Sobakis Samba Member
Posted: Mon Feb 01, 2016 6:20 am Post subject: Kdf engine (Lithuania) |
Hello everyone.
I can't say that we found this engine, becouse everyone form LT beetle club know about this engine. But no one looked at this engine. When we taked in our garage we saw that it is old one Kdf engine. Can you recognize what engine it is? I think it' kubelwagen, and the number on bloack is ocrrect but something is not good becouse teh numbers are not original. Inside we have some Lithuania/russian style work . We can't recognize fuel pump too. Please help us
DDub Samba Member
Joined: January 06, 2005 Posts: 307 Location: central pa.
Posted: Mon Feb 01, 2016 6:52 am Post subject: Re: Kdf engine (Lithuania) |
The main bearings appear to be bronze, are they? |
Posted: Mon Feb 01, 2016 7:03 am Post subject: Re: Kdf engine (Lithuania) |
DDub wrote: |
Yes you are right. |
janerick3 Samba Member
Posted: Mon Feb 01, 2016 10:06 am Post subject: Re: Kdf engine (Lithuania) |
It looks like the correct engine number is 7-043147, which identifies this as late 1943 production, consistent with the casting dates (21 July and 02 September 1943) on the case.
I'm wondering if this short block has ever been apart in its 72 years, given the unusual parts found inside and the lack of rebuild stamps on the case. Given wartime materiel shortages, the oddball parts may not be the results of Soviet ingenuity.
The bottom half of the fuel pump dates from around 1955--I'm not sure of the top half, it may not be VW. _________________ Thanks,
Jan K. |
mikeandkirsti Samba Member
Posted: Mon Feb 01, 2016 10:55 am Post subject: Re: Kdf engine (Lithuania) |
The engine number has been ground off and restamped, however the original star at the end remains. The original number would have a star on the other end too, then a line between 7 and O, also a round check stamp would be present, usually stamped above the line. Also the stamps used are not original VW stamps.
What probably happened is the original engine of the Schwimmwagen having had the number 7-043147 was replaced by another KdF block from another Schwimmer or Kübelwagen and restamped with the original engine number. Very common practice. This block might have come from a 1943 Schwimmwagen as it has threads for the studs to hold the engine tin at the bottom.
In the Soviet Union the vehicle was registered with the engine number and if the the engine failed, the new engine had to carry the same number. Vehicles were owned by the Soviet state as there was no private ownership but a private person would get a registration certificate for the vehicle and de facto could sell it. |
Undis Samba Member
Joined: October 24, 2006 Posts: 1396 Location: Riga, Latvia & Sydney, Australia
Posted: Mon Feb 01, 2016 2:44 pm Post subject: Re: Kdf engine (Lithuania) |
Sweet find! It seems most KdF cars and parts found in the Baltic countries are from 1943.
The fuel pump seemed familiar. Then I remembered I saw one just like this on the Lithuanian “rooftop KDF”. This may as well be that it comes from a more common Soviet vehicle or maybe even from a German one as the fuel pump top seems to fit right on the VW bottom part.
Posted: Wed Feb 03, 2016 12:09 am Post subject: Re: Kdf engine (Lithuania) |
What a week Today i found another "oldie". Number on engine are not original on same problem. Becaouse engine was mounted in oval. So someone correct engine number and it original oval engine number.
The car where engine was
Engine i Think it's 1944 Kubelwagen engine
So today we have 2 oldies and we think we will restorate it
One more question. This alternator original or not? And what year? I can't found any information about this
Posted: Wed Feb 03, 2016 12:13 am Post subject: Re: Kdf engine (Lithuania) |
Forgot one photo
pastellgreen Samba Member
Joined: January 06, 2012 Posts: 1049 Location: Germany
Posted: Wed Feb 03, 2016 10:34 am Post subject: Re: Kdf engine (Lithuania) |
Your generator is a correct one. 130 W 2600 AL 15
If you find a datacode like "10F" for exanmple, you can tell the date. |
splitjunkie Samba Member
Posted: Wed Feb 03, 2016 12:19 pm Post subject: Re: Kdf engine (Lithuania) |
The generator backing plate is much later. Late '49 or later. _________________ Chris
blood Samba Member
Joined: October 01, 2015 Posts: 50 Location: nashville tn
Posted: Wed Feb 03, 2016 5:09 pm Post subject: Re: Kdf engine (Lithuania) |
Thanks for the post! your 21-7-43 engine is 8 days older than a kubelwagen block I am currently sourcing parts for a rebuild to replace the 36hp one that is in my 44 type 82. I do have say the numbers do not look original. they are much clearer than the zundfolge wording just under them. But that case is very period correct in my opinion.
Can anyone give me a date on when the cases received the upper perimeter bolts? You can see in the 2-9-44 case that they are present then but not on the first case (or on mine). Also are the pushrod tube openings in the first case not countersunk but flat? looks like it has rubber pushrod seals stuck to the side of the case. does the later case you have also have flat openings?
thanks and best wishes on your project.
David |
virtanen Samba Member
Joined: January 08, 2006 Posts: 1462 Location: Finland
Posted: Wed Feb 03, 2016 11:08 pm Post subject: Re: Kdf engine (Lithuania) |
splitjunkie wrote: |
The generator backing plate is much later. Late '49 or later. |
The generator backing plate without holes came late '47 or early '48. I haven't found the exact date for the change.
Here a picture of late '47/early '48 without holes:
_________________ Mika
Split beetle restoration panels
Oval beetle restoration panels
New projects |
Posted: Thu Feb 04, 2016 5:35 am Post subject: Re: Kdf engine (Lithuania) |
thanks for the correction. I knew it was somewhere in the late 40's but didn't have time to look it up in PR. _________________ Chris
Posted: Sat Feb 06, 2016 6:25 pm Post subject: Re: Kdf engine (Lithuania) |
It looks like there is a barely readable "9Z" (Sep 1944) directly above the "2600" stamp on the generator housing... _________________ Thanks,
Jan K. |
