laughtybus Samba Member
Joined: September 10, 2010 Posts: 118 Location: Terrell tx
Posted: Thu Jan 28, 2016 10:25 am Post subject: Volksair compressor build |
I am currently building a volksair compressor for my shop bought the kit from dunn-right out of South Carolina. |
far rider Samba Member
Joined: August 30, 2005 Posts: 771 Location: Rutland, VT
Posted: Thu Jan 28, 2016 1:11 pm Post subject: Re: Volksair compressor build |
Sounds good. Would love to see some pics of the procedure. _________________ 67 zenith blue sunroof
Contentment; when what you have is what you want. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
Posted: Thu Jan 28, 2016 3:03 pm Post subject: Re: Volksair compressor build |
They've been in that compressor business for decades, remember reading about the kit in old Hot VWs magazine. Maybe Oct. 1997 issue. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Thu Jan 28, 2016 7:33 pm Post subject: Re: Volksair compressor build |
this is the cam and the secret to the compressor |
Posted: Thu Jan 28, 2016 7:39 pm Post subject: Re: Volksair compressor build |
this is the intake modification needs to be welded |
Posted: Thu Jan 28, 2016 7:59 pm Post subject: Re: Volksair compressor build |
Posted: Thu Jan 28, 2016 8:32 pm Post subject: Re: Volksair compressor build |
This is the directions supplied with the kit |
Posted: Fri Jan 29, 2016 2:43 pm Post subject: Re: Volksair compressor build |
Looks like an ambitious job. Looking forward to the finished project. Thanks for sharing. _________________ 67 zenith blue sunroof
Posted: Fri Jan 29, 2016 7:36 pm Post subject: Re: Volksair compressor build |
have to cut a few push rods. Used torch and pliers to remove ends.
putting new bearings and gears on the crank
rebuilding the heads
Posted: Fri Jan 29, 2016 10:15 pm Post subject: Re: Volksair compressor build |
still lots more small stuff to do. Could have taken short route but but better take the correct one. |
Posted: Sat Jan 30, 2016 8:08 pm Post subject: Re: Volksair compressor build |
everything is in its place
everything torque to spec yeah the crank is frozen. Pulled back apart the standard cam bearings are not standard. They fit the case as the old ones did |
Posted: Mon Apr 04, 2016 2:18 pm Post subject: Re: Volksair compressor build |
after some little problems with the case I was able to get it turning. now to get it up on this 75 gallon tank |
Posted: Sun Apr 10, 2016 11:37 am Post subject: Re: Volksair compressor build |
have it out in my shed now to cut out the noise in the shop. just got to plumb the oil cooler an filter, get a small fuel tank an plumb the lines and finish the wiring |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
CleanThatPoolTile Samba Member
Joined: July 21, 2020 Posts: 4 Location: Tucson, Arizona
Posted: Wed Jul 22, 2020 1:59 pm Post subject: Re: Volksair compressor build |
1967 VW Air Compressor Conversion ... 'Lucky Lime' ... Dunn Right Inc. ... Cleaning Pool Tile, in Tucson, Arizona
https://youtu.be/ytiAQqEzgCQ[/url]
Cleaning pool tile, in Tucson, Arizona, since 2014. Compressor makes 56 cfm @ 100 psi. 'Volks-Aire' conversion kit from Dunn-Right Inc. The magic is in the cam shaft: 4 cycle, in the front, two cycle, in the back.
