ibjack Samba Member
Joined: February 06, 2002 Posts: 2106 Location: Imperial Beach CA
Posted: Wed Jan 27, 2016 6:59 pm Post subject: Things I wish I would have known about restoring a type 3 |
I thought with all the restorations going on it would be good to have a list of things we wished we would have known or thought of doing.
Before painting I wished I would have made sure all holes for trim were drilled as I forgot to drill the holes on the replacement door I was using.
I also forgot to make the cut out for the side marker on the replacement fender .
I should have drilled out and tapped all the screws that snapped during disassembly.
I should have started cleaning all the parts that needed to be ready for reassembly during all the down times (cleaning parts costs little to no money but takes up a lot of time).
Feel free to chime in and hopefully others can learn from those of us who have been there _________________ '68 Lotus White T34 automatic sunroof
'64 Manila Yellow T34
'65 Sea Blue Square Panel
the1500club.com
Shop Lacky at the T3/34 Factory, https://www.facebook.com/profile.php?id=100094313902074 |
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1425 Location: Toronto, Ontario. Canada
Posted: Wed Jan 27, 2016 7:36 pm Post subject: Re: Things I wish I would have known about restoring a type |
After bagging and tagging parts, I should have labeled the boxes better.
Re-torque all exhaust bolts after warming up the motor for the first time.
Keep an extra fuel filter for the first tank of fuel. _________________ I think he meant "rare", as in "not well-done" |
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4189 Location: Pasadena CA/DTLA soon China
Posted: Wed Jan 27, 2016 8:37 pm Post subject: Re: Things I wish I would have known about restoring a type |
1. warmed up and stretched all the rubber seals.
2. polished all chrome and removed tags.
3. straightened and stretched fender beading.
4. made sure all wires had a plug to reconnect. _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
NON INFLUENCER APPROVED |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Wed Jan 27, 2016 9:05 pm Post subject: Re: Things I wish I would have known about restoring a type |
1. Make sure grommets are actually correct for their intended location and the wires will fit through said grommet.
2. Test fit parts (screws are correct/fit) that are shiny/chromed.
3. Fender beading on correct side (and for the correct model/year) and it's warm enough to be pliable.
4. Rubber seals (especially NOS rubber) are warm, clean and flexible. I've torn a few because I was impatient.
5. Order of operations (last but should be first). I've done things backward too many times to still be doing it. There's no better waste of time/frustration than having to take three things apart to fix the one thing that I forgot.
6. Since living in the Midwest: Have a spare of just about everything. The one part I don't have is the one that'll break (or I'll lose it) and I'll have to find another one - stopping all subsequent work. This wasn't an issue when I lived in California. |
Bobnotch Samba Member
Posted: Wed Jan 27, 2016 9:28 pm Post subject: Re: Things I wish I would have known about restoring a type |
ibjack wrote: |
I thought with all the restorations going on it would be good to have a list of things we wished we would have known or thought of doing. |
I should have sent the entire car to Tram, and paid him to do the entire car. It would have been a lot less stressful, and probably cheaper in the long run. It would have been 100% correct then. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Wed Jan 27, 2016 9:30 pm Post subject: Re: Things I wish I would have known about restoring a type |
Bobnotch wrote: |
ibjack wrote: |
I should have sent the entire car to Tram, and paid him to do the entire car. It would have been a lot less stressful, and probably cheaper in the long run. |
Too funny- I was just thinking about sending all of mine over to you so I wouldn't have to deal with them... _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
squaretobehip Samba Member
Joined: August 23, 2004 Posts: 3695 Location: San Jose, CA
Posted: Wed Jan 27, 2016 9:31 pm Post subject: Re: Things I wish I would have known about restoring a type |
Bobnotch wrote: |
ibjack wrote: |
I should have sent the entire car to Tram, and paid him to do the entire car. It would have been a lot less stressful, and probably cheaper in the long run. It would have been 100% correct then. |
Yeah but it would have taken 10 times longer. _________________ 1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
Instagram - @ispwest - www.instagram.com/ispwest |
ibjack Samba Member
Posted: Wed Jan 27, 2016 9:51 pm Post subject: Re: Things I wish I would have known about restoring a type |
ataraxia wrote: |
1,2 and especially 5 😩😁😣 _________________ '68 Lotus White T34 automatic sunroof
the1500club.com
Posted: Wed Jan 27, 2016 9:52 pm Post subject: Re: Things I wish I would have known about restoring a type |
squaretobehip wrote: |
Bobnotch wrote: |
ibjack wrote: |
Yeah but it would have taken 10 times longer. |
That's OK, I'd get perfection then. It would literally be a "new"car after he's done with it. You know Tram's 1 of those guys that wants it right, and will only do it right, even if it takes years. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Wed Jan 27, 2016 9:53 pm Post subject: Re: Things I wish I would have known about restoring a type |
Bobnotch wrote: |
ibjack wrote: |
Don't believe everything notchboy tells you.
It's more like 20 times longer. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Wed Jan 27, 2016 10:01 pm Post subject: Re: Things I wish I would have known about restoring a type |
ibjack wrote: |
ataraxia wrote: |
1,2 and especially 5 |
Yup, those are good too, when added to yours Jack. And Martin's #2 and #4 are also right on the money. His number 2 is the same as your cleaning stuff during the down time.
I'll add in that unless a part is perfect, plan on replacing it. Otherwise it'll look like crap against the new paint. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
ibjack Samba Member
Posted: Wed Jan 27, 2016 10:15 pm Post subject: Re: Things I wish I would have known about restoring a type |
Bobnotch wrote: |
ibjack wrote: |
ataraxia wrote: |
1,2 and especially 5 ������ |
I'll add in that unless a part is perfect, plan on replacing it. Otherwise it'll look like crap against the new paint. |
Yep. Ever part that looked useable coming off gets the "like hell I will put that crap back on my shiny car" treatment. That's why a restoration budget goes way over the projection of time and money. _________________ '68 Lotus White T34 automatic sunroof
the1500club.com
t3kg Samba Member
Joined: June 14, 2006 Posts: 2712 Location: Los Angeles
bad1916 Samba Member
Joined: November 14, 2010 Posts: 224 Location: Camarillo ca
Posted: Wed Jan 27, 2016 11:05 pm Post subject: Re: Things I wish I would have known about restoring a type |
Don't throw anything away until you are done,especially since not everything is available. Even things that look like crap can be used to compare new parts against when something doesn't work. _________________ SEMPER PARATUS!
1963 SQUAREBACK |
JeeJeeJason Samba Member
Joined: May 23, 2014 Posts: 234 Location: Bay area, CA
Posted: Wed Jan 27, 2016 11:17 pm Post subject: Re: Things I wish I would have known about restoring a type |
Put the windshield in properly the first time....
Decide to put side markers in BEFORE paint, ack.
Keep all old parts even if you plan on replacing or buying new parts.
Stretch fender beading out better before installing. _________________ 1968 FI Squareback |
Posted: Thu Jan 28, 2016 12:47 am Post subject: Re: Things I wish I would have known about restoring a type |
Bobnotch wrote: |
Bobnotch wrote: |
ibjack wrote: |
That's OK, I'd get perfection then. It would literally be a "new"car after he's done with it. You know Tram's 1 of those guys that wants it right, and will only do it right, even if it takes years. |
OK, WTF are you up to, Robert? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
HenrikL Samba Member
Posted: Thu Jan 28, 2016 1:12 am Post subject: Re: Things I wish I would have known about restoring a type |
Don't wait 16 years before rebuilding the distributor. The car runs so much better when everything inside the distributor can move. |
Aaron M265 Samba Member
Joined: March 31, 2008 Posts: 656 Location: Adelaide, South Australia
Posted: Thu Jan 28, 2016 4:15 am Post subject: Re: Things I wish I would have known about restoring a type |
Wise words.
Don't throw away anything until the replacement is fitted has served me well over the years .
I learnt that the hard way by throwing away what were actually good parts from my Renault Dauphine Gordini. Only afterwards did I find that parts didn't exist for them. Hard lesson to learn. _________________ Aaron
http://1500notchback.blogspot.com/
Need to contact me? Email is faster than a PM - [email protected]
For T3 Panel Van information:
http://www.thesamba.com/vw/forum/viewtopic.php?t=389465 |
69 Notchback Samba Member
Joined: September 12, 2011 Posts: 714 Location: Bailey Co
Posted: Thu Jan 28, 2016 5:37 am Post subject: Re: Things I wish I would have known about restoring a type |
Do what you can on your own! No one cares about your restoration and final results more then your self. |
RAIDER SS Samba Member
Joined: November 21, 2003 Posts: 270 Location: Fairport, New York
Posted: Thu Jan 28, 2016 6:22 am Post subject: Re: Things I wish I would have known about restoring a type |
Never say “this will be good enough for now”
Save time by doing it correctly once! _________________ 1972 SquareBack.....recycled back to life......
"Elwood" |
