PDX_VW_Erik Samba Member
Joined: November 15, 2015 Posts: 199 Location: Oregon
Posted: Mon Feb 01, 2016 9:22 pm Post subject: Unmovable head bolt |
Going from single port to dual port and this damn thing needs to come out.
I've already JB Spotwelded nuts onto it, and they just back out.
If I can't remove this, the case is trash.
Any ideas??
TIA!!!! |
Posted: Mon Feb 01, 2016 9:29 pm Post subject: Re: Unmovable head bolt |
I've hammered on it, gingerly, I'm OK with putting in case savers. Should I hammer like mad on it? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51150 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Feb 01, 2016 10:46 pm Post subject: Re: Unmovable head bolt |
PDX_VW_Erik wrote: |
JB Spotwelded nuts onto it, |
I need to hear more about this, please elaborate. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Bruce Samba Member
Posted: Mon Feb 01, 2016 10:52 pm Post subject: Re: Unmovable head bolt |
Vise Grips? _________________
DeathTrap Samba Member
Joined: February 26, 2004 Posts: 1757 Location: Sacramento/Vermont
Posted: Tue Feb 02, 2016 4:55 am Post subject: Re: Unmovable head bolt |
heat case/threaded area
they may be locktighted
locktight forms a plastic like lock and heat will melt this
grab "stud" not far from case with Visegrips and lefty loosey
do it while hot
not cherry red but probably enough to steam or bubble spit |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Tue Feb 02, 2016 5:09 am Post subject: Re: Unmovable head bolt |
Any ideas??
TIA!!!! |
Why take it out? I'm assuming you are going to put in shorter studs for the dual port heads, but you can always just cut the existing one down... |
MacLeod Willy Samba Member
Joined: February 18, 2014 Posts: 933 Location: Ontario Canada
Zundfolge1432 Samba Member
Posted: Tue Feb 02, 2016 7:29 am Post subject: Re: Unmovable head bolt |
That tool,penetrating oil and heat should do the trick, rarely have I seen one that wouldn't let go, sometimes the case saver would come out too. This is a good reason not to loctite these or if you do use only the green. We've always just used aviation permatex or nothing at all. Good luck and you know what they say about the right tools making the job easier. |
Posted: Tue Feb 02, 2016 7:33 am Post subject: Re: Unmovable head bolt |
Any ideas??
TIA!!!! |
Rereading your post skip the j b weld and use the time honored method of tightening two nuts against each other then put a wrench on the bottom nut turn counterclockwise. |
rayvwbug Samba Member
Posted: Tue Feb 02, 2016 10:27 am Post subject: Re: Unmovable head bolt |
X2 As above |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Tue Feb 02, 2016 10:41 am Post subject: Re: Unmovable head bolt |
RoboRay wrote: |
X2 As above |
And if double-nuts don't do the job, try triple-nutting!
It will back out . . . no heat required. _________________ Jesucristo es mi Seņor y Salvador! |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
awreed Samba Member
Joined: January 14, 2010 Posts: 1268 Location: Kirkland, WA
Posted: Tue Feb 02, 2016 6:23 pm Post subject: Re: Unmovable head bolt |
Take the cylinders off and use a stud removal tool
Posted: Sat Feb 06, 2016 10:58 pm Post subject: Re: Unmovable head bolt |
If you all are still concerned, and thanks for your tips, I didn't think cutting it shorter would have done it, but I'm noob when it comes to splitting cases and this kind of upgrade.
I am going to dual port heads, and after tons of WTFing on it (and I did JB Spotweld two nuts onto the threads and they just backed off) it finally came out and the thing is progressing.
Thanks for all the tips, though, I may need them next time. Hopefully, some poor jackass like me found yall on Google and you helped them! |
Posted: Mon Feb 08, 2016 12:08 pm Post subject: Re: Unmovable head bolt |
Glad you solved the problem reread this " You do not need JB weld" when you double nut a stud to install or remove you are using the mechanical force of the two nuts tightened against each other to form a lock on the stud. This technique has been around forever and is taught to every student learning to be a mechanic. It's a good thing you didn't follow the advice of cutting the stud, you would have found the stud too short and run out of threads. You cannot add more threads to these type of studs as they are rolled. |
