CBDZ_CBDZ Samba Member
Joined: December 27, 2007 Posts: 363 Location: Eastvale, CA
Posted: Fri Jan 29, 2016 4:14 pm Post subject: Clutch Bowden Tube - Metal Tube in Chassis |
The bowden tube for my clutch cable has excessive bend in it. I don't have any washers or shims at the transmission mounting point.
I have two questions...
1. Is there different length bowden tubes? Can I find a shorter one from a different year.
2. How much of the metal tube that runs through the chassis protrudes past the rear bulk head? I may not have trimmed enough of this tube after shortening this tube. _________________ Tube Bender Rental in So. Cal.
http://www.rentabender.com |
Dale M. Samba Member
Posted: Fri Jan 29, 2016 8:37 pm Post subject: Re: Clutch Bowden Tube - Metal Tube in Chassis |
What is excessive ... should have about 1 inch droop... Yes there is several different lengths.... Believe the are different by "years"....
http://www2.cip1.com/SearchResults.asp?search=bowden+tube&Submit=
Looks there are 11-3/4 and 12-1/2 and 12-5/8...
Iguana Samba Member
Posted: Sat Jan 30, 2016 3:44 am Post subject: Re: Clutch Bowden Tube - Metal Tube in Chassis |
We trim them at 25mm from rear cross section.
If you shortened it then more than likely it will be to long |
oldfirtwithafastoldbug Samba Member
Joined: February 02, 2016 Posts: 8 Location: Ontario Calif 909-986-2742
Posted: Wed Feb 03, 2016 12:20 pm Post subject: Re: Clutch Bowden Tube - Metal Tube in Chassis |
Do you have tube benders for rent/ if you do. Ill fix your bug so you well never have to replace the cable again. call me please or post your # and ill call you |
AMAC1680 Samba Member
Joined: April 09, 2015 Posts: 300 Location: Jacksonville Fl/Mantoloking NJ
Posted: Wed Feb 03, 2016 3:00 pm Post subject: Re: Clutch Bowden Tube - Metal Tube in Chassis |
oldfirtwithafastoldbug wrote: |
Ok now I'm interested. How?
AMAC |
Posted: Wed Feb 03, 2016 8:41 pm Post subject: Re: Clutch Bowden Tube - Metal Tube in Chassis |
If someone well tell me how to post pic I wood show you. But for now I'll just tell how I did mine. !st you take out the old 1 and through it as fair as you can. Then take out the pedal assembly and ( this is where I need the pic) weld a air craft swivel end to the of the clutch rod. Then take a piece of rod from there to the opening of the trans hole and put on a ( I call it a house shoe) U / with a pin and weld it. Then take a sm length of pipe. ( go pick up the tube you through away and cut it) Now weld it in place so your bent tube is just where you need it . ( need pic) install a old cable to the trans into the bent tube into the trans hole . then take the cable around the house shoe and tie it off with 2 cable clamps. You have to have enough space for the cable to move about 3 in from the end of the house shoe to the tube end. ( a pic wood help) I did mine over 10 yrs ago and it is still works today. When you use this idea of mine, Just tell every 1 its a Bob thing. |
