nshaddox Samba Member
Joined: January 18, 2005 Posts: 612 Location: Hammatramma, MI
Posted: Sat Aug 13, 2016 6:57 am Post subject: Re: Neil's bubbletop volksrod build |
Pretty sure you are describing the other plate for adjusting the clutch and brake pedal stops. I'm just looking for location on pan to weld gas pedal pivot.
I adjusted a brake pedal pushrod once. Everything got fuzzy for a minute, but then I came up with the idea for this build. Not really sure what happened but I'd say there were no ill consequences. |
caleb0101 Samba Member
Joined: August 26, 2014 Posts: 524 Location: Bristol Connecticut
Posted: Sat Aug 13, 2016 7:04 am Post subject: Re: Neil's bubbletop volksrod build |
On my 60 it's about 1 inch from the side of the tunnel to the edge of the bracket and about 6 and 3/4 fron the bottom of the fire wall to the front face of the bracket _________________ Ruby red 1967 beetle sedan with a 2021cc
1967 beetle sedan baja project
April 60 euro spec ragtop beetle with a 1641cc |
Posted: Sat Aug 13, 2016 7:48 am Post subject: Re: Neil's bubbletop volksrod build |
Awesome. This is based on a 60 too so that should get me close with the intended pedal assembly. Face is pretty perpendicular to the tunnel correct? |
Posted: Sat Aug 13, 2016 7:51 am Post subject: Re: Neil's bubbletop volksrod build |
Yea I'm not sure why I haven't cut it off my car yet as I have a roller pedal and never plan on taking it off. What's your plan for tail lights? _________________ Ruby red 1967 beetle sedan with a 2021cc
Posted: Sat Aug 13, 2016 8:02 am Post subject: Re: Neil's bubbletop volksrod build |
almost went roller. how do you like that by the way?
pretty sure I posted tail light plan way back, but I have an old stop light from a wrecker that I made a pretty large teardrop housing for. plan is to set it up so that top and bottom are tail light and stop band in middle is brake light. not sure how I will do that yet or what to do about turn signals. |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11055 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sat Aug 13, 2016 9:50 am Post subject: Re: Neil's bubbletop volksrod build |
^ good rollers are good.. Cheap rollers are shit..
You may want to consider a 66 up cast pedal assembly.. it has the bracket for the throttle pedal cast into it.... and its much much more stable.
nshaddox wrote: |
Think trailer...and American... cancel the stop and activate turn side selected.
No harm in the stop band blinking for turn .. IMO ..
And note..
Usually the White wire labeled "56" on a turn switch is a high beam dimmer signal wire for a dimmer or passing relay circuit.
Black "56".. is most likely ground (or power) input for said turn switch contact 56 white.
Easily tested and verified with an Ohm meter or continuity device ..
If you have other plans for a dimmer.. just omit and proceed. Just passing it along..
The other colors "should" be as you suspect...
Hopefully the switch is good..
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Sat Aug 13, 2016 11:34 am Post subject: Re: Neil's bubbletop volksrod build |
nshaddox wrote: |
And sorry about me not really reading the question - not enough coffee this morning.... _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Sat Aug 20, 2016 8:54 pm Post subject: Re: Neil's bubbletop volksrod build |
been doing little things after work that have to be done but aren't so interesting to look at. installed rear axle bearings and all brake hardware other than ebrake cable. replacing some old hardware with new hardware. bolted engine up after installing clutch and pressure plate. got throwout arm and new bushings and bearing installed in transaxle too, also put some oil in it. have to figure out what to do with dipstick, stock t3 stuff not gonna work, empi adapter for universal case is total garbage and also wont work with t3 shroud. still lots of little tweaks to do on engine tins and then have to get them powder coated.
some pictures, my camera is getting progressively worse, will be replacing soon.
looks pretty close to the original sketch. pretty happy about that. tires are just for mock up, still need to order rear ones and also figure out how to convert the t3 to alternator setup. |
VeeDubWolf Samba Member
Joined: July 12, 2010 Posts: 656 Location: Yakima, WA
Posted: Sun Aug 21, 2016 3:12 am Post subject: Re: Neil's bubbletop volksrod build |
That mock-up looks good! It'll look even better on the road! _________________ Two Bugs-
'70 rust-bucket sunroof sedan
'69 PO hack-job special
-Plus a wide assortment of various parts'n'junk |
finefettle Samba Member
Joined: October 13, 2006 Posts: 699 Location: Shelburne,Vermont
Posted: Sun Aug 21, 2016 7:47 pm Post subject: Re: Neil's bubbletop volksrod build |
George Jetson eat your hart out!
To cool. |
Jacks Samba Member
Joined: July 15, 2006 Posts: 2347 Location: San Clemente, Ca.
Posted: Mon Aug 22, 2016 4:02 am Post subject: Re: Neil's bubbletop volksrod build |
Big Daddy would be proud....Really coming together....So how long did you walk around and just look at it? When I hit that stage, it's usually and hour or two....and my wife walks in and asks what I am doing...I'm working . _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Mon Aug 22, 2016 11:49 am Post subject: Re: Neil's bubbletop volksrod build |
probably 3hrs of staring and thinking for every one hour of work actually done. its all just little jobs left, but the little jobs are the ones that take forever because you have to worry about all the different ways to tackle the little problems and decide which one is best. and the details are what make a build really, so trying to not screw it up at this stage. also struggling to remember all the details from the engine build from 5 yrs ago. i know i left rocker arms off and plugged all holes for the storage, but was surprised to relearn that I'd tapped the two holes next to the fan end of the crankshaft oversized for step studs since they were messed up. vaguely remembered modifying some step studs for the fan housing, but figured I would never find them and spent a couple of days looking for metric step studs at local hardware stores after work. finally found some and modified them and found the ones I'd turned down on a lathe 5 yrs ago within 6 hrs of installing the new ones, go figure. 5yrs and 1500 miles later...
lots of little issues like that. can't even decide if i like the way this car is looking or not right now. either sick of looking at it or thrown off by the knobbies in back or freaked out by how close it is to my original sketch, but I just keep thinking it looks impractical and cartoonish, which i guess is true. guess i just gotta keep working on it. |
Posted: Mon Aug 22, 2016 1:03 pm Post subject: Re: Neil's bubbletop volksrod build |
nshaddox wrote: |
Yep.. which.. makes it stand out even more from all the rest..
Not a bad thing.. IMO..
Cry me a river will ya..
If you were going for practical. .. and bland.. .. you could have saved alot of time and bought that at the corner car lot..
You've seemed like you've moved faster and more efficiently than some of the best in the business that have the $$ and a team at their disposal..
Keep at it.. Take a break.... sure.... just DO NOT stop.. too many good Kustom car beginnings have gone the way of the DoDo that way..
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1425 Location: Toronto, Ontario. Canada
Posted: Mon Aug 22, 2016 5:47 pm Post subject: Re: Neil's bubbletop volksrod build |
Check out building a sedan delivery in the 58 to 67 type one crowd. Grampa Pete used a type 3 motor for his craft and had the same issues you had.
Your ride is still tops for me. Keep up the great work _________________ I think he meant "rare", as in "not well-done" |
Posted: Mon Aug 22, 2016 6:20 pm Post subject: Re: Neil's bubbletop volksrod build |
Something I was taught a long time ago is to keep notes because you will forget. Whenever I start on a car - whether one of mine or a customers, I have a spiral bound notebook. If a total build, I use a 5 subject one and break it into catagories, like parts orders, general build notes, hours/work done, etc.
We all have good intentions to get a project done from start to finish in a timely manner....Then life interferes. So, on my hours/work, I may or may not track time for my own, but I have a summary for work done that day such as: 8/17 5 hrs - front brakes - all new, rear brake shoes and hardware only, new rear bearing seals. replaced drivers front hard line. Painted misc interior parts.
This way if its a year before I get back to it, I can scan my log and see "oh yeah, already did the brakes....." _________________ D-Dubya Manx clone - 63 Short pan,1914.
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4186 Location: Pasadena CA/DTLA soon China
Posted: Mon Aug 22, 2016 8:37 pm Post subject: Re: Neil's bubbletop volksrod build |
Are you building The Homer?
_________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
NON INFLUENCER APPROVED |
Posted: Tue Aug 23, 2016 7:17 am Post subject: Re: Neil's bubbletop volksrod build |
indeed. except the homer was a much more practical and less attractive vehicle. real inspiration is closer to Ed Roth's Beatnik Bandit or Starbird's Predicta.
People that call it a homer lose their invitation to copilot... |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4919 Location: Southern AB
Posted: Tue Aug 23, 2016 7:58 am Post subject: Re: Neil's bubbletop volksrod build |
This is awesome!
I keep hoping for some 50's fins to show up on the tail for that Rocket age look to go with the bubble top
_________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
HeidelbergJohn4.0 Samba Member
Joined: March 01, 2004 Posts: 1199 Location: Havre de Grace, MD
Posted: Mon Aug 29, 2016 7:45 am Post subject: Re: Neil's bubbletop volksrod build |
I just want to see you push it out of the garage and take a few pictures of it. _________________ 71 LWB Manx style dunebuggy
71 Beetle
71 Volksrod
Machette Speedster
2012 Passat TDI SE (sadly sitting in a buyback parking lot somewhere waiting for it's heart to be ripped out.) |
