revD Samba Member
Posted: Thu Dec 24, 2015 11:08 am Post subject: Trans code list? |
Hey,
I am gonna pick up a tranny in a couple days and just want to verify whatever code is on the side, I have looked at the below list before but it now seems in-active. I regret not saving the sheet - but does anyone have the trans code listings saved? I am looking for the 5spd codes.
TIA !
http://www.brick-yard.co.uk/VehicleSpecific/T3/info/gbx.htm _________________ Current:
87 Sunroof - weitec springs, 17x7.5 et35 KT1 - 265k on original drive-train
past:
'85 DOKA - 1.9l of fury
http://doka-d.tumblr.com/ |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12008 Location: Santa Cruz, CA
hdenter Samba Member
Joined: October 14, 2008 Posts: 2754 Location: San Luis Obispo, CA
Posted: Thu Dec 24, 2015 11:52 am Post subject: Re: Trans code list? |
I use the one from Shaw. It's not as complete a list, but it has a calculator built into it that let's you plug in different tire sizes and gear ratios to get mpr. I don't have it on my phone, I'll post the link when I get home if no one else has beat me to it.
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
Posted: Thu Dec 24, 2015 4:31 pm Post subject: Re: Trans code list? |
http://www.google.com/url?sa=t&rct=j&q=&am...Sy_QPUp8Yw
Try this link for the trans ratio chart and calculator. I have spent hours running different combinations of tires sizes and gear ratios in search of what I want for my vans.
'84 sunroof vanagon
'85 weekender |
revD Samba Member
Posted: Fri Dec 25, 2015 4:58 pm Post subject: Re: Trans code list? |
Thanks all!! Perfect. _________________ Current:
past:
Syncrozilla Samba Member
Joined: September 11, 2004 Posts: 772 Location: Santa Barbara
Posted: Mon Jan 30, 2017 9:42 pm Post subject: Re: Trans code list? |
Does anyone know where there is a current comprehensive list of T3 trans codes/gear ratios? All the links above are now dead. Except the T3 one which does not list front diffs. I can no longer find the one that used to be on club 80/90. _________________ Please do not message me on TheSamba. Use my email, [email protected] |
kamzcab86 Samba Moderator
Posted: Mon Jan 30, 2017 10:55 pm Post subject: Re: Trans code list? |
Thanks Kammy. Unfortunately none of those list the syncro front diffs which is what I'm looking for
The club 80/90 had that info but I think it's gone now. I should have printed it out and stuck it in my bentley. _________________ Please do not message me on TheSamba. Use my email, [email protected] |
BavarianWrench Samba Member
Joined: January 18, 2004 Posts: 1045 Location: Oceans Edge
Posted: Tue Jan 31, 2017 1:15 am Post subject: Re: Trans code list? |
Thanks Kamz
that is a lot of info, I never stumbled across such a clearly laid out list before.
Well done
dobryan Samba Member
Joined: March 24, 2006 Posts: 16508 Location: Brookeville, MD
Posted: Tue Jan 31, 2017 11:52 pm Post subject: Re: Trans code list? |
dobryan wrote: |
Any way to post that spreadsheet on this topic for future reference? |
Working on a complete document that will combine all of the above-posted links... stay tuned. _________________ ~Kamz
2016 Golf GTI S
Posted: Fri Feb 03, 2017 4:15 pm Post subject: Re: Trans code list? |
kamzcab86 wrote: |
dobryan wrote: |
Working on a complete document that will combine all of the above-posted links... stay tuned. |
Many, many, many hours' worth of work later, here it is:
T3/T25/Vanagon Transmission Specs
If anyone sees errors, or can fill in some of the blanks, let me know.
2016 Golf GTI S
Posted: Sat Feb 04, 2017 6:58 am Post subject: Re: Trans code list? |
Kamz nice effort, Thanks. |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
J Charlton Samba Member
Joined: August 24, 2007 Posts: 1546 Location: The True North Strong and Free
Posted: Sat Feb 04, 2017 12:40 pm Post subject: Re: Trans code list? |
here they are - pretty much every vanagon gearbox - you can use google translate for German to English but its pretty self explanatory
http://www.t3-infos.de/images/T3-Getriebe.pdf _________________ NAHT hightop availability May 18 2023 -
Bend Oregon - for Oregon, California- (7 tot , 3 available), Kennewick Wa (6 tot, 1 available), Small Car Performance Fife Wa. (7 tot 4 avail ), Fairbanks Alaska (1 tot 0 avail)
Future availability TBD : Springfield Mass. Staunton Va, Florida, Colorado, Grand Junction Co., SLC probably late 2024 |
