Speedmaster Problems with finding the right tires
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
ratpanel61
ratpanel61 is offline
PostPosted: Sat Jan 30, 2016 2:46 pm    Post subject: Speedmaster Problems with finding the right tires Reply with quote
I'm trying to figure out the best size tire that will fit the 5.5 inch Speedmasters. I want something that will still tuck. I'm running a 4" narrowed beam, with CB disc brakes in the front so I'm trying to still keep it well within the wheel wells. Problem is that I don't have the body on the pan to take measurements. I have a pair of both Speedmasters (13 and 21) and measured them mounted to the beam. The narrowest ones are 57" lip to lip. I want a tire that is pretty close to flush with the outer lip. And obviously, if I can get something in low profile, that would be a bonus. Any suggestions?
- '57 Sunroof Beetle (project)
- '73 THING
ps2375
ps2375 is offline
PostPosted: Sun Jan 31, 2016 1:02 pm    Post subject: Re: Speedmaster Problems with findind the right tires Reply with quote
wait till you get the body on before buying something. You might have issues getting a tire flush at the front since you have a narrowed beam.
I have 185/65-15's up front and 205/65-15's out back on what I think are 5.5" wide wheels and those are fairly flush front and rear. And I wouldn't go any wider than the 205's nor much shorter on the sidewalls with that narrow of a wheel.
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
