rogerpasadena Samba Member
Joined: April 21, 2014 Posts: 23 Location: pasadena ca
Posted: Thu Feb 04, 2016 10:31 am Post subject: Relay |
Found this relay not hooked up in my car any ideas what it is used for
Thanks
Randy in Maine Samba Member
Posted: Thu Feb 04, 2016 10:39 am Post subject: Re: Relay |
Run signal flasher?
Your keys are in the car buzzer?
Your headlights are on even though the car is off buzzer? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Feb 04, 2016 11:11 am Post subject: Re: Relay |
If you rotate it a little more you'll be able to read where it says "flasher" just past Wagner, it's a USA made turn signal relay. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Feb 04, 2016 11:31 am Post subject: Re: Relay |
Thanks for the info, head lights, turn signals and emergency lights
all work without it, no warning buzzer.
sorry should have said 72 Super Thanks Again |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5593 Location: 37.5N 77.1W
Posted: Fri Feb 05, 2016 8:49 am Post subject: Re: Relay |
Did a search of Wagner stuff, no hits on that number |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15975 Location: North Florida, USA
Posted: Fri Feb 05, 2016 11:36 am Post subject: Re: Relay |
Maybe a spare flasher relay?
What are the terminal letters/numbers on the bottom?
If they are #31, #49 (+) and #49a you may be able to use it. Any other numbering and it is the wrong one for your car.
I found a listing where the Wagner 591 is shown as compatible with a CEC TF569 relay which appears to have the correct terminals.
http://www.cecindustries.com/pdfs/Flasher%20&%20Light%20Module.pdf
If your turn signals and E-Flashers are working then you don't need it. Keep it as a spare. _________________ AshMan40
