wwest Samba Member
Posted: Sat Jan 30, 2016 6:36 pm Post subject: Shifter bushing mystery |
I have a 57 beetle and went to replace my shifter bushing.....
But I ran into a shift rod hangar that doesnt accept the standard shift rod bushing.
Did the 57 have a different shift rod hangar? |
Snort Samba Member
Joined: April 02, 2005 Posts: 1957 Location: Seattle, WA
Posted: Sat Jan 30, 2016 6:45 pm Post subject: Re: Shifter bushing mystery |
Yes. It's all metal, put some grease on it. If it's worn through then you'll need to replace the whole bracket with the later style as the superior early ones are no longer available. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Sat Jan 30, 2016 7:18 pm Post subject: Re: Shifter bushing mystery |
Good thread here on it
http://www.thesamba.com/vw/forum/viewtopic.php?t=568407&highlight=shift+rod+hanger _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
wwest Samba Member
Posted: Sun Jan 31, 2016 3:59 am Post subject: Re: Shifter bushing mystery |
Perfect! Thanks guys.
Its in good shape...Iwas just confused... |
1302Steve Samba Member
Joined: April 04, 2004 Posts: 19 Location: Sydney, Australia
Posted: Fri Sep 18, 2020 11:45 pm Post subject: Re: Shifter bushing mystery |
Hi, sorry to drag up an old post.
I've mainly worked on later Beetles and when I found that bracket in the chassis wouldn't accept a plastic bushing I looked here for expert help.
Reading the posts in this thread made me aware that my 1956 doesn't need a bush. Looking at online VW shops they all list the same bush for 1950 - 1979, very confusing.
As a side note if your car does have a plastic bushing a drop of STP or even motor oil squirted down the rear gearstick hole will lube shift bushing.
Cheers Steve |
splitjunkie Samba Member
Posted: Sat Sep 19, 2020 6:05 am Post subject: Re: Shifter bushing mystery |
The later style that accepts the nylon bushing fits the earlier cars. It is just an updated part. Pretty standard practice with air cooled VWs since they didn't totally redesign the car every few years. _________________ Chris
Posted: Sat Sep 19, 2020 5:38 pm Post subject: Re: Shifter bushing mystery |
Hi
I think while car is apart I will fit the later bracket, I did notice some slop in the shift rod that why I pulled it apart |
Posted: Mon Sep 21, 2020 8:23 am Post subject: Re: Shifter bushing mystery |
read that thread for the procedure for replacing the hanger. There is no reason to cut a hole in the tunnel. The Bentley manuals also cover the procedure. _________________ Chris
