roadmenace Samba Member
Posted: Wed Jan 20, 2016 7:08 pm Post subject: Mexi Beetle starting issues |
Hi guys!
My Mexican Beetle is getting worse and worse. When I bought it, it had trouble starting if it would sit more than one day. It would crank, but nothing. Now the problem got worse. If I leave the engine off for an hour, it doesn't start.
If i spray starting fluid in intake, it "starts". But only till the starting fluid is gone. It need at least 2 minutes of cranking and swearing till it starts. And then it runs well, it revs, it's not sluggish ...
What can it be? I changed the fuel filter and nothing improved.
Thank you! |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17285 Location: Left coast, Canada
Posted: Wed Jan 20, 2016 9:50 pm Post subject: Re: Mexi Beetle starting issues |
Fuel pump.
What is your fuel pressure? _________________
Posted: Thu Jan 21, 2016 3:19 pm Post subject: Re: Mexi Beetle starting issues |
I can't measure the fuel pressure.
I will take the pump apart next week and try to clean it, hope it will work. |
Posted: Sat Feb 06, 2016 12:28 pm Post subject: Re: Mexi Beetle starting issues |
I changed the fuel pump and things got better, thank you!
Still doesn't always start at the first try, but the second one is always good. I think I'm gonna change the whole fuel line just to make sure is new and nothing wrong with it. |
hopkin Samba Member
Joined: June 25, 2012 Posts: 2480 Location: Ottawa, Ontario
Posted: Sat Feb 06, 2016 2:05 pm Post subject: Re: Mexi Beetle starting issues |
Also change the gas filter underneath the car. _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (current)
2017 Dune Edition (daughter's car) |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24735 Location: Olympia Wash Rinse & Repeat
hopkin Samba Member
Posted: Sat Feb 06, 2016 5:33 pm Post subject: Re: Mexi Beetle starting issues |
There are schematics for the Mexi-Beetles on www.1600i.de _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
