nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3776 Location: Twin Cities, MN
Posted: Mon Jan 04, 2016 1:39 pm Post subject: Finishing the bed |
What tricks have people used to sand down the bed of a DC or SC? With the corrugations it's no easy task to sand the area.
Has anyone made a sanding block to fit the shape? I thought about trying to find a chunk of an original bed to use but don't have access as I'm sanding the original bed.
Other ideas? |
Braukuche Samba Member
Posted: Mon Jan 04, 2016 2:05 pm Post subject: Re: Finishing the bed |
nlorntson wrote: |
Other ideas? |
Use a chemical stripper if you intend to take it down to metal. If you are doing bodywork they make round blocks that might fit. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1973 Ghia convertible |
Posted: Mon Jan 04, 2016 2:11 pm Post subject: Re: Finishing the bed |
It's down to metal right now. I'm using some high build primer to fill in some of the smaller rust pits and would like to sand this.
I've tried various shapes and it takes the top "corners" off __/ \__/ \__ and misses the bottom ones if that makes sense.
I wonder what glideking used to smooth out his bed? |
Malokin Martin Samba Member
Posted: Mon Jan 04, 2016 2:31 pm Post subject: Re: Finishing the bed |
nlorntson wrote: |
It was a semi-sketchy guide plate welded to an angle grinder. It's somewhere in his thread. |
Schwing Samba Member
Joined: May 10, 2009 Posts: 2506 Location: Centreville, MD
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Jan 04, 2016 3:02 pm Post subject: Re: Finishing the bed |
You can build all sorts of custom sanding blocks from a dense foam camping mat and krazy glue. Another option I use for the one offs is the blue or pink insulation foam, stick a few strips of coarse paper to whatever you want to sand, rub the block of foam on it until it matches the profile then stick your sandpaper to the newly shaped foam. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4561 Location: St Charles, MO
Posted: Mon Jan 04, 2016 4:00 pm Post subject: Re: Finishing the bed |
On my Double-Cab restoration, we made a few properly shaped blocks of wood, similar in shape to a wood slat, to fit down into the corrugated bed grooves, wrapped it in various grits of sandpaper and it worked great! Rough on the hands, but awesome on the bed grooves.
build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=545000
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
V-Dub Guy Samba Member
Posted: Sat Jan 30, 2016 9:41 pm Post subject: Re: Finishing the bed |
OK, another detail question for anyone who has installed the wood slats. What does the front end look like? Squared off or angled like the rear edge?
Also how far from the front of the bed should they be? Flush? A gap? How much?
Pictures would be awesome. Especially from Bullibill
Thanks! |
glideking Samba Member
Joined: February 02, 2013 Posts: 990 Location: California
Posted: Thu Feb 04, 2016 8:38 pm Post subject: Re: Finishing the bed |
nlorntson wrote: |
Thanks! |
Does anyone have a picture or time to take a measurement of your original slats? |
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2190 Location: UK (South)
Posted: Fri Feb 05, 2016 6:22 am Post subject: Re: Finishing the bed |
nlorntson wrote: |
Have a look on dropgates.com. Dimensions and info about the profile etc of the slats are on there under Restoration Help/Info > Bed slats _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
Posted: Fri Feb 05, 2016 6:47 am Post subject: Re: Finishing the bed |
Who.Me? wrote: |
nlorntson wrote: |
Have a look on dropgates.com. Dimensions and info about the profile etc of the slats are on there under Restoration Help/Info > Bed slats |
Been there, done that. Could not find what I'm asking about. Maybe I missed it. |
Posted: Fri Feb 05, 2016 6:53 am Post subject: Re: Finishing the bed |
nlorntson wrote: |
What measurement are you looking for?
This is what it says on dropgates...
SLAT SPECS:
Single Cabs: Slats are 1 1/4" wide by 5/8" thick. There are 15 slats total.
2 different lengths are needed: 5 of them are 8foot 1 1/4". The other 10 are 8foot 5 1/2". They go in every other space on the bed.
Double Cabs: Same as above except the lengths are different. 10 Long ones are 69" and the 5 short ones are 64".
Or are you looking for something else? _________________ Andy
Posted: Fri Feb 05, 2016 9:34 am Post subject: Re: Finishing the bed |
nlorntson wrote: |
Pictures would be awesome. |
Mostly the amount of gap between the slat end and front wall of the bed. |
coolerthanelvis Samba Member
Joined: June 30, 2003 Posts: 924 Location: San Diego, CA
Posted: Fri Feb 05, 2016 12:16 pm Post subject: Re: Finishing the bed |
Looks like they taper off at about the same spot as the metal ridges. Photo credit: Sam_W
_________________ Shawn
SV2s member #420
'68 Westy
"Do or do not, there is no try."
-Silent Bob |
Posted: Fri Feb 05, 2016 1:58 pm Post subject: Re: Finishing the bed |
coolerthanelvis wrote: |
Just the info I was looking for. Thanks. |
