phil fox Samba Member
Joined: March 07, 2002 Posts: 110 Location: Santa Rosa, CA
Posted: Fri Feb 05, 2016 9:36 pm Post subject: 6v to 12v conversion questions.... |
So I have re-wired a few VWs (2 bugs, and 1 buggy) front to rear and they have come out GREAT.. BUT, those were cars that were already 12v cars... I am currently working on rewiring my buggy, but it is/was still 1962 6v wiring system and I am converting it to 12v... I already have the alternator, coil, starter, bulbs (headlight, taillight, blinker, etc), and a new fuse block... But, my question is.. what relays and switches need to be changed out to convert to 12 volt?? Such as headlight relays/switches, blinker relays, etc. Thanks in advance for the help...
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Fri Feb 05, 2016 10:54 pm Post subject: Re: 6v to 12v conversion questions.... |
The starter didn't need to be changed, the 6v starter will last indefinitely on 12v and unless the new 12v starter matches the 6v flywheel, it won't work.
No switches need to be changed.
Yes change the blinker relay
If you have a 67 dimmer switch yes, you'll need to replace the relay. If you have a foot dimmer switch, there is no dimmer relay.
Change the motor in the wiper to 12v. |
Posted: Fri Feb 05, 2016 11:43 pm Post subject: Re: 6v to 12v conversion questions.... |
BL3Manx wrote: |
Thanks for the response... Sorry, I should have mentioned that the reason I changed the starter was because the original was toast... But also because the new engine has a 12v flywheel..
Also, it has the foot dimmer switch so I'm good there. And I will not be running a wiper motor so no need to worry about that one.. Thanks for the help... |
EVfun Samba Member
Posted: Sat Feb 06, 2016 12:19 pm Post subject: Re: 6v to 12v conversion questions.... |
If you car had an electric gas gauge installed it will need attention before you apply 12 volts to it. A small voltage regulator can be used to adjust the voltage to what it is expecting. The stock mechanical gas gauge only needs a 12 volt light bulb.
Don't forget all the little bulbs in the speedo! They last seconds on 12 volts. The 6 volt fuse block and fuses are fine in a 12 volt conversion. _________________
Wildthings wrote: |
Posted: Sat Feb 06, 2016 9:27 pm Post subject: Re: 6v to 12v conversion questions.... |
EVfun wrote: |
Don't forget all the little bulbs in the speedo! They last seconds on 12 volts. The 6 volt fuse block and fuses are fine in a 12 volt conversion. |
Nah, it's just a mechanical gas gauge.. So that is okay.. And I will be replacing the gauge bulbs as well..
I am replacing the fuse block only because it had some funky aftermarket fuse block that the P.O. installed.. Plus, the new wiring harness I bought came with a new fuse block.. So going to just use that one.. Thanks for the input though.. This all helps make sure I am not missing something!! |
Posted: Sat Feb 06, 2016 11:01 pm Post subject: Re: 6v to 12v conversion questions.... |
If the fuse block that came with the harness is one of the ceramic fuse type, don't use it. Make sure it is an SAE blade type fuse block |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Sun Feb 07, 2016 6:39 am Post subject: Re: 6v to 12v conversion questions.... |
BL3Manx wrote: |
Why? Mine work fine. Haven't blown a fuse or had an issue in many, many years. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Sun Feb 07, 2016 8:50 am Post subject: Re: 6v to 12v conversion questions.... |
My experience was that fairly often a tail light or whatever quit working and the solution was to have to remove that circuit's fuse and clean its ends and the contacts on the block.
Here is somebody else's thoughts
Joel wrote: |
bdub475 wrote: |
What is the reason for wanting to update the fuse block? If the car is wired correctly then you should have zero trouble with the factory fuses. . |
Zero trouble?
there is a good reason why cars havent used ceramic fuses for 3 decades.
they are shocking for losing contact especially in areas of high humidity, there is just not enough surface area where they make contact with the fuse box tabs.
compare them to glass and blade type fuse boxes and you'll see the problem |
Phil doesn't need to get stopped for a non-working tail light and have to explain why he doesn't have wipers |
Q-Dog Samba Member
Posted: Sun Feb 07, 2016 10:44 am Post subject: Re: 6v to 12v conversion questions.... |
Dielectric grease will solve that problem, and a lot cheaper that replacing the fuse block. Just saying. It isn't a requirement.
I am quite familiar with humidity. My buggy, and other VWs, live under an open shed in South Louisiana. Like I said, no issues with the stock fuses. I have problems with the water spray and mud from the tires soaking signal lights and taillights, but the fuses and fuse panel have never been an issue. Never.
'69 Dune Buggy
'70 Beetle |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Sun Feb 07, 2016 12:18 pm Post subject: Re: 6v to 12v conversion questions.... |
With you on that about the fuses...When I do a build, I clean the terminals and the fuses. Never had an issue. However doing a bugy for a customer and am using a universal street rod harness because I had no harness to start with and wanted to try using one. _________________ D-Dubya Manx clone - 63 Short pan,1914.
