rpmx2 Samba Member
Posted: Fri Feb 12, 2016 12:39 am Post subject: Re: Hoping to get some info on Ignition Issue |
Problem Solved...!
Ok folks, so what I did was I made sure that I had 12vdc power to the MSD while the ignition was in the "On" position, which I did have.
Next, I jumped the Violet and Green wire as per MSD instructions and I did get a spark but it only happened once, after that, no spark at all...
So, I did have two bad MSD 6AL boxes. Yes, both had problems after warming up and would not start the car until the units were cooled down.
Besides this major problem with both boxes, one box also gave me erroneous Tach readings, the other box rev limiter did not even work...
I obtained an .009 distributor, points, condenser and wires, I had to swap a set of velocity stacks but I think I got the better deal. however, knowing that I found the issue, I ordered a new Digital MSD 6AL... $235 and the box came in a day after I received my distributor so I elected to wait to install new MSD and wala! All Workie Workie!!!
Thanks for all the input and help.
