle bin or construction paper from walmart.
Quote: |
How do you determine if the metal needs to be replaced? |
It depends on how hard it is to replace and how pitted. If it is not really hard ,I replace anything that is more than moderately pitted and has lost strength. Body panels are not there to hold body filler to. If the area is very hard to patch I solder the pin holes/craters up.
Quote: |
Do you use weld thru primer on everything? |
You should use weldthru primer on panels that you are sealing up and can't get to the inside bead after welding. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
jason Samba Member
Posted: Wed Dec 09, 2015 4:19 pm Post subject: Re: What do you use to mark bad metal? |
I usually don't mark it, just cut it out. I then make a template with the cutout piece. Make only round cuts, no 90's. |
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Sat Dec 12, 2015 9:07 pm Post subject: Re: What do you use to mark bad metal? |
It seems if I use anything, its usually masking tape I guess. If possible, I hold the new metal behind the hole I cut and spray bomb it. Makes a perfect replica of what needs cut. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Sat Dec 19, 2015 5:55 pm Post subject: Re: What do you use to mark bad metal? |
jason wrote: |
Can I ask why you recommend this idea? What if I were to replace a rear quarter pane from below the window to the "b" pillar and to the rear fender well? A round cut would seam a bit difficult to achieve.
Just curious. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Sat Dec 19, 2015 8:51 pm Post subject: Re: What do you use to mark bad metal? |
The theory is that the rounded curve instead of a 90 degree will have a lesser chance of warping because there is less weld bead per inch. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
beetlenut Samba Member
Posted: Wed Dec 23, 2015 12:21 pm Post subject: Re: What do you use to mark bad metal? |
As to how much to cut out is usually dictated on when/where you can get back into solid uniform steel. If you don't cut out enough of the bad metal, and end up leaving some solid but thin metal, when you hit it with the welder, it will just blow a hole through it. I usually cut out bad metal until I'm into solid steel all the way around the cut, then make a cardboard template of that with any bends or angles, and trim the template until it fits perfectly. Then transfer the template onto steel. Then fit the steel replacement piece up to the car and trim multiple times until it fits perfectly. The better the steel patch/part/panel fits before you start welding, the better the finished product. _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
jason Samba Member
Posted: Wed Dec 23, 2015 1:22 pm Post subject: Re: What do you use to mark bad metal? |
Yes less warping. The tip of a 90 cut will warp easier than a curve. Also make the patch longer than end. Meaning overhang the patch if you can and cut it back. Less chance of blowthrough and the bead will extend past the end of where you want it. I cut it round and extended past the ends, then cut back.
Grind with cutoff wheel, belt sander then DA.
jason Samba Member
Posted: Wed Dec 23, 2015 9:18 pm Post subject: Re: What do you use to mark bad metal? |
Some people mark metal with sharpies or dyekem. Do you have to remove this completely before priming? How do you remove it?
Do you trust weld-thru primer to protect metal you cannot get to the backside of? For instance replacing rear bumper brackets on a type 1. The factory seemed to do a bad job of preventing rust in this area. Not really an area you can seam seal.
Danny's thread is amazing but without seeing him do a section on video I can only guess he tig welds and hammer/Dolly's the weld followed by a file. We only see the outside. How does he make sure the inside looks as perfect as the outside (no proof of replacement metal)?
I guess what i am asking for is not the before and after shots but the step by step process that the good guys use to replace metal. Maybe some don't want to give up their secrets but I think that is their ability to see and move metal. _________________ View my 66 build thread here: http://www.thesamba.com/vw/forum/viewtopic.php?t=507996 |
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Thu Dec 24, 2015 9:56 am Post subject: Re: What do you use to mark bad metal? |
fla2smoker wrote: |
How does he make sure the inside looks as perfect as the outside (no proof of replacement metal)? |
The only way I know to make a repair "disappear" is body filler. There will always be evidence of a repair (seams, weld spots) unless they are covered by filler. _________________ Everything known to man has been written.
Readers are Leaders! |
Posted: Thu Dec 24, 2015 12:08 pm Post subject: Re: What do you use to mark bad metal? |
Quote: |
Some people mark metal with sharpies or dyekem. Do you have to remove this completely before priming? How do you remove it? |
Welding removes the marker just fine.
Quote: |
Do you trust weld-thru primer to protect metal you cannot get to the backside of? |
If you have a better solution you can share it with us. I do the best job I can and then hope for the best.
Quote: |
Danny's thread is amazing but |
MIG welding with a gap is impossible to beat.
[/quote]How does he make sure the inside looks as perfect as the outside (no proof of replacement metal)?[/quote] Why would anyone care? _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
jason Samba Member
Posted: Fri Jan 01, 2016 11:57 pm Post subject: Re: What do you use to mark bad metal? |
Tig is a nicer weld. If you read some of Gab-Fab threads he does what I said. He hammers and dollies to remove the warping. If you want no evidence you have to finish the rear also. If you ever look on a Ghia, there are weld beads present under the fenders. Get it as close as you can and use a good filler primer. Block it twice and your good to go. |
buguy Samba Member
Posted: Sat Jan 02, 2016 9:22 am Post subject: Re: What do you use to mark bad metal? |
When I do this sort of work where both sides have to be nice, I simply weld as cool as I can and grind both side smooth. Then I do my filler work. Then when I spray the primer I use a pencil with an eraser. I take the eraser and push in the primer to simulate where any spot welds would have been. Finish as usual. |
Posted: Sat Jan 02, 2016 12:11 pm Post subject: Re: What do you use to mark bad metal? |
buguy wrote: |
That is dedication to the sport. I haven't heard of this idea. Creative for sure.
Good luck. _________________ I have learned over the years.
Buy Once, Cry Once!
stanovich Samba Member
Joined: March 18, 2013 Posts: 191 Location: central coast calif
Posted: Thu Jan 21, 2016 11:11 pm Post subject: Re: What do you use to mark bad metal? |
welders chalk stick for marking metal |
Posted: Thu Jan 21, 2016 11:21 pm Post subject: Re: What do you use to mark bad metal? |
stanovich wrote: |
AKA- Soapstone. You can get them at a welding supplier and maybe Home Depot.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Thu Jan 21, 2016 11:33 pm Post subject: Re: What do you use to mark bad metal? |
yep soapstone. did'nt think the youngsters would know it by that name so, chalk |
