epowell Samba Member
Joined: September 23, 2015 Posts: 4733 Location: Czech (mostly) Vancouver (sometimes)
Posted: Sun Feb 07, 2016 2:08 am Post subject: Confusion: The final word on Rust |
Hi guys...
I have been searching the archives and the net for the final word on rust - I'd like to know that I've done the right thing to halt the rust on my van, and that once I've put in my new interior, the rust won't return at least over-night.
It seems to me that we can catagorize rust in to 3 catagories:
1) Accessible rust
2) Semi-accessible rust
3) Inaccessible rust
Accessible rust is pretty obvious - just get it out... ...replace any holes with new metal... ....then paint and protect.
Inaccessible rust seems also pretty obvious... if you simply can not reach it then the best you can do it goop or spray on/in there (deep into seams or into crannies in the underbody) some sort of rust inhibiting wax/oil.
But what to do about the Semi-accessible rust - for me the confusion comes when I hear seemingly two contradictory pieces of advice: 1) one person says beware of thick layers of anti-rust goop under your van - get it all off and see what is under it, and if you find rust - deal with it!... 2) and other person says lightly sand rusty areas under your van then spray with anti-rust goop. [Is the answer to yes, goop on anti-rust stuff on these areas, but then once every few years, clean it all off again, clean out whatever rust has developed, then goop it up again?]
So which is correct, and what finally to do with areas of semi-accessible rust - areas which are very difficult to reach - and rust repair areas that can not be perfectly cleaned free of rust... areas that will end up for years behind insulation and wall material... ??
Thanks
Ed _________________ www.edwardpowell.com |
Merian Samba Member
Posted: Sun Feb 07, 2016 1:37 pm Post subject: Re: Confusion: The final word on Rust |
Rust can always be made Accessible by drilling a hole - or just wait for it to perforate thru on its own
not sure I get your query - if there might be rust under something like undercoating you can clean it off to check and reseal; if you are sure there is none then leave it
if you are 50/50 on that contingency then... |
Posted: Sun Feb 07, 2016 1:38 pm Post subject: Re: Confusion: The final word on Rust |
Merian wrote: |
not sure I completely understand rust... if rust is there, but completely sealed off to H20 then it will NOT grow anymore? _________________ www.edwardpowell.com |
Posted: Sun Feb 07, 2016 1:39 pm Post subject: Re: Confusion: The final word on Rust |
What I mean by "accessible" is accessible enough to scrape off completely. _________________ www.edwardpowell.com |
Merian Samba Member
Posted: Sun Feb 07, 2016 1:49 pm Post subject: Re: Confusion: The final word on Rust |
it is NEVER completely sealed off to H20 - vapor can permeate almost anywhere - even thru Tygon tubing (at a low rate)
you need to worry about O2 anyway, which is even worse
where is your Van - if in Czech Republic that should be a place where you can get nice cheap labor to work on it |
Posted: Sun Feb 07, 2016 1:56 pm Post subject: Re: Confusion: The final word on Rust |
Not extremely cheap, like India or something - but auto repairs are at least 50% cheaper than in the US... maybe 66% cheaper even. IP overhaul is about 150USD.
But I don't want to hire people to do anything to my van that I can do myself - that was the whole point of getting a T3. Otherwise I would have been more wise to get a newer vehicle.
Unless I am missing something, my van have very little rust. Yes it has had a lot of rust repairs and welding done, but they did a pretty good job and just some small spots have returned. The main frame beams seem totally free of rust. And I'd like to keep them that way!
Maybe I should scrape the black tar type stuff off one portion of the underbody main beams just to test and make sure the beams really are rust free....? _________________ www.edwardpowell.com |
Merian Samba Member
Posted: Sun Feb 07, 2016 2:04 pm Post subject: Re: Confusion: The final word on Rust |
if you want to, sure - you must not be having an adequate number of mechanical breakdowns to be so bored
but where? is there a suspicious bump anywhere?
there are also known high-liklihood rust areas:
others know better than me (fortunately for me), but...
- seam behind front wheels
- inside behind the vent & kitchen in general
do you own a pressure washer or have access to a steam cleaner? |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4098 Location: East Kootenay, British Columbia
Posted: Sun Feb 07, 2016 2:10 pm Post subject: Re: Confusion: The final word on Rust |
http://www.thesamba.com/vw/forum/viewforum.php?f=13 _________________ Currently:
Merian wrote: |
Break downs???? ha! I have not even had the chance to DRIVE my van hardly yet. I am still sorting out the TB issue.... but yes, in a time crunch there are people who can fix the van cheap if necessary In Vancouver it was the opposite... almost nobody repairing VWs and absurdly high costs. That is why I got completely out of ownership 2 decades ago.
No the bottom of my van seems great and solid.
No high pressure washer... u suggest giving the underside a mega wash? This might reveal something? ...good idea! _________________ www.edwardpowell.com |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Sun Feb 07, 2016 2:47 pm Post subject: Re: Confusion: The final word on Rust |
I wouldn't undertake a powerwashing of a vehicle in winter conditions. It forces water into all manner of cracks and voids (and carries with it any salty deposits that weren't as deep into the cracks). And unless you can park it in a heated environment, the water in the thousands of nooks and crannies will be there for months.
That kind of thing is best done in the heat of summer.
I advocate a sane approach to rust and some do not. To me, cleaning it in the summer, then scraping loose undercoating until it is no longer popping off due to aged bonding, then using a spray product to recoat makes sense.
On rust repair, there are those who believe the nickname "cancer" for rust literally means it has a life of itself and can grow like a cancer. Those people will cut out perfectly good sheet metal with a rust spot here and there and weld in new sheet metal - not realizing all you have to do is sand to metal, recoat and fill voids with metal only at the spot. So know what you are doing here - it is not a living thing and it is not rocket science. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
Merian Samba Member
Posted: Sun Feb 07, 2016 3:34 pm Post subject: Re: Confusion: The final word on Rust |
yes - it's for a lazy summer day
why not work on the throttle body while waiting for summer, tho it won't hurt to get it on a lift and check things over carefully - take pics
hose down every bolt and brake connection with Kroil
use a stiff hand brush to investigate things now
what I do is very minimal - but I don't live in the salt belt and my Vanagon has never done so either - I tracked all the 6 POs
if you are in BC with the Van, you can likely do what I do - inspect carefully; knock off any loose undercoating & touch it up
check kitchen back o' town area, etc. |
Merian Samba Member
Posted: Sun Feb 07, 2016 3:39 pm Post subject: Re: Confusion: The final word on Rust |
some disagreement with both of the 2 worthies above:
tho rust it is not a living thing - scientists have found bacteria that live in rust and exacerbate the rust
you can completely eradicate rust, but as a practical matter it is very hard to do so permanently
people who think otherwise need to spend more time outside the rust belt |
Posted: Sun Feb 07, 2016 3:46 pm Post subject: Re: Confusion: The final word on Rust |
IdahoDoug wrote: |
On rust repair, there are those who believe the nickname "cancer" for rust literally means it has a life of itself and can grow like a cancer. Those people will cut out perfectly good sheet metal with a rust spot here and there and weld in new sheet metal - not realizing all you have to do is sand to metal, recoat and fill voids with metal only at the spot. So know what you are doing here - it is not a living thing and it is not rocket science. |
Thanks for these words... speaks of sanity!
It does seem to make a lot of sense to do rust work in the heat of summer if at all possible [unfortunately right now I have to deal with some rust]... but doing an annual summer rust roundup seems like a great idea! _________________ www.edwardpowell.com |
Posted: Sun Feb 07, 2016 3:54 pm Post subject: Re: Confusion: The final word on Rust |
Merian wrote: |
No, I am in Czech --- very few rusty cars over here - I think they don't use too much salt here... In BC all the vans are rusted thru and thru... probably because of so much rain and tree leaves... So I feel lucky.
Yes, this is good advice to wait til summer and get it up high on a lift and simply inspect the heck outta it!! Then treat it 100%... ...after that an annual check up ought to be enough.
One thing I have always wondered about - why do people not simply re-build the frames main beams when and if they get rusted thru? Why do people rather just condemn the vehicle than weld in there new large frame member? _________________ www.edwardpowell.com |
outcaststudios Samba Member
Joined: February 09, 2015 Posts: 1732 Location: Maine
Posted: Sun Feb 07, 2016 3:59 pm Post subject: Re: Confusion: The final word on Rust |
for the most part understanding rust means having a deep understanding of metals and particularly iron-carbon alloys such as steel and its substructures. the mechanism of rust is obvious enough,water (contains o2) oxidizes(gains electrons) from iron(the reducing agent in the reaction)readily. the trick is to stop that from ever happening which is of course futile as that is why you cant name one single production method that has successfully avoided the reaction entirely(usuing iron steel alloys of course i dont mean resin etc), its a fact of our position on the planet in this atmosphere etc etc. the best processes are working on a substructure level like austenetic and martensitic , or graphoidal to name a few. however ,your cars arent going to be made from that(unless you're irish, re:deloreans lol) galvanizing doesnt always hold especially at deeper ares of a shape,nor does plating which also is limited by the geometry of wave functions to enter 90º spaces (standing waves) so the real solution is to only keep the vehicle in a perpetual vacuum and thus you will eliminate its contact with O2 and by default chlorine,sodium (seawater)and any other common catalyzing agent! everything will rust. to beat it for real involves leaving the planet _________________ '88Doka JX td
'69 westy
(rip)couple bugs
(rip)three type III"s
(rip) '81 vanagon
a bunch of french stuff,and 9 motorcycles.
https://www.thesamba.com/vw/classifieds/detail.php?id=2573791 |
Posted: Sun Feb 07, 2016 4:04 pm Post subject: Re: Confusion: The final word on Rust |
outcaststudios wrote: |
for the most part understanding rust means having a deep understanding of metals and particularly iron-carbon alloys such as steel and its substructures. the mechanism of rust is obvious enough,water (contains o2) oxidizes(gains electrons) from iron(the reducing agent in the reaction)readily. the trick is to stop that from ever happening which is of course futile as that is why you cant name one single production method that has successfully avoided the reaction entirely(usuing iron steel alloys of course i dont mean resin etc), its a fact of our position on the planet in this atmosphere etc etc. the best processes are working on a substructure level like austenetic and martensitic , or graphoidal to name a few. however ,your cars arent going to be made from that(unless you're irish, re:deloreans lol) galvanizing doesnt always hold especially at deeper ares of a shape,nor does plating which also is limited by the geometry of wave functions to enter 90º spaces (standing waves) so the real solution is to only keep the vehicle in a perpetual vacuum and thus you will eliminate its contact with O2 and by default chlorine,sodium (seawater)and any other common catalyzing agent! everything will rust. to beat it for real involves leaving the planet |
So the ONLY way to truly beat rust is to accept that it will rust, and then get busy learning how to weld, and expect to have to eventually replace every metal part of the van? That's what Vilayat Khan had to do with his famous amazing sounding sitar... they just kept on replaced different parts of that instrument until eventually nothing was original anymore _________________ www.edwardpowell.com |
Posted: Sun Feb 07, 2016 4:07 pm Post subject: Re: Confusion: The final word on Rust |
djkeev wrote: |
There is no simple one step repair for this truck. To fix the frame is simply a waste of time. This is a future parts truck.
abandon ship? _________________ www.edwardpowell.com |
