misfitnick Samba Member
Joined: January 02, 2008 Posts: 16 Location: Navarre, Florida
Posted: Wed Mar 23, 2016 5:22 pm Post subject: Silly towing question...loose/missing body mount bolts ok? |
I need to take my 56 Oval over to the blaster's in preparation for body repairs. I want the body to be off the pan when it's being blasted in order to get all of the nooks and crannies. I don't have a real good way of transporting the body after it has been removed from the pan, but if the body is still mounted to the pan I can just tow the car using my tow bar.
So....would it be okay to have the body "loosely" attached to the pan with just a few key bolts, so that I could remove the body once the car is at the blasting shop? Would there be any concerns with structural integrity of the body if I did this? Which particular bolts should I leave installed during the tow? I only have a few miles to travel along quiet backroads, and the towing speed would likely never exceed 30 mph.
After the body is blasted, I would just reverse the process in order to tow the car back home. What do you think, is there any reason why this wouldn't work? Your thoughts? Thank you... |
splitjunkie Samba Member
Posted: Wed Mar 23, 2016 6:19 pm Post subject: Re: Silly towing question...loose/missing body mount bolts ok? |
I transported my split on a U haul car carrier with just the two front beam, four front heater channel and the large four under seat bolts with no problems on a 400 mile move.
As long as you don't have anything heavy sitting on the floor pans you should be fine with just those bolts. _________________ Chris
stanovich Samba Member
Joined: March 18, 2013 Posts: 191 Location: central coast calif
Posted: Wed Mar 23, 2016 7:24 pm Post subject: Re: Silly towing question...loose/missing body mount bolts ok? |
towed my 55 with just the front 2 bolts and steering wheel/shaft in place 9 mi flat tow 55mph . |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Thu Mar 24, 2016 2:26 pm Post subject: Re: Silly towing question...loose/missing body mount bolts ok? |
misfitnick wrote: |
I only have a few miles to travel along quiet backroads, and the towing speed would likely never exceed 30 mph. Your thoughts?
I agree . . . . should not be a problem. _________________ Jesucristo es mi Seņor y Salvador! |
green giant Samba Member
Posted: Fri Apr 08, 2016 8:16 am Post subject: Re: Silly towing question...loose/missing body mount bolts ok? |
it should be fine |
