JasonBaker Samba Member
Joined: February 08, 2010 Posts: 1642 Location: Cleveland, TN
windfish Samba Member
Posted: Fri Dec 11, 2015 2:54 pm Post subject: Re: Emergency Heater for Home Use |
Got a Kerosene heater like this one -
www.amazon.com/gp/product/B000ITQ5DY/
Infact I think the one I have now is a DuraHeat.. I don't remember paying that much for it, but I guess it's possible.
Works great, heats a large amount of air quickly with just a touch of odor.
Got a 5 gallon fuel container I top off at the start of winter, Kerosene seems to store quite well. |
cbeck Samba Member
Posted: Fri Dec 11, 2015 5:30 pm Post subject: Re: Emergency Heater for Home Use |
I've used a single head that goes on top of a bbq propane tank. What I use now is a genny plugged into dryer outlet after main breaker is thrown off. I turn off all breakers except propane furnace and a circuit upstairs for tv , light, coffee maker, and fridge. Can't turn all on at the same time, think its only a 5k watt generator. Can't stress throwing the main enough, Don't want to electrocute a lineman or feed neighbors house. My propane furnace only needs enough juice to power board and spin both blowers. |
crukab Samba Chef
Joined: December 13, 2002 Posts: 6116 Location: Vermont
Posted: Fri Dec 11, 2015 6:54 pm Post subject: Re: Emergency Heater for Home Use |
I just keep enough wood on hand to stay warm...... _________________ Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'82 Rabbit Truck Diesel from CALI
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Sat Dec 12, 2015 6:06 am Post subject: Re: Emergency Heater for Home Use |
Have an LP Mr Heater Torpedo for the shop....Only use it in my one extra bay that is well vented....The ones that say outdoor use really give off the fumes.
That being said - we live out in the woods and have had power outages for days. I have a couple kerosun type heaters and coleman lanterns. Thats fine for a few hours or overnight, BUT any longer and you need to worry about your refrigerator etc (BTW - when we have a power outage, the fridge and freezers stay closed unless you absolutely positively NEED something out of them.)
What I did a couple years ago was get a portable 1800 watt generator. I installed a reverse receptacle on the hot side of the furnace switch box. When I loose power, I flip the switch off to the furnace so I am disconnected from the house wiring, run 2 extensions cords into the house - one to the furnace and one to the kitchen for a couple clamp lights and the fridge.
Having lights and real heat is MUCH nicer than dicking around with kerosuns and lanterns. And with 4 or more VWs sitting in my storage garage with full gas tanks means I can run for a couple weeks.
I also recently had an automatic backup generator installed at my one business to power lights, servers and computers.. Was less than I expected - about $6K all in, including the propane tank.
Seriously consider going this route - till you are done buying and messing with heaters and lanterns, you can have a generator. _________________ D-Dubya Manx clone - 63 Short pan,1914.
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sat Dec 12, 2015 7:37 am Post subject: Re: Emergency Heater for Home Use |
Living in in the sticks, I feel your pain.. Sporadic power outages can be be rampant.
If you have Natural Gas at your home disposal that's the simplest albeit expensive fuel option. Buy a wall mount, install properly, have connected, burn and pay the bill.
If you already have a Propane tank for other appliances thats another easy option. Wall mount, tank mounted, or slip on a hose.. and you're hot.... but, BE SURE its rated for INDOOR use (ONLY).
Some of those propane units put off some awful bad fumes. Even the so called vent less. Avoid the ones that say indoor and outdoor..
Most of us have a gas grill right?? Its pretty simple and practical to have a tank mounted unit at your disposal..but most are outdoor only so take caution.
Thanks to our rural area... we have neither of those fuels (in large capacity) at our home... so we have had to always think about other sources.
IMO, its hard to beat a good Kerosene indoor rated heater for emergency quick home heat.
The fuel is easy to find, relatively inexpensive, you can pump and supply it yourself and it stores well for about six months, sometimes longer.
They can give off bad fumes though ..
I have a small one... just in case as well as a small propane tank mounted unit.
Just be sure any portable appliance is safely used and always think about asphyxiation. A GOOD Carbon Monoxide detector is vital when using any fuel source for home heating.
I always flush the house after a while of any fuel heating use.
Wood heat is simple and inexpensive AFTER the main investment of wood burning capability added.
It is hard work to source, supply and takes effort to keep it burning. Not for the lazy.
When we were designing and building our home 15 years ago, I was adamant regarding incorporating a REAL masonry fireplace in the main living room as well as a masonry flue for a standing wood stove in the cellar.
The long haired chief wanted gas logs... sooooo $500 + later investing in a 100llb cylinder, regulator, tubing, logs... we started with "vent less" propane gas logs in the main. Great instant heat but it left a bad taste in the air I didn't trust or like. Plus it was costing about $100 (then) a month to refill a portable cylinder that I had to tote to have filled.
My wife loved them though .. flick, spooof.. instant warmth..
I was given a nice standing Buck (with blower) for the cellar from my father in law, but frankly its a pain to keep it hot and fed enough to warm our whole open floor plan loft home from the bowels bellow which were my intentions.. .. When he had it in his home, it was placed so the main HVAC fan pulled heat right off the stove. Great idea, and it worked well in that application, but it has a small ash box so he ..well ..really my mother in law had to deal with it daily. So thats how I got it.. .. He.... she was right.. shallow ash box and have to clean it out daily..
When I finally had my shot I traded my Pop our gas logs for his Dove stove 4 blower insert as he had stopped using it in his senior years. That damn thing heats hotter than the gates of hell. When we were kids we would wear shorts just to stay cool at home when Pop had it cookin'..
I installed it in out main fireplace. Use it when needed or wanted and it heats great and has a removable ash drawer that I simply dump and and done..
Ugh..grunt... man says.. fire good.. women says.. keep it hot and keep it clean.
I agree.. with some of the above statements regarding generator back up power. If the power is out for more than about 8 hours then we start to get nervous about loosing food that is stored cold or night time cold temps in the winter.
(Damn overhead power lines)
I back feed our home with an 8500 Watt generator via an Arc Welder outlet tied into the main service panel outside. It is CRITICAL to open the main service breaker for safety before attaching and applying your generator power. Plus knowing what can and can not be used at a given available wattage. We use it mainly for refrigerators, freezers, a couple of lights, well pump or water heater (one at a time), and of course.. the wood stove blowers when it's cold..
In reality.. . a full generating back up unit installed price has dropped over the years..
If you have a tractor with a PTO.. a PTO generator is a great and inexpensive alternative if it has enough HP to turn it.
It amazes me daily.. how our forefathers survived with nothing we have today and how anything was accomplished without machinery.
It took guts, brawn, know how and drive.. something few of us can compare with today.
It just goes to show how spoiled we all are ...
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
johnnypan Samba Member
Joined: October 24, 2007 Posts: 7431 Location: sackamenna
Posted: Sat Dec 12, 2015 10:49 am Post subject: Re: Emergency Heater for Home Use |
gt1953 Samba Member
Posted: Sun Dec 13, 2015 8:08 am Post subject: Re: Emergency Heater for Home Use |
Johnny what is the BTU output of that device? _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Sun Dec 13, 2015 8:49 am Post subject: Re: Emergency Heater for Home Use |
gt1953 wrote: |
Johnny what is the BTU output of that device? |
it appears to be four candlepower...
https://www.youtube.com/watch?v=zCAfAT9MVrY |
lovethatconvertible Samba Member
Joined: August 22, 2008 Posts: 1434 Location: Las Vegas N. V.
Posted: Sun Dec 13, 2015 7:06 pm Post subject: Re: Emergency Heater for Home Use |
Johnnypan, "keepin' it Green" _________________ 1960 Convertible |
mark tucker Samba Member
Posted: Sun Dec 13, 2015 10:49 pm Post subject: Re: Emergency Heater for Home Use |
I just installed a duel fuel fireplace in my home last winter,works awesome, I run it off a bbq propane tank, I got it on clearance at homers depoet on clearance after winter. it was $699.00 I think I paid about $100.it was the display,pretty oak cabnet hearth what ever you call it. I might use a tank this winter last was cold and I used 3 tanks, but....it realy wasent that cold I just like a fire place.(yes I got very cold below 20 drgees) I added a fan assy from ebay for about $65 that makes a big differance.
as far as the ones you listed....possiably the top one if it will do what you want.I dont like the tank mounted ones if you have kids or animals or old or decrepid .....(that would be me) |
Posted: Sun Jan 08, 2017 8:09 am Post subject: Re: Emergency Heater for Home Use |
Bringing this back up for the season.. to make and inquiry..
We had a nice snow storm for NC. and last night it was 6 degrees F.... (brrrr) and my home was nice toasty 68 with our good ole tried and true Dove stove cooking.. overnight. ... but as usual.. its starting to dry the air out...
I use a humidifier over night, as well as pot of water on the stove, ...plus .. the Dove has a built in tank humidifier that I will occasionally add water to (yet to this round).
For those who use gas or wood or.. any other air drying fuel to heat your home.
What methods do you use to keep the air moisture levels up ..in your home .....the best?
Usually and often edited |
Posted: Sun Jan 08, 2017 12:32 pm Post subject: Re: Emergency Heater for Home Use |
bathtub full of water.....(we do this in motels and hotels). depending on how your heating system is set up, there are various humidifiers that can be attached and plumbed. _________________ D-Dubya Manx clone - 63 Short pan,1914.
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20279 Location: Sandpoint, ID
Posted: Sun Jan 08, 2017 5:14 pm Post subject: Re: Emergency Heater for Home Use |
We mainly heat with a centrally located wood stove, but also have a gas forced air furnace in the attic. Our house gets pretty dry in the winter, especially with the furnace. There is always a pot of water on the wood stove, and there is almost always a window cracked in the kitchen. My wife will often have a big pot of water on the cook stove to add moisture if it gets really bad.
Interestingly, in reading the previous posts in this thread, I noticed mention of the expense/lack of availability of natural gas and the relative opposite for kerosene. That is the exact opposite of my experience around here. Natural gas is pretty cheap, and almost universally available except for the most rural areas. Kerosene is pretty expensive, with only one local bulk distributor. For about six months in 2015 they did not have any at all. I only know this because an acquaintance of mine heats his greenhouse in the fall with kerosene. He spent a huge pile of money that year having it shipped in. His greenhouse is too far for electrical service to make sense, and propane emits way too much moisture. _________________ nothing |
my59 Samba Member
Joined: August 13, 2003 Posts: 3793 Location: connecting the dots
Posted: Mon Jan 09, 2017 4:50 am Post subject: Re: Emergency Heater for Home Use |
Some PO installed wood/coal burning hot air furnace and ducted the first floor of the house.
It will draw without the forced draft fan on once hot enough, and without the circulating fan on the heat will rise through the ducts. It does the job for power outages, and I keep a half ton of anthracite on hand for emergencies. Not real comfortable but will prevent the pipes from freezing
The main system is steam radiators and a boiler fired with oil. Ugh.
Best system we ever had was in NYC- natural gas fired hot water boiler supplied the hot water and hot water heat system. The piping for the system was 3" pipe connected to cast iron radiators, and the pump never ran, as the system would circulate via convection. The boiler was old enough to run on pilot light, so when power went out no problems. This was a 4 story 20 by 35 town house, so the here were only 2 walls exposed and 2 heat loops. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
Posted: Mon Jan 09, 2017 7:45 am Post subject: Re: Emergency Heater for Home Use |
cdennisg wrote: |
Interestingly, in reading the previous posts in this thread, I noticed mention of the expense/lack of availability of natural gas and the relative opposite for kerosene. |
Yep.. once you get outside the main cities around here..
No Natural gas.. no water or sewer..
Kerosene is at just about every fuel station, even the Mom and Pop places.. .. and it can also be found in gallons at the hardware..
My neighbors were bragging right after his home was built about his low electric bill ..and warm home ...until he got the first Propane tank fill bill... and..not to mention the times.. the tank went dry.. right in the middle of an ice/snow storm...
My home is all electric.. and yes.. the E bill has some spikes Dec-February..
I think if I were to compare.. my all electric bill to another's combined gas/electric bills in a year.. .. it would even and average out.
Plus I don't have to worry about a hot water heater or gas appliance destroying a home.. with an explosion..
But all Electric it has its drawbacks too..
One things for certain.. you cant compare good gas/wood heat.. to a freezeme-heat pump.. Once it gets below freezing.. the air delivery can be chilly and starts with electric strips/coils to assist.
Then the whole defrost cycle.. which is essentially air conditioning for 10 minutes.. which ...S.U.C.K.S
Its simply amazing the difference in "feel" of the hot (wood or gas) heated air. even if the temperature in the house is the same..
If I were home more.. it would be wood heated more.. ..
Posted: Mon Jan 09, 2017 6:58 pm Post subject: Re: Emergency Heater for Home Use |
We are blessed to have all natural gas,heat, stove, dryer, you get the picture. last year the price of gas actually went down, and if we have a power outage, we can light our fireplace insert with a match. Keeps the whole place warm enough, since we over insulated it. |
Posted: Mon Jan 09, 2017 9:48 pm Post subject: Re: Emergency Heater for Home Use |
if it gets too dry I run the shower on full hot for 5 minuts & let the h2o stand in there. when I was in switzerland 2 weeks ago they had solor heaters and oil fired for the heat.if the sun is out the solar was all that was needed is what he told me...otherwize the oil fired one does just fine. houmoungus water tanks, one for the oil&one for the solar under the house in the parking garage.pretty sweet setup, the house was always warm. |
