neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Tue Feb 02, 2016 9:49 pm Post subject: Re: Anyone recognize e this piece of metal I found in my cas |
DP _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo
neil68 Samba Member
Posted: Tue Feb 02, 2016 9:51 pm Post subject: Re: Anyone recognize e this piece of metal I found in my cas |
That piece looks like a chunk of magnesium case material from under the #4 cylinder spigot. There are several raised lobes like that surrounding #4.
It looks "most" like the bump beside one of the head studs, so it could indicate a loose stud insert. Here's a photo of one of my old crankcases, with the suspected bump circled in red:
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
nextgen Samba Member
Joined: August 19, 2004 Posts: 6023 Location: CONGERS, N.Y.
Posted: Wed Feb 03, 2016 6:51 am Post subject: Re: Anyone recognize e this piece of metal I found in my cas |
Well that head bolt may be loose, if that is where it came from there may be cracks. Hopefully not, at this time the parts are not going to jump between something and destroy your engine. They would be in the sump. But can warp a head, first sign is compression loss.
We still don't know for sure were it came from, but torquing the head bolts will tell. Will also make matters worse if there is a crack. Creepy, 6 of 1, half dozen of the other. _________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
Howard 111 Samba Member
Posted: Wed Feb 03, 2016 7:01 am Post subject: Re: Anyone recognize e this piece of metal I found in my cas |
Neil, I think you pegged it. That's a perfect match! _________________ 1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270 |
MotoMike Samba Member
Joined: June 13, 2013 Posts: 120 Location: Durango, CO
Posted: Thu Feb 04, 2016 5:02 pm Post subject: Re: Anyone recognize e this piece of metal I found in my cas |
I looks like it made contact with something, looks pretty gouged in the first pic.
Amazing what these engines can take. Many years ago I was racing a class 10 buggy, unlimited 1200 2 seater. A guy in the same class broke a rod, #1 or 3, I don't remember but what I do remember is it blew a GIANT HOLE in the top of the case, and he finished the race like that. Drove it probably 20 miles at race speed. He fired it up in the pits afterward and we all sat there and watched the pieces go round and round! |
poptop Samba Member
Joined: February 27, 2003 Posts: 607 Location: jersey
Posted: Fri Feb 12, 2016 9:00 am Post subject: Re: Anyone recognize e this piece of metal I found in my cas |
Ok shavings did not ignite , just got fire red! Used acetylene so plenty hot _________________ So what I drive the short bus! |
poptop Samba Member
Posted: Fri Feb 12, 2016 9:04 am Post subject: Re: Anyone recognize e this piece of metal I found in my cas |
One buddy suggests throw it back together and get what I am out of it performance wise. And other says while the jugs are jiggling crack it and go crazy!it had mismatched heads so was thinking of using these heads
http://www.thesamba.com/vw/classifieds/detail.php?id=1800680
but valves are smaller from what I'm told . Thoughts on them as well as other factors _________________ So what I drive the short bus! |
