W1K1 Samba Member
Joined: March 04, 2004 Posts: 4919 Location: Southern AB
Posted: Sun Jan 31, 2016 6:39 pm Post subject: Re: Rear Bearing and Seal Replacement. Still Leaking After R |
FYI
using an impact to install new bearings will cause false brinelling (vibrating the bearing housing and balls causing dents in the bearing race) which shortens the life of the bearing. Kind of like taking an axe to a new asphalt road causes pot holes. _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
one4house Samba Member
Joined: July 18, 2009 Posts: 1121 Location: Sherman Texas
Posted: Mon Feb 01, 2016 6:21 pm Post subject: Re: Rear Bearing and Seal Replacement. Still Leaking After R |
Took the time after work to check the torque with a nice 250 lb. torque wrench. Driver side was not torqued enough. Passenger side was torqued enough.
After getting the drives' side to spec + a little and the passenger side + a little, I took her for a drive. No luck. Still leaking.
I have a new set of rebuild kits coming on Wednesday. I will take it apart this weekend, check everything over and add the gasket behind the backing plate. Hopefully that will take care of it. I'll keep everyone updated. _________________ My Old 64 Field Find
My Old 66 Squareback
My Old 66 Beetle
My Old 70 Squareback |
rosevillain Samba Member
Joined: December 28, 2005 Posts: 1289 Location: roseville, ca
Posted: Mon Feb 01, 2016 9:21 pm Post subject: Re: Rear Bearing and Seal Replacement. Still Leaking After R |
Edited due to double post. |
Posted: Mon Feb 01, 2016 9:25 pm Post subject: Re: Rear Bearing and Seal Replacement. Still Leaking After R |
We looked everything over, and it all looked fine. At $20 a set, i might just order them to be sure. Seems like cheap insurance. For all I know, the ones in the car turn 50 with the car next month.
Edit: I just ordered a set. No reason not to at $20. I would rather not do this a third time, and I will already have it 100% apart. _________________ My Old 64 Field Find
My Old 66 Beetle
Posted: Mon Feb 01, 2016 9:38 pm Post subject: Re: Rear Bearing and Seal Replacement. Still Leaking After R |
Good idea. Good luck. |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5994 Location: Brooklyn
Posted: Tue Feb 02, 2016 7:57 am Post subject: Re: Rear Bearing and Seal Replacement. Still Leaking After R |
This is a timely thread as this job is in my near future. Good to know especially about the second paper gasket behind the backing plate - as OP mentioned it's not shown in Bentley even though it is included in the rebuild kit. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
ibjack Samba Member
Joined: February 06, 2002 Posts: 2105 Location: Imperial Beach CA
Posted: Tue Feb 02, 2016 8:18 am Post subject: Re: Rear Bearing and Seal Replacement. Still Leaking After R |
I had the same problem a few years ago. Replaced the seals twice, then a good friend suggested I check the bearing cover. Somehow it became slightly warped and didn't sit flush. A few runs with a file and sandpaper, I was good to go. _________________ '68 Lotus White T34 automatic sunroof
'64 Manila Yellow T34
'65 Sea Blue Square Panel
the1500club.com
Shop Lacky at the T3/34 Factory, https://www.facebook.com/profile.php?id=100094313902074 |
Posted: Tue Feb 02, 2016 8:20 am Post subject: Re: Rear Bearing and Seal Replacement. Still Leaking After R |
ibjack wrote: |
I had the same problem a few years ago. Replaced the seals twice, then a good friend suggested I check the bearing cover. Somehow it became slightly warped and didn't sit flush. A few runs with a file and sandpaper, I was good to go. |
Another good tip. Another something to check. Thank you. _________________ My Old 64 Field Find
My Old 66 Beetle
Posted: Sun Feb 07, 2016 9:32 pm Post subject: Re: Rear Bearing and Seal Replacement. Still Leaking After R |
Where is the vent on a 66 manual? I am still having leaking behind the baking plates, and I want to make sure there isn't a clogged vent.
I took the time to take everything a part today. The leaking is confined to the backing plate. Inside the drum, behind the hub, was dry and clean.
The bad news is that the installation of the missing gaskets did nothing to effect the leak. It looks like I leaking exclusively at the seep hole.
So, is there a clogged vent that is causing the fluid to find the path of least resistance? _________________ My Old 64 Field Find
My Old 66 Beetle
RHD Notch Samba Member
Joined: April 06, 2007 Posts: 1412 Location: Joshua Tree, CA
Posted: Tue Feb 09, 2016 10:45 pm Post subject: Re: Rear Bearing and Seal Replacement. Still Leaking After R |
Can you post some pics of your parts once it's taken apart and cleaned? All of the pics you've posted have been external. I'd like to see the internals...all of them. Something like the exploded view in the Bentley.
Many of us have done this job with no problems, but a picture is worth a thousand words sometimes.
There are quite a few photos to be found in the gallery, but I'd like to see your parts...Thanks
http://www.thesamba.com/vw/forum/album_search.php?search_id=520325757&start=0 _________________
Lind wrote: |
I am at the point where I hardly want to own anything that isn't original paint. |
campingbox wrote: |
I have some other projects I'd like to finish first and I want to drive this bus while I'm working on those to help stay motivated. |
Posted: Wed Feb 10, 2016 6:59 am Post subject: Re: Rear Bearing and Seal Replacement. Still Leaking After R |
Here is a picture of the seal kit i used.
A new set of spacers are in the mail. I'll take a picture of those once they are here. I will only be using the new front spacers. I don't think it will be advantageous to pull the bearings again just to replace the rear spacer. I also don't believe the bearings can be pulled without having to ruin them.
I will get a picture of the spacer kit once it comes in this week. I plan on pulling it all apart again on Monday. I have plans for the weekend that get in the way of any car repairs.
Here is the info on the bearings I ordered from rock auto.
https://www.rockauto.com/catalog/moreinfo.php?pk=4582707&cc=1370168
For fun and consolidation, here is a picture of the exploded view.
My Old 66 Beetle
Posted: Thu Feb 11, 2016 4:26 pm Post subject: Re: Rear Bearing and Seal Replacement. Still Leaking After R |
Ok. The new spacer set came in today. I am noticing that both the small and large spacers are tapered on one side. Here are the pictures.
The small spacer goes in before you put in the bearing. Is the taper (larger ID) supposed to face the bearing or is the non-taper (smaller ID)supposed to face the bearing?
The large spacer, that goes on after you put the small o-ring on the axle shaft, I assume would have the taper (large id) facing the bearing so that the oRing has a place to fit?
These are my concerns. I KNOW that I put the large spacer in with the taper towards the o-ring. I cannot remember which way I put the small spacer behind the bearing. I will be able to check which way the taper is facing when I have everything apart next week.
I'm looking forward to some guidance on this. My thought, because of the fact that it is leaking by the backing plate only, is that I have the rear spacer in backwards behind the bearing. This is causing the leak between the backing plate and the swing axle. _________________ My Old 64 Field Find
My Old 66 Beetle
blues90 Samba Member
Joined: March 14, 2009 Posts: 1912 Location: Hollywood ,CA
Posted: Thu Feb 11, 2016 5:09 pm Post subject: Re: Rear Bearing and Seal Replacement. Still Leaking After R |
All I could fine was in the Haynes book and it says the inner spacer the taper goes in . I assume this means toward the diff side. I didn't find how it goes in in the Bentley.
Also found on a search that the inner spacer taper faces the diff.
Posted: Thu Feb 11, 2016 5:15 pm Post subject: Re: Rear Bearing and Seal Replacement. Still Leaking After R |
blues90 wrote: |
All I could fine was in the Haynes book and it says the inner spacer the taper goes in . I assume this means toward the diff side. I didn't find how it goes in in the Bentley. |
Inner spacer the taper goes towards the diff, the small ID (edit) goes towards the bearing. I'm just waiting on a confirmation or two, and I will know what to look for. I'm not taking it apart till Monday or Tuesday, so I have plenty of time.
It is pretty sad that the Bentley makes no mention of the taper. 90% information still leaves 10% guessing. _________________ My Old 64 Field Find
My Old 66 Beetle
Posted: Thu Feb 11, 2016 5:43 pm Post subject: Re: Rear Bearing and Seal Replacement. Still Leaking After R |
one4house wrote: |
blues90 wrote: |
Inner spacer the taper goes towards the diff, the small OD goes towards the bearing. I'm just waiting on a confirmation or two, and I will know what to look for. I'm not taking it apart till Monday or Tuesday, so I have plenty of time.
It is pretty sad that the Bentley makes no mention of the taper. 90% information still leaves 10% guessing. |
another site I found doing a search also says the tapered side of the inner spacer faces the diff meaning it does not face the bearing. |
Posted: Thu Feb 11, 2016 6:20 pm Post subject: Re: Rear Bearing and Seal Replacement. Still Leaking After R |
blues90 wrote: |
We are on the same page. The most surface area touches the bearing. The small surface area points towards the diff. I just hope they are already that way. Pulling the bearings again is going to suck if it has to be done. _________________ My Old 64 Field Find
My Old 66 Beetle
Posted: Thu Feb 11, 2016 6:42 pm Post subject: Re: Rear Bearing and Seal Replacement. Still Leaking After R |
The chamfers of both the thick and thin spacers face toward the gearbox. Please see #5 & #10 on the diagram above.
"Hoping" you assembled the inner spacer correctly may be why this problem has been ongoing. You should pull that bearing and confirm it's orientation. _________________
Lind wrote: |
campingbox wrote: |
Posted: Thu Feb 11, 2016 6:46 pm Post subject: Re: Rear Bearing and Seal Replacement. Still Leaking After R |
RHD Notch wrote: |
The chamfers of both the thick and thin spacers face toward the gearbox. Please see #5 & #10 on the diagram above. |
Thanks for this. I am 100% on how the spacers go now. I appreciate it.
Quote: |
"Hoping" you assembled the inner spacer correctly may be why this problem has been ongoing. You should pull that bearing and confirm it's orientation. |
I put the spacer back in the way it came out. After 50 years of owners before me, I have no idea if it was in right or wrong when I took it apart. The first thing I will do, when I pull it apart, is confirm the orientation of the inner spacer. As of right now, the inner spacer is the only unknown. _________________ My Old 64 Field Find
My Old 66 Beetle
