What is this max buggy worth
Page: Previous  1, 2, 3  Next
didget69
didget69 is offline
PostPosted: Mon Jan 25, 2016 5:37 pm    Post subject: Re: What is this max buggy worth Reply with quote
Moving forward with a modern drivetrain & Corvair rear suspension seems like going backwards...
bnc
I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door.
GS guy
GS guy is offline
PostPosted: Mon Jan 25, 2016 6:27 pm    Post subject: Re: What is this max buggy worth Reply with quote
The Corvair transaxle is an integral part of the Corvair rear suspension, in both guises - swingaxle and IRS. The early model SA is similar to the VW SA in operation - the transaxle provides the inner axle pivot points. The later model IRS uses the transaxle to axle pivot joint as a combination inner axle pivot and as a suspension "upper link" pivot - similar to the Mako Corvette and early Jag rear. Most other transaxles are not designed to take suspension loads at the transaxle carrier like the Corvair, although I've heard of using the "overbuilt" 930 Porsche trans for this purpose.
This makes it difficult to "adapt" just about any other rear-engine transaxle to the Corvair rear suspension. You have to design and install suspension pivot points and upper links not depending on the transaxle for support (the lower links are present in the Corvair design).
I personally think the Subaru 5 and 6-speed transaxles would make awesome replacements for the Corvair trans, especially with the availability of the reverse R&P gears. Just needs a bolt-in or simple weld-in design subframe for the upper suspension links and a modified trailing arm to accept the upper link. Same for any FGB based on a Corvair suspended chassis. I'd bet the guys at Subarugears would tool up for a Corvair (engine) to Subaru trans adapter and flywheel if there was enough interest. They seem eager to adapt the Suby engine and gearboxes to a multitude of applications.
Jeff
70's vintage Deserter GS buggy - undergoing transformation to Super GS!
Dale M.
Dale M. is offline
PostPosted: Mon Jan 25, 2016 8:56 pm    Post subject: Re: What is this max buggy worth Reply with quote
EVfun wrote:
Has anybody converted a Corvair rear chassis setup to take a Subaru transaxle?
If a Subaru transaxle is used with either a Subaru or Corvair engine then no reversal should be needed.
Subaru transaxle is for front engine....
Dale
“Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
EVfun
EVfun is online now
PostPosted: Mon Jan 25, 2016 11:15 pm    Post subject: Re: What is this max buggy worth Reply with quote
You mean these Subaru engine and transaxle swaps into Bugs all require a custom ring and pinion? I thought the Subaru engine turned the opposite direction. Embarassed
Wildthings wrote:
BL3Manx
BL3Manx is offline
PostPosted: Mon Jan 25, 2016 11:43 pm    Post subject: Re: What is this max buggy worth Reply with quote
Subarus turn the same direction as almost everything other than Corvairs and 928 Porsches, but when you put a front Subaru transaxle in back it requires a different ring and pinion, the ring gear can't be flipped
tgodber
tgodber is offline
PostPosted: Tue Jan 26, 2016 1:05 am    Post subject: Re: What is this max buggy worth Reply with quote
Is the body the same dimensions as a Manx. Would it fit a VW pan or are you stuck with the Corvair setup?
My buggies are not restored. It was a matter of putting the project together with quality parts and end up with a reliable fun buggy.
Some are into restoration. Not me personally.
My wife said I never listen to her.
Or something like that!
joescoolcustoms
joescoolcustoms is offline
PostPosted: Tue Jan 26, 2016 8:08 am    Post subject: Re: What is this max buggy worth Reply with quote
The Suby trans is turned around backwards from normal configuration, so it still has to be reversed to work. The suby and VW engine have the same rotation, the corvair rotates the opposite direction.
Bad News Racing 2018 NORRA 1000 3rd in Class
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
BL3Manx
BL3Manx is offline
PostPosted: Tue Jan 26, 2016 9:36 am    Post subject: Re: What is this max buggy worth Reply with quote
That's not something I'd consider a disadvantage. This is Mike McCrae's Classic Manx with an all Corvair drivetrain, 4-spider, posi, 3.89. Holley 4-barrel with heated plenum manifold.
How about a 5 speed
http://aboxer.tripod.com/
didget69
didget69 is offline
PostPosted: Tue Jan 26, 2016 10:20 am    Post subject: Re: What is this max buggy worth Reply with quote
The Subaru transaxle rotated 180-degrees about the Vertical (think - installed like a VW Type 1 trans) would not require a R&P flip to work with a Standard-Rotation (CCW at the crank pulley) Corvair engine...
Now - let the debates begin regarding the strength of the Subaru gears running 'backwards'... Laughing
For me? I'd look to using the cheap 5-speed transmissions from a FWD Passat/Audi A4 in back of a buggy if the desire was to use a Standard-Rotation Corvair engine. VW Type 1 CV axles will bolt up with use of matching trans output flanges, and another Samba Forum member has been running the Passat/Audi trans in Vanagons with a rev-rot'd 1.8T engine.
bnc
Dale M.
Dale M. is offline
PostPosted: Tue Jan 26, 2016 2:35 pm    Post subject: Re: What is this max buggy worth Reply with quote
Subie gears do not run backwards you can not flip R&P, it requires new reverse rotation R&P gear set....
Dale
joescoolcustoms
PostPosted: Tue Jan 26, 2016 2:53 pm    Post subject: Re: What is this max buggy worth Reply with quote
Dale
Subarugears makes a new ring and pinion and flips the ring gear to the other side of the pinion. The new gear set is made to apply pressure to the proper side of the tooth instead of the coast side like flipping a VW ring gear.
For holding up, two of them raced the NORRA Baja 1000, finished 1 and 2 in class, partied, drove back to SoCal, cleaned them, then drove both across the US and back. Only problem was a clutch disk did not like the silt during the race, and in Columbus Ohio, one electrical connector broke, (on the engine electrical system, not trans).
didget69
didget69 is offline
PostPosted: Wed Jan 27, 2016 11:08 am    Post subject: Re: What is this max buggy worth Reply with quote
Dale
A reverse rotation R&P Subaru transmission still won't work in a rear engine application in conjunction with a standard rotation Corvair engine.
bnc
didget69
didget69 is offline
PostPosted: Wed Jan 27, 2016 11:23 am    Post subject: Re: What is this max buggy worth Reply with quote
The Porsche 928 engine rotates in standard clockwise rotation when looking at front of engine (at harmonic balancer).
Starter is under the engine on 928 -
The is why the 928 starter can be used on T1 gearbox to spin over a standard-rotation (CCW at harmonic balancer) Corvair engine swap.
bnc
Dale M.
Dale M. is offline
PostPosted: Wed Jan 27, 2016 1:06 pm    Post subject: Re: What is this max buggy worth Reply with quote
didget69 wrote:
Dale
bnc
Was not even EVER considering Corvair in my comments, all I was commenting on is a complete Subaru application...
Dale
heywebonya
heywebonya is offline
PostPosted: Wed Jan 27, 2016 1:18 pm    Post subject: Re: What is this max buggy worth Reply with quote
Dale M,
Is it possible to replace a VW transmission and engine with a Subie engine and transmission by purchasing the ring and pinion set from Subagears?
Thanks, Jeff
If I knew what I was doing; I wouldn't be building a buggy!
joescoolcustoms
PostPosted: Wed Jan 27, 2016 1:25 pm    Post subject: Re: What is this max buggy worth Reply with quote
heywebonya wrote:
Dale M,
Thanks, Jeff
That is exactly what you do to make it rear engine/drivetrain.
BL3Manx
BL3Manx is offline
PostPosted: Wed Jan 27, 2016 4:16 pm    Post subject: Re: What is this max buggy worth Reply with quote
There isn't room to flip the ring gear to the other side of the pinion, that's why the Subarugears gears are cut backwards. The ring gear stays on the same side of the pinion but rotates in the revese direction
Dale M.
Dale M. is offline
PostPosted: Wed Jan 27, 2016 7:57 pm    Post subject: Re: What is this max buggy worth Reply with quote
heywebonya wrote:
Dale M,
Thanks, Jeff
Agreed....
But it also could make a awesome mid engine combination and you would not have to replace R&P.. Like if you were to put it into a mid engine kit car like Porsche RSK..
Dale
joescoolcustoms
PostPosted: Wed Jan 27, 2016 8:52 pm    Post subject: Re: What is this max buggy worth Reply with quote
Think about that for a second. The input shaft still turns the same direction, so the pinion will turn the same direction, so it cannot possibly turn the ring gear backwards if it is still on the same side. So Subarugears makes a ring and pinion to flip the ring gear to the other side of the pinion which allows the input shaft to turn the stock direction, but change the axle rotation.
It is some mental math, and most times my mental state is tired.
Check out the photos on their website:
http://www.subarugears.com/About/About.html
streetbuggy8804
streetbuggy8804 is offline
PostPosted: Thu Jan 28, 2016 8:23 am    Post subject: Re: What is this max buggy worth Reply with quote
A thing of beauty.
Page 2 of 3
